8.1
cs_turbulence_sa.h
1 #ifndef __CS_TURBUBELNCE_SA_H__
2 #define __CS_TURBUBELNCE_SA_H__
5  * nu_tilda turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
45 /*
46  * \brief Solve the \f$ \tilde{\nu} \f$ equations.
47  *
48  * Solve the equation of \f$ \tilde{\nu} \f$, which is the scalar
49  * quantity defined by the Spalart-Allmaras model for one time-step.
50  *
51  * \param[in] ncesmp number of cells with mass source term
52  * \param[in] icetsm index of cells with mass source term
53  * \param[in] itypsm mass source type for the variables
54  * size: [nvar][ncesmp]
55  * \param[in] dt time step (per cell)
56  * \param[in] smacel values of the variables associated to the
57  * mass source (for the pressure variable,
58  * smacel is the mass flux)
59  * size: [nvar][ncesmp]
60  * \param[in] b_face_type boundary face types
61  */
63
64 void
66  cs_lnum_t icetsm[],
67  int itypsm[],
68  const cs_real_t dt[],
69  cs_real_t smacel[],
70  const int b_face_type[]);
71
73 /*
74  * \brief Calculation of turbulent viscosity for
75  * the Spalart-Allmaras model.
76  */
77 /*----------------------------------------------------------------------------*/
78
79 void
81
82 /*----------------------------------------------------------------------------*/
83
85
86 #endif /* __CS_TURBUBELNCE_SA_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ dt
void cs_turbulence_sa(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[], const int b_face_type[])
Solve the equations.
Definition: cs_turbulence_sa.c:417
void cs_turbulence_sa_mu_t(void)
Calculation of turbulent viscosity for the Spalart-Allmaras model.
Definition: cs_turbulence_sa.c:715
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:191
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:185
