8.1
cs_mesh_warping.h
1 #ifndef __CS_MESH_WARPING_H__
2 #define __CS_MESH_WARPING_H__
5  * Cut warped faces in serial or parallel with/without periodicity.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_mesh.h"
36
38
42  * Macro definitions
46  * Type definitions
48
49 /*=============================================================================
50  * Public function prototypes
52
53 /*----------------------------------------------------------------------------
54  * Cut warped faces.
55  *
56  * Updates border face connectivity and associated mesh quantities.
57  *
58  * parameters:
59  * mesh <-> pointer to mesh structure.
60  * max_warp_angle <-- criterion to know which face to cut
61  * post_flag <-- 1 if we have to post-process cut faces, 0 otherwise
62  *----------------------------------------------------------------------------*/
63
64 void
66  double max_warp_angle,
67  bool post_flag);
68
69 /*----------------------------------------------------------------------------
70  * Set defaults for cutting of warped faces.
71  *
72  * parameters:
73  * max_warp_angle <-- maximum warp angle (in degrees) over which faces will
74  * be cut; negative (-1) if faces should not be cut
75  * postprocess <-- 1 if postprocessing should be activated when cutting
76  * warped faces, 0 otherwise
77  *----------------------------------------------------------------------------*/
78
79 void
80 cs_mesh_warping_set_defaults(double max_warp_angle,
81  int postprocess);
82
83 /*----------------------------------------------------------------------------
84  * Get defaults for cutting of warped faces.
85  *
86  * parameters:
87  * max_warp_angle --> if non NULL, returns maximum warp angle (in degrees)
88  * over which faces will be cut, or -1 if faces should
89  * not be cut
90  * postprocess --> if non NULL, returns 1 if postprocessing should be
91  * activated when cutting warped faces, 0 otherwise
92  *----------------------------------------------------------------------------*/
93
94 void
95 cs_mesh_warping_get_defaults(double *max_warp_angle,
96  int *postprocess);
97
98 /*----------------------------------------------------------------------------*/
99
101
102 #endif /* __CS_MESH_WARPING_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:515
void cs_mesh_warping_cut_faces(cs_mesh_t *mesh, double max_warp_angle, bool post_flag)
Cut warped boundary faces.
Definition: cs_mesh_warping.c:542
void cs_mesh_warping_get_defaults(double *max_warp_angle, int *postprocess)
Definition: cs_mesh_warping.c:702
void cs_mesh_warping_set_defaults(double max_warp_angle, int postprocess)
Definition: cs_mesh_warping.c:678
Definition: mesh.f90:26
Definition: cs_mesh.h:85
