8.1
cs_turbulence_ke.h
1 #ifndef __CS_TURBULENCE_KE_H__
2 #define __CS_TURBULENCE_KE_H__
5  * k-epsilon turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
63 /*----------------------------------------------------------------------------*/
64
65 void
66 cs_turbulence_ke(int phase_id,
67  cs_lnum_t ncesmp,
68  cs_lnum_t icetsm[],
69  int itypsm[],
70  const cs_real_t *dt,
71  cs_real_t smacel[],
72  cs_real_t *prdv2f);
73
83 /*----------------------------------------------------------------------------*/
84
85 void
86 cs_turbulence_ke_clip(int phase_id,
87  cs_lnum_t n_cells,
88  int iclip);
89
96 /*----------------------------------------------------------------------------*/
97
98 void
99 cs_turbulence_ke_mu_t(int phase_id);
100
101 /*----------------------------------------------------------------------------*/
109 /*----------------------------------------------------------------------------*/
110
111 void
112 cs_turbulence_ke_q_mu_t(int phase_id);
113
114 /*----------------------------------------------------------------------------*/
123
124 void
125 cs_turbulence_ke_q(int phase_id,
126  cs_real_6_t rij[]);
127
129
131
132 #endif /* __CS_TURBULENCE_KE_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:336
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ rij
Definition: cs_field_pointer.h:73
@ dt
void cs_turbulence_ke_q_mu_t(int phase_id)
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al....
Definition: cs_turbulence_ke.c:2454
void cs_turbulence_ke_clip(int phase_id, cs_lnum_t n_cells, int iclip)
Clipping of the turbulent kinetic energy and turbulent dissipation.
Definition: cs_turbulence_ke.c:2134
void cs_turbulence_ke_q(int phase_id, cs_real_6_t rij[])
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al....
Definition: cs_turbulence_ke.c:2566
void cs_turbulence_ke(int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t *dt, cs_real_t smacel[], cs_real_t *prdv2f)
Solve the k-epsilon equations.
void cs_turbulence_ke_mu_t(int phase_id)
Calculation of turbulent viscosity for the K-epsilon model.
Definition: cs_turbulence_ke.c:2372
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:191
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:185
