8.1
cs_parameters_check.h
1 #ifndef __CS_PARAMETERS_CHECK_H__
2 #define __CS_PARAMETERS_CHECK_H__
5  * Log field and other array statistics at relevant time steps.
35  * Local headers
38 #include "cs_base.h"
45  * type definitions
48 /*----------------------------------------------------------------------------*/
49
52 typedef enum {
53
60
61 /*============================================================================
62  * Public function prototypes
63  *============================================================================*/
64
65 /*----------------------------------------------------------------------------*/
75 /*----------------------------------------------------------------------------*/
76
77 #if defined(__GNUC__)
78
79 void
81  const char *section_desc,
82  const char *format,
83  ...)
84  __attribute__((format(printf, 3, 4)));
85
86 #else
87
88 void
90  const char *section_desc,
91  const char *format,
92  ...);
93
94 #endif
95
96 /*----------------------------------------------------------------------------*/
106 /*----------------------------------------------------------------------------*/
107
108 void
110  const char *section_desc,
111  const char *format,
112  ...);
113
114 /*----------------------------------------------------------------------------*/
123
124 void
126  const char *section_desc);
127
135
136 void
138
139 /*----------------------------------------------------------------------------*/
151 /*----------------------------------------------------------------------------*/
152
153 void
155  const char *section_desc,
156  const char *param_name,
157  int param_value,
158  int range_l,
159  int range_u);
160
161 /*----------------------------------------------------------------------------*/
174 /*----------------------------------------------------------------------------*/
175
176 void
178  const char *section_desc,
179  const char *param_name,
180  int param_value,
181  int range_l,
182  int range_u);
183
184 /*----------------------------------------------------------------------------*/
198 /*----------------------------------------------------------------------------*/
199
200 void
202  const char *section_desc,
203  const char *param_name,
204  int param_value,
205  int enum_size,
206  const int *enum_values,
207  const char *enum_names[]);
208
209 /*----------------------------------------------------------------------------*/
224 /*----------------------------------------------------------------------------*/
225
226 void
228  const char *section_desc,
229  const char *param_name,
230  int param_value,
231  int enum_size,
232  const int *enum_values,
233  const char *enum_names[]);
234
235 /*----------------------------------------------------------------------------*/
246 /*----------------------------------------------------------------------------*/
247
248 void
250  const char *section_desc,
251  const char *param_name,
252  int param_value,
253  int std_value);
254
255 /*----------------------------------------------------------------------------*/
266 /*----------------------------------------------------------------------------*/
267
268 void
270  const char *section_desc,
271  const char *param_name,
272  int param_value,
273  int fbd_value);
274
275 /*----------------------------------------------------------------------------*/
285 /*----------------------------------------------------------------------------*/
286
287 void
289  const char *section_desc,
290  const char *param_name,
291  int param_value);
292
293 /*----------------------------------------------------------------------------*/
304 /*----------------------------------------------------------------------------*/
305
306 void
308  const char *section_desc,
309  const char *param_name,
310  int param_value,
311  int ib_value);
312
313 /*----------------------------------------------------------------------------*/
325 /*----------------------------------------------------------------------------*/
326
327 void
329  const char *section_desc,
330  const char *param_name,
331  double param_value,
332  double range_l,
333  double range_u);
334
335 /*----------------------------------------------------------------------------*/
348 /*----------------------------------------------------------------------------*/
349
350 void
352  const char *section_desc,
353  const char *param_name,
354  double param_value,
355  int enum_size,
356  const double *enum_values,
357  const char *enum_names[]);
358
359 /*----------------------------------------------------------------------------*/
370 /*----------------------------------------------------------------------------*/
371
372 void
374  const char *section_desc,
375  const char *param_name,
376  double param_value,
377  double std_value);
378
379 /*----------------------------------------------------------------------------*/
390 /*----------------------------------------------------------------------------*/
391
392 void
394  const char *section_desc,
395  const char *param_name,
396  double param_value,
397  double ib_value);
398
399 /*----------------------------------------------------------------------------*/
403 /*----------------------------------------------------------------------------*/
404
405 void
407
408 /*----------------------------------------------------------------------------
409 !
410  * \brief Check data settings
411  */
412 /*----------------------------------------------------------------------------*/
413
414 void
415 cs_parameters_check(void);
416
417 /*----------------------------------------------------------------------------*/
418
420
421 #endif /* __CS_PARAMETERS_CHECK_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:515
void cs_parameters_is_not_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int fbd_value)
Check that a given integer keyword is not equal to a specified value.
Definition: cs_parameters_check.c:517
void cs_parameters_error_footer(cs_parameter_error_behavior_t err_behavior)
Print footer for a given parameters error message type.
Definition: cs_parameters_check.c:236
void cs_parameters_is_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int std_value)
Check that a given integer keyword is equal to a specified value.
Definition: cs_parameters_check.c:475
void cs_parameters_error_barrier(void)
Abort if the the parameter errors count is nonzero.
Definition: cs_parameters_check.c:786
void cs_parameters_is_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has values in a specified range.
Definition: cs_parameters_check.c:259
Definition: cs_parameters_check.h:52
@ CS_WARNING
Definition: cs_parameters_check.h:54
@ CS_ABORT_DELAYED
Definition: cs_parameters_check.h:55
@ CS_ABORT_IMMEDIATE
Definition: cs_parameters_check.h:57
void cs_parameters_is_positive_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value)
Check that a given integer keyword is strictly positive.
Definition: cs_parameters_check.c:551
void cs_parameters_is_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Definition: cs_parameters_check.c:336
void cs_parameters_error(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *format,...)
Print general parameters error or warning info.
Definition: cs_parameters_check.c:169
void cs_parameters_is_in_list_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, int enum_size, const double *enum_values, const char *enum_names[])
Check that a given double keyword has values in a specified list.
Definition: cs_parameters_check.c:659
void cs_parameters_is_not_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Check that a given integer keyword does not have values in a specified list.
Definition: cs_parameters_check.c:405
void cs_parameters_is_equal_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double std_value)
Check that a given double keyword is equal to a specified value.
Definition: cs_parameters_check.c:716
void cs_parameters_is_greater_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double ib_value)
Check that a given double keyword is greater than a specified value.
Definition: cs_parameters_check.c:758
void cs_parameters_is_not_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has not values in a specified range.
Definition: cs_parameters_check.c:297
void cs_parameters_check(void)
Check computation parameters after user modification.
Definition: cs_parameters_check.c:810
void cs_parameters_is_in_range_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double range_l, double range_u)
Check that a given double keyword has values in a specified range.
Definition: cs_parameters_check.c:621
void cs_parameters_is_greater_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int ib_value)
Check that a given int keyword is greater than a specified value.
Definition: cs_parameters_check.c:585
void cs_parameters_error_header(cs_parameter_error_behavior_t err_behavior, const char *section_desc)
Print header for a given parameters error message type.
Definition: cs_parameters_check.c:199
