8.1
fvm_interpolate.h
1 #ifndef __FVM_INTERPOLATE_H__
2 #define __FVM_INTERPOLATE_H__
5  * Interpolate data defined on a nodal representation associated with a mesh.
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_nodal.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*=============================================================================
52  * Static global variables
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Interpolate vertex-based values to points located relative to a mesh.
61  *
62  * Least-squared based interpolation is used for now.
63  *
64  * parameters:
65  * this_nodal <-- pointer to nodal mesh representation structure
66  * entity_dim <-- 3 for location on cells, 2 for faces, 1 for edges,
67  * and 0 for vertices
68  * data_dim <-- data dimension
69  * n_points <-- number of points to locate
70  * location_id <-- id of element (with concatenated sections)
71  * in which each point is located
72  * point_coords <-- point coordinates
73  * src_data <-- source data (interleaved)
74  * dest_data <-> destination data (interleaved)
75  *----------------------------------------------------------------------------*/
76
77 void
78 fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal,
79  int entity_dim,
80  int data_dim,
81  cs_lnum_t n_points,
82  const cs_lnum_t location_id[],
83  const cs_coord_t point_coords[],
84  const cs_real_t src_data[],
85  cs_real_t dest_data[]);
86
87 /*----------------------------------------------------------------------------*/
88
90
91 #endif /* __FVM_INTERPOLATE_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
double cs_coord_t
Definition: cs_defs.h:317
Definition: cs_defs.h:515
Definition: cs_defs.h:313
void fvm_interpolate_vtx_data(const fvm_nodal_t *this_nodal, int entity_dim, int data_dim, cs_lnum_t n_points, const cs_lnum_t location_id[], const cs_coord_t point_coords[], const cs_real_t src_data[], cs_real_t dest_data[])
Definition: fvm_interpolate.c:107
