if (domain->time_step->nt_prev > 0)
return;
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[restrict])
Assign a constant scalar value to an array.
Definition: cs_array.c:581
cs_combustion_model_t * cs_glob_combustion_model
Definition: cs_combustion_model.c:120
Definition: cs_defs.h:319
Definition: cs_defs.h:313
@ fm
Definition: cs_field_pointer.h:127
#define CS_F_(e)
int cs_glob_physical_model_flag[CS_N_PHYSICAL_MODEL_TYPES]
Definition: cs_physical_model.c:108
@ CS_COMBUSTION_3PT
Definition: cs_physical_model.h:58
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.c:216
real(c_double), dimension(:), pointer, save fs
Mixing rate at the stoichiometry.
Definition: ppthch.f90:147
real(c_double), pointer, save hinoxy
Definition: coincl.f90:88
real(c_double), pointer, save hinfue
double hinfue
Definition: cs_combustion_model.h:78
double fs[CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS]
Definition: cs_combustion_model.h:97
Definition: cs_combustion_model.h:104
cs_combustion_gas_model_t * gas
Definition: cs_combustion_model.h:106
double hinoxy
Definition: cs_combustion_model.h:140
cs_real_t * val
Definition: cs_field.h:152
