8.1
cs_param_cdo.h
1 #ifndef __CS_PARAM_CDO_H__
2 #define __CS_PARAM_CDO_H__
5  * High-level metadata related to CDO/HHO schemes
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
44 /* Specifications for OpenMP loops/sections */
45
46 #define CS_CDO_OMP_CHUNK_SIZE 128
47 #define CS_CDO_OMP_SCHEDULE schedule(static, CS_CDO_OMP_CHUNK_SIZE)
48 #define CS_CDO_OMP_SYNC_MODE 0 /* > 0 --> critical sections otherwise
49  * atomic sections is used */
50
51 /* Avoid issues with assert in some OpenMp contructs using gcc 9 */
52
53 #if defined(HAVE_OPENMP) && defined(__GNUC__)
54  #if __GNUC__ == 9
55  #define CS_CDO_OMP_ASSERT(e)
56  #else
57  #define CS_CDO_OMP_ASSERT(e) assert(e)
58  #endif
59 #else
60  #define CS_CDO_OMP_ASSERT(e) assert(e)
61 #endif
62
63 /* The following limitation only results from an optimization in the size of
64  the bit mask (can be changed if needed by changing the definition of
65  the type cs_mask_t)
66  Here is the max. number of reaction terms allowed in an equation */
67
68 #define CS_CDO_N_MAX_REACTIONS 8
69
70 #define CS_ALL_FACES 0 /* All faces: interior + border */
71 #define CS_BND_FACES 1 /* Boundary faces */
72 #define CS_INT_FACES 2 /* Interior faces */
73
74 /* HHO specific part:
75  *
76  * Number of DoFs on faces and cells according to the polynomial space
77  */
78
79 #define CS_N_DOFS_FACE_0TH 1
80 #define CS_N_DOFS_FACE_1ST 3
81 #define CS_N_DOFS_FACE_2ND 6
82
83 #define CS_N_DOFS_CELL_0TH 1
84 #define CS_N_DOFS_CELL_1ST 4
85 #define CS_N_DOFS_CELL_2ND 10
86
87 /*============================================================================
88  * Type definitions
89  *============================================================================*/
90
91 typedef enum {
92
93  CS_PARAM_CDO_MODE_OFF = -1, /* CDO schemes are not used */
94  CS_PARAM_CDO_MODE_WITH_FV = 1, /* CDO and legacy FV schemes are used */
95  CS_PARAM_CDO_MODE_ONLY = 2 /* Only CDO schemes are used */
96
98
99 /*============================================================================
100  * Global variables
101  *============================================================================*/
102
104
105 /*============================================================================
106  * Public function prototypes
107  *============================================================================*/
108
109 /*----------------------------------------------------------------------------*/
114 /*----------------------------------------------------------------------------*/
115
116 void
118
119 /*----------------------------------------------------------------------------*/
125 /*----------------------------------------------------------------------------*/
126
129
130 /*----------------------------------------------------------------------------*/
135
136 void
137 cs_param_cdo_log(void);
138
139 /*----------------------------------------------------------------------------*/
143 /*----------------------------------------------------------------------------*/
144
145 void
147
148 /*----------------------------------------------------------------------------*/
149
151
152 #endif /* __CS_PARAM_CDO_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:515
void cs_param_cdo_log(void)
Print a welcome message indicating what is the current CDO status.
Definition: cs_param_cdo.c:139
cs_param_cdo_mode_t
Definition: cs_param_cdo.h:90
@ CS_PARAM_CDO_MODE_ONLY
Definition: cs_param_cdo.h:94
@ CS_PARAM_CDO_MODE_OFF
Definition: cs_param_cdo.h:92
@ CS_PARAM_CDO_MODE_WITH_FV
Definition: cs_param_cdo.h:93
cs_param_cdo_mode_t cs_glob_param_cdo_mode
void cs_param_cdo_setup_log(void)
Print generic parameters used with CDO/HHO schemes.
Definition: cs_param_cdo.c:171
cs_param_cdo_mode_t cs_param_cdo_mode_get(void)
Get the mode of activation for the CDO/HHO schemes.
Definition: cs_param_cdo.c:127
void cs_param_cdo_mode_set(cs_param_cdo_mode_t mode)
Set the global variable storing the mode of activation to apply to CDO/HHO schemes....
Definition: cs_param_cdo.c:113
