1 #ifndef __FVM_MORTON_H__
2 #define __FVM_MORTON_H__
114 #if defined(HAVE_MPI)
283 #if defined(HAVE_MPI)
305 fvm_morton_build_rank_index(
int dim,
Definition: cs_defs.h:514
double cs_coord_t
Definition: cs_defs.h:317
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
Definition: cs_defs.h:515
Definition: cs_defs.h:313
void fvm_morton_local_sort(cs_lnum_t n_codes, fvm_morton_code_t morton_codes[])
Definition: fvm_morton.c:1170
fvm_morton_code_t fvm_morton_encode(int dim, fvm_morton_int_t level, const cs_coord_t coords[])
Definition: fvm_morton.c:950
bool fvm_morton_a_ge_b(fvm_morton_code_t a, fvm_morton_code_t b)
Definition: fvm_morton.c:1290
void fvm_morton_local_order(cs_lnum_t n_codes, const fvm_morton_code_t morton_codes[], cs_lnum_t order[])
Definition: fvm_morton.c:1121
void fvm_morton_get_global_extents(int dim, size_t n_extents, const cs_coord_t extents[], cs_coord_t g_extents[])
Definition: fvm_morton.c:904
int fvm_morton_compare_o(const void *elt1, const void *elt2, const void *input)
Function pointer for comparison of 2 Morton codes.
Definition: fvm_morton.c:1463
fvm_morton_compare_t fvm_morton_compare(int dim, fvm_morton_code_t code_a, fvm_morton_code_t code_b)
Definition: fvm_morton.c:1218
int fvm_morton_binary_search(cs_lnum_t size, fvm_morton_code_t code, fvm_morton_code_t *codes)
Definition: fvm_morton.c:1311
void fvm_morton_s_to_code(double s, void *elt, const void *input)
Function pointer for conversion of a double precision value in range [0, 1] to a given Morton code.
Definition: fvm_morton.c:1436
Definition: fvm_morton.h:52
@ FVM_MORTON_SAME_ANCHOR
Definition: fvm_morton.h:55
@ FVM_MORTON_EQUAL_ID
Definition: fvm_morton.h:54
@ FVM_MORTON_DIFFERENT_ID
Definition: fvm_morton.h:56
void fvm_morton_get_coord_extents(int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[])
Definition: fvm_morton.c:852
void fvm_morton_dump(int dim, fvm_morton_code_t code)
Definition: fvm_morton.c:1489
unsigned int fvm_morton_int_t
Definition: fvm_morton.h:60
void fvm_morton_encode_coords(int dim, fvm_morton_int_t level, const cs_coord_t extents[], size_t n_coords, const cs_coord_t coords[], fvm_morton_code_t m_code[])
Definition: fvm_morton.c:988
bool fvm_morton_a_gt_b(fvm_morton_code_t a, fvm_morton_code_t b)
Definition: fvm_morton.c:1272
void fvm_morton_get_children(int dim, fvm_morton_code_t parent, fvm_morton_code_t children[])
Definition: fvm_morton.c:1063
Definition: fvm_morton.h:62
fvm_morton_int_t L
Definition: fvm_morton.h:64
