1 #ifndef __CS_HHO_SCALEQ_H__
2 #define __CS_HHO_SCALEQ_H__
61 typedef struct _cs_hho_scaleq_t cs_hho_scaleq_t;
276 void *scheme_context);
292 void *scheme_context);
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
unsigned short int cs_flag_t
Definition: cs_defs.h:334
void cs_hho_scaleq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition: cs_hho_scaleq.c:696
void * cs_hho_scaleq_free_context(void *data)
Destroy a cs_hho_scaleq_t structure.
Definition: cs_hho_scaleq.c:956
void cs_hho_scaleq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_hho_scaleq.c:1663
void cs_hho_scaleq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_hho_scaleq.c:1520
void cs_hho_scaleq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_hho_scaleq.c:994
void cs_hho_scaleq_finalize_sharing(void)
Free buffers and generic structures related to HHO schemes.
Definition: cs_hho_scaleq.c:719
cs_real_t * cs_hho_scaleq_get_cell_values(void *context, bool previous)
Get the computed values at cells (DoF used in the linear system are located at primal faces)
Definition: cs_hho_scaleq.c:1494
cs_real_t * cs_hho_scaleq_get_face_values(void *context, bool previous)
Get the computed values at faces (DoF used in the linear system are located at primal faces)
Definition: cs_hho_scaleq.c:1467
void cs_hho_scaleq_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme....
Definition: cs_hho_scaleq.c:1087
void cs_hho_scaleq_init_sharing(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition: cs_hho_scaleq.c:594
void cs_hho_scaleq_initialize_system(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associ...
Definition: cs_hho_scaleq.c:1044
void cs_hho_scaleq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_hho_scaleq.c:1602
void cs_hho_scaleq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition: cs_hho_scaleq.c:1353
void * cs_hho_scaleq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_hho_scaleq_t structure storing data useful for building and managing such a scheme.
Definition: cs_hho_scaleq.c:758
Definition: cs_matrix.h:110
Definition: cs_restart.h:95
double precision, dimension(:,:), pointer solu
Definition: atincl.f90:308
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_local.h:60
Definition: cs_equation_param.h:193
Definition: cs_hho_builder.h:54
time step descriptor
Definition: cs_time_step.h:64
