1 #ifndef __CS_PARAMEDMEM_REMAPPER_HXX__
2 #define __CS_PARAMEDMEM_REMAPPER_HXX__
38 typedef struct _cs_paramedmem_remapper_t cs_paramedmem_remapper_t;
55 cs_paramedmem_remapper_t *
57 const char *sel_criteria,
73 cs_paramedmem_remapper_t *
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
@ dt
cs_real_t * cs_paramedmem_remap_field_one_time(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it)
Remaps a field from the med file to the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:593
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_paramedmem_remapper.cxx:554
cs_real_t * cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval)
Interpolate a given field on the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:708
void cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition: cs_paramedmem_remapper.cxx:836
void cs_paramedmem_remapper_destroy_all(void)
Destroy all remappers.
Definition: cs_paramedmem_remapper.cxx:868
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create(char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius)
Creates a new cs_paramedmem_remapper_t instance.
Definition: cs_paramedmem_remapper.cxx:496
void cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_paramedmem_remapper.cxx:804
