Using an appropriate CAD representation, it may be possible to compute the porosity fields using "common" or "cut" boolean operations between cells in the porous zones and the CAD volume. If the CAD shape represents the actual fluid volume, the common volume between the shape and the porous mesh section's cells will be used. If the CAD shape represents the solid volume, it should be cut from the pourous mesh section's cells.
The following example uses functions from the OpenCascade Technology (OCCT) libraries (https://dev.opencascade.org/doc/overview/html/index.html), and assumes they are installed on the user's machine. As these libraries form the backbone of the SALOME platform's CAD features, they are present with any generic or common SALOME install, and are available as a package in many Linux distributions.
Libraries to compile and link.
As the OCCT libraries provide a C++ API, interfacing them with code_saturne requires a file written in C++, so the following example uses a separate C++ file, cs_cad_intersect.cxx to to most of the work. This file is also a user example, and may be improved or modified.
To compile and link, additional compiler flags must be passed to code_saturne. They may be defined in <_ref cs_user_scripts.py, and the following values are recommended (adapting the paths to the local environment):
occ_include_path = "/opt/occ/7.4.0/include/opencascade"
occ_lib_paths = ("/opt/occ/7.4.0/lib", "/opt/gl2ps/1.4.0.1/lib")
occ_libs "-lTKMesh -lTKernel -lTKG2d -lTKG3d -lTKMath -lTKIGES -lTKXSBase -lTKBin -lTKBool -lTKBO -lTKCDF -lTKBRep -lTKTopAlgo -lTKGeomAlgo -lTKGeomBase -lTKOffset -lTKPrim -lTKSTEP -lTKSTEPBase -lTKSTEPAttr -lTKHLR -lTKFeat"
domain.compile_cxxflags = "-std=c++11 -I" + occ_include_path;
domain.compile_libs = ""
for p in occ_lib_paths:
domain.compile_libs += "-L" + p + " -Wl,-rpath -Wl," + p + " "
domain.compile_libs += occ_libs
Function prototypes.
As the prototypes for the cs_cad_intersect.cxx are not part of the defaul code_saturne installation, do not forget to include the cs_cad_intersect.h header in the Local headers section of the cs_user_porosity.c file:
#include "cs_cad_intersect.h"
Zone selection
It is recommended to use the standard zone selection mechanism to select cells which may be intersected by the CAD shape, for example:
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.c:677
Local variables and initialization
A few local variables may allow a more concise syntax, and optional face porosity arrays may be declared as temporary work arrays if face factors are required::
cs_real_t *i_face_porosity, *b_face_porosity;
i_face_porosity[i] = 1;
b_face_porosity[i] = 1;
Definition: bft_mem.h:97
Definition: cs_defs.h:332
Definition: cs_defs.h:325
Definition: cs_field.c:2489
cs_real_t * val
Definition: cs_field.h:152
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
CAD intersection operation
The actual CAD intersection is done using the following call (adapting the file path to the actual file):
cs_cad_intersect(m,
"Compound_1.step",
CS_CAD_INTERSECT_CUT,
cell_porosity,
NULL,
i_face_porosity,
NULL,
b_face_porosity,
NULL);
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
cs_lnum_t n_elts
Definition: cs_zone.h:64
Computing porous quantities
Though the cell porosity is directly set by the call above, face quantities may be computed from the face porosities. The following code also handles the cleanup op local arrays.
for (
cs_lnum_t f_id = 0; f_id < n_i_faces; f_id++) {
cs_real_t f_porosity = i_face_porosity[f_id];
i_f_face_normal[f_id][i] = f_porosity * i_face_normal[f_id][i];
for (
cs_lnum_t f_id = 0; f_id < n_b_faces; f_id++) {
cs_real_t f_porosity = b_face_porosity[f_id];
b_f_face_normal[f_id][i] = f_porosity * b_face_normal[f_id][i];
CS_MAX(i_f_face_surf[f_id] / i_face_surf[f_id],
#define BFT_FREE(_ptr)
Free allocated memory.
Definition: bft_mem.h:136
#define restrict
Definition: cs_defs.h:141
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:340
#define CS_MAX(a, b)
Definition: cs_defs.h:492
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
void cs_halo_sync_var(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
Definition: cs_halo.cpp:2071
@ CS_HALO_EXTENDED
Definition: cs_halo.h:59
const cs_real_t cs_math_epzero
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:460
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:117
cs_real_2_t * i_f_face_factor
Definition: cs_mesh_quantities.h:127
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:118
cs_real_t * i_f_face_surf
Definition: cs_mesh_quantities.h:120
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:102
cs_real_t * i_f_face_normal
Definition: cs_mesh_quantities.h:104
cs_real_t * b_f_face_surf
Definition: cs_mesh_quantities.h:121
cs_real_t * b_f_face_normal
Definition: cs_mesh_quantities.h:106
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:100
cs_halo_t * halo
Definition: cs_mesh.h:156
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
