A second method of defining an inlet condition which converges towards an infinite channel profile is based simply on feedback from values computed at inlet cell centers (combining the inlet boundary conditions and the effect of wall friction on the inlet walls). It assumes the mesh is very regular and orthogonal, at least on the first two inlet cell layers (using a gradient correction in the case of a less regular mesh might work, but has never been tested.
const cs_lnum_t n_cells_ext = domain->mesh->n_cells_with_ghosts;
const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
const int nt_cur = domain->time_step->nt_cur;
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
#define restrict
Definition: cs_defs.h:141
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:325
int cs_field_n_fields(void)
Definition: cs_field.c:1593
Definition: cs_field.c:2719
@ vel
@ rho_b
#define CS_F_(e)
Definition: cs_physical_constants.c:445
real(c_double), pointer, save viscl0
reference molecular dynamic viscosity.
Definition: cstphy.f90:160
double viscl0
Definition: cs_physical_constants.h:75
Here, we define an inlet boundary condition for a very long channel or duct with a section matching the boundary faces of zone 'INLET'.
We fix a mean inlet velocity, and use a feedback loop assuming a fixed-point type behavior will allow us to reach a state matching that of a very long inlet channel.
For EBRSM of V2f models, to avoid laminarization at the inlet, the initial velocity (at the first time step) is divided by 10 on inlet faces adjacent to the boundary, so as to ensure a velocity gradient and turbulent production. Otherwise, the initialization may fail.
if (nt_cur == 1) {
int *mrkcel = NULL;
mrkcel[i] = 0;
for (
cs_lnum_t f_id = 0; f_id < n_b_faces; f_id++) {
mrkcel[c_id] = 1;
const cs_lnum_t c_id = b_face_cells[face_id];
for (
int ii = 0; ii<
CS_F_(
vel)->dim; ii++)
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id]
= -fmprsc*b_face_normal[face_id][ii]/b_face_surf[face_id];
if (mrkcel[c_id] == 1)
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*0 + face_id] = fmprsc/10;
for (
int ii = 0; ii<
CS_F_(
vel)->dim; ii++)
uref2 += pow(
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id], 2);
uref2,
xdh,
b_rho,
if (sc_id < 0)
continue;
else {
acc[0] += vnrm*b_face_surf[face_id];
acc[1] += b_face_surf[face_id];
fmul = fmprsc/(acc[0]/acc[1]);
for (
int ii = 0; ii<
CS_F_(
vel)->dim; ii++)
CS_F_(
= -fmul*vnrm*b_face_normal[face_id][ii]/b_face_surf[face_id];
CS_F_(
k)->bc_coeffs->rcodcl1[face_id] =
CS_F_(
k)->val[c_id];
CS_F_(
rij)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id]
CS_F_(
CS_F_(
k)->val[c_id];
CS_F_(
CS_F_(
k)->val[c_id];
if (sc_id < 0)
continue;
Definition: bft_mem.h:97
#define BFT_FREE(_ptr)
Free allocated memory.
Definition: bft_mem.h:136
#define CS_REAL_TYPE
Definition: cs_defs.h:472
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:346
Definition: cs_field.c:2465
Definition: cs_field.c:3213
@ alp_bl
Definition: cs_field_pointer.h:77
@ nusa
Definition: cs_field_pointer.h:81
@ k
@ eps
Definition: cs_field_pointer.h:71
@ omg
Definition: cs_field_pointer.h:80
@ rij
Definition: cs_field_pointer.h:73
@ phi
Definition: cs_field_pointer.h:75
@ f_bar
Definition: cs_field_pointer.h:76
const cs_real_t cs_math_epzero
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:460
static CS_F_HOST_DEVICE cs_real_t cs_math_fmax(cs_real_t x, cs_real_t y)
Definition: cs_math.h:200
static void cs_parall_sum(int n, cs_datatype_t datatype, void *val)
Sum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:154
@ CS_INLET
Definition: cs_parameters.h:85
@ CS_SMOOTHWALL
Definition: cs_parameters.h:89
Definition: cs_turbulence_bc.c:871
const cs_turb_model_t * cs_glob_turb_model
@ CS_TURB_SPALART_ALLMARAS
Definition: cs_turbulence_model.h:69
@ CS_TURB_RIJ_EPSILON_EBRSM
Definition: cs_turbulence_model.h:62
@ CS_TURB_V2F_PHI
Definition: cs_turbulence_model.h:66
@ CS_TURB_V2F_BL_V2K
Definition: cs_turbulence_model.h:67
@ CS_TURB_K_OMEGA
Definition: cs_turbulence_model.h:68
cs_real_t * rcodcl1
Definition: cs_field.h:109
Definition: cs_field.h:131
cs_real_t * val
Definition: cs_field.h:152
Definition: cs_field.h:163
int iturb
Definition: cs_turbulence_model.h:117
int itytur
Definition: cs_turbulence_model.h:139
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
cs_lnum_t n_elts
Definition: cs_zone.h:64
