1 #ifndef __CS_ATMO_AEROSOL_SSH_H__
2 #define __CS_ATMO_AEROSOL_SSH_H__
void cs_atmo_aerosol_ssh_initialize(void)
This function initializes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:341
void cs_atmo_aerosol_ssh_get_aero(cs_real_t *)
This function fills the given array with aerosol concentrations and numbers from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:670
void cs_atmo_aerosol_ssh_set_gas(cs_real_t *)
This function uses the given array to update the gas concentrations in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:712
void cs_atmo_aerosol_ssh_time_advance(void)
This function computes a time step of gaseous chemistry and aerosols dynamic using SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:763
void cs_atmo_aerosol_ssh_compute_numbers(cs_real_t *)
This function computes the number of aerosols using the given array.
Definition: cs_atmo_aerosol_ssh.c:558
void cs_atmo_aerosol_ssh_finalize(void)
This function finalizes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:533
void cs_atmo_aerosol_ssh_get_gas(cs_real_t *)
This function fills the given array with gas concentrations from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:736
void cs_atmo_aerosol_ssh_set_t_p_h(cs_real_t *T, cs_real_t *P, cs_real_t *yw)
This function takes as input absolute temperature T total pressure P water mass fraction yw It comput...
Definition: cs_atmo_aerosol_ssh.c:601
void cs_atmo_aerosol_ssh_set_aero(cs_real_t *)
This function uses the given array to update the aerosol concentrations and numbers in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:638
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
