1 #ifndef __CS_TURBULENCE_V2F_H__
2 #define __CS_TURBULENCE_V2F_H__
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ dt
void cs_turbulence_v2f_bl_v2k_mu_t(void)
Calculation of turbulent viscosity for the V2F-BL model.
Definition: cs_turbulence_v2f.c:1292
void cs_turbulence_v2f_phi_mu_t(void)
Calculation of turbulent viscosity for the V2F-phi model.
Definition: cs_turbulence_v2f.c:1247
void cs_turbulence_v2f(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t *dt, cs_real_t smacel[], const cs_real_t prdv2f[])
Solve the V2F phi-model equations.
Definition: cs_turbulence_v2f.c:1114
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:191
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:185
