8.2
cs_mass_source_terms.h
1 #ifndef __CS_MASS_SOURCE_TERMS_H__
2 #define __CS_MASS_SOURCE_TERMS_H__
5  * Mass source terms computation.
29  * Local headers
32 #include "cs_base.h"
34 /*----------------------------------------------------------------------------*/
38 /*=============================================================================
39  * Public function prototypes
40  *============================================================================*/
43 /*
44  * \brief Implicit and explicit mass source terms computation.
45  *
46  * \param[in] iterns iteration number on Navier-Stoke
47  * \param[in] dim associated field dimension
48  * \param[in] ncesmp number of cells with mass source term
49  * \param[in] icetsm source mass cells pointer (1-based numbering)
50  * \param[in] itpsmp mass source type for the working variable
51  * \param[in] volume cells volume
52  * \param[in] pvara variable value at time step beginning
53  * \param[in] smcelp value of the variable associated with mass source
54  * \param[in] gamma flow mass value
55  * \param[in,out] st_exp explicit source term part linear in the variable
56  * \param[in,out] st_imp associated value with \c tsexp
57  * to be stored in the matrix
58  * \param[out] gapinj explicit source term part independent
59  * of the variable
60  */
61 /*----------------------------------------------------------------------------*/
62
63 void
64 cs_mass_source_terms(int iterns,
65  int dim,
66  cs_lnum_t ncesmp,
67  const cs_lnum_t icetsm[],
68  int itpsmp[],
69  const cs_real_t volume[],
70  const cs_real_t pvara[],
71  const cs_real_t smcelp[],
72  const cs_real_t gamma[],
73  cs_real_t st_exp[],
74  cs_real_t st_imp[],
75  cs_real_t gapinj[]);
76
77 /*----------------------------------------------------------------------------*/
78
80
81 #endif /* __CS_MASS_SOURCE_TERMS_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ gamma
Definition: cs_field_pointer.h:222
void cs_mass_source_terms(int iterns, int dim, cs_lnum_t ncesmp, const cs_lnum_t icetsm[], int itpsmp[], const cs_real_t volume[], const cs_real_t pvara[], const cs_real_t smcelp[], const cs_real_t gamma[], cs_real_t st_exp[], cs_real_t st_imp[], cs_real_t gapinj[])
Definition: cs_mass_source_terms.c:231
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:), pointer volume
volume of each cell
Definition: mesh.f90:108
