8.2
cs_boundary_conditions_priv.h
1 #ifndef __CS_BOUNDARY_CONDITIONS_PRIV_H__
2 #define __CS_BOUNDARY_CONDITIONS_PRIV_H__
5  * Private types for boundary condition handling.
30 #include "cs_defs.h"
37  * Local headers
40 #include "cs_function.h"
41 #include "cs_math.h"
42 #include "cs_mesh_location.h"
43 #include "cs_time_control.h"
44 #include "cs_zone.h"
45
46 /*----------------------------------------------------------------------------*/
49
53  * Local Macro definitions
55
56 /*============================================================================
57  * Local type definitions
59
62 typedef enum {
63
64  CS_BC_VEL_RESCALE_NONE,
65  CS_BC_VEL_RESCALE_MASS_FLOW_RATE,
66  CS_BC_VEL_RESCALE_VOLUME_FLOW_RATE
68 } cs_bc_velocity_rescale_t;
69
72 /* Enum for boundary conditions of multiple turbulence values */
73
74 typedef enum {
75
76  CS_BC_TURB_NONE = 0,
77  CS_BC_TURB_BY_HYDRAULIC_DIAMETER,
78  CS_BC_TURB_BY_TURBULENT_INTENSITY
80 } cs_bc_turbulence_compute_t;
81
83 #define CS_BC_OPEN_CONSTANT (1 << 1)
84
86 #define CS_BC_OPEN_UNIFORM_QUANTITY (1 << 2)
87
89 #define CS_BC_OPEN_UNIFORM_DIRECTION (1 << 3)
90
92 #define CS_BC_OPEN_NORMAL_DIRECTION (1 << 4)
93
95 /*----------------------------------------------------*/
96
116 typedef struct {
117
118  const cs_zone_t *zone;
120  cs_time_control_t tc;
122  int vel_flags;
124  cs_bc_velocity_rescale_t vel_rescale;
125  cs_bc_turbulence_compute_t turb_compute;
127  int bc_pm_zone_num;
131  cs_real_t vel_values[4];
137  cs_real_t *vel_buffer;
140  cs_real_t hyd_diameter;
141  cs_real_t turb_intensity;
143  cs_real_t c_pr;
145  cs_real_t c_tk;
148  cs_eval_at_location_t *vel_func;
150  void *vel_func_input;
153  cs_eval_at_location_t *flow_func;
156  void *flow_func_input;
159  cs_eval_at_location_t *scale_func;
161  void *scale_func_input;
164  cs_dof_func_t *dof_func;
168  void *model_inlet;
171  cs_destructor_t *model_inlet_del;
176 } cs_boundary_conditions_open_t;
177
180 /*=============================================================================
181  * Semi-private function prototypes
182  *============================================================================*/
183
184 /*----------------------------------------------------------------------------*/
192 /*----------------------------------------------------------------------------*/
193
194 cs_boundary_conditions_open_t *
196
197 /*----------------------------------------------------------------------------*/
205 /*----------------------------------------------------------------------------*/
206
207 cs_boundary_conditions_open_t *
209
210 /*----------------------------------------------------------------------------*/
211
213
214 #endif /* __CS_BOUNDARY_CONDITIONS_PRIV_H__ */
cs_boundary_conditions_open_t * cs_boundary_conditions_open_find_or_add(const cs_zone_t *zone)
Find or add an open boundary context for a given zone.
Definition: cs_boundary_conditions.c:1774
cs_boundary_conditions_open_t * cs_boundary_conditions_open_find(const cs_zone_t *zone)
Get an open boundary context structure for a given zone.
Definition: cs_boundary_conditions.c:1869
void *() cs_destructor_t(void *s)
Destroy a given structure.
Definition: cs_defs.h:627
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:112
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
Definition: cs_time_control.h:96
Definition: cs_zone.h:55
