8.2
cs_bad_cells_regularisation.h
1 #ifndef __CS_BAD_CELLS_REGULARISATION_H__
2 #define __CS_BAD_CELLS_REGULARISATION_H__
5  * Divergence operators.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_halo.h"
36
38
41 /*=============================================================================
42  * Local Macro definitions
46  * Type definition
48
50  * Global variables
52
54  * Public function prototypes for Fortran API
56
57 /*=============================================================================
58  * Public function prototypes
59  *============================================================================*/
60
61 /*----------------------------------------------------------------------------*/
67 /*----------------------------------------------------------------------------*/
68
69 void
71
78 /*----------------------------------------------------------------------------*/
79
80 void
82  int boundary_projection);
83
84 /*----------------------------------------------------------------------------*/
91
92 void
94  int boundary_projection);
95
96 /*----------------------------------------------------------------------------*/
103
104 void
106  int boundary_projection);
107
108 /*----------------------------------------------------------------------------*/
109
111
112 #endif /* __CS_BAD_CELLS_REGULARISATION_H__ */
void cs_bad_cells_regularisation_sym_tensor(cs_real_6_t *var, int boundary_projection)
Regularisation on bad cells for symmetric tensors.
Definition: cs_bad_cells_regularisation.c:390
void cs_bad_cells_regularisation_tensor(cs_real_9_t *var, int boundary_projection)
Regularisation on bad cells for tensors.
Definition: cs_bad_cells_regularisation.c:570
void cs_bad_cells_regularisation_scalar(cs_real_t *var)
Regularisation on bad cells for scalars.
Definition: cs_bad_cells_regularisation.c:79
void cs_bad_cells_regularisation_vector(cs_real_3_t *var, int boundary_projection)
Regularisation on bad cells for vectors.
Definition: cs_bad_cells_regularisation.c:204
Definition: cs_defs.h:528
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:349
Definition: cs_defs.h:529
cs_real_t cs_real_9_t[9]
Definition: cs_defs.h:351
