8.1
cs_ibm.h
1 #ifndef __CS_IBM_H__
2 #define __CS_IBM_H__
5  * Time and space immersed boundaries model.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_mesh_quantities.h"
37 #include "cs_stl.h"
38 #include "cs_xdef.h"
42 #ifndef DOXYGEN_SHOULD_SKIP_THIS
45
46 #endif /* DOXYGEN_SHOULD_SKIP_THIS */
49  * Local Macro definitions
51
53  * Type definition
55
56 /*---------------------------------------------------------------------------
57  * Choice for porosity model
58  *---------------------------------------------------------------------------*/
59
60 typedef enum
61 {
62  CS_IBM_OFF = 0, /* No immersed boundary model */
63  CS_IBM_FIXED_SOLID = 1, /* Fix solid porosity model */
64
66
67 /*---------------------------------------------------------------------------
68  * Detection of problem dimension type for immersed boundaries
69  *---------------------------------------------------------------------------*/
70
71 typedef enum
72 {
73  CS_IBM_3D = -1, /* 3D computation */
74  CS_IBM_2D_X = 0, /* 2D computation with symmetry in X direction */
75  CS_IBM_2D_Y = 1, /* 2D computation with symmetry in Y direction */
76  CS_IBM_2D_Z = 2 /* 2D computation with symmetry in Z direction */
77
79
80 /*---------------------------------------------------------------------------
81  * Algorithm choice for porosity computation
82  *---------------------------------------------------------------------------*/
83
84 typedef enum
85 {
86  CS_IBM_ALGO_NONE , /* Default init before knowing the chosen algo */
87  CS_IBM_ALGO_CUT_CELLS , /* Cut-cells: optimised cutting */
88  CS_IBM_ALGO_MEDCOUPLING, /* MEDCoupling sequential volume interpolation */
89  CS_IBM_ALGO_STL , /* Computation from STL ASCII file */
90
91  CS_N_VAR_PORO_ALGO_TYPES /* Number of algo choices */
92
94
95 /*---------------------------------------------------------------------------
96  * Choice for B.C. at walls
97  *---------------------------------------------------------------------------*/
98
99 typedef enum
100 {
101  CS_IBM_SLIP_WALL_CONDITION , /* Slip wall b.c. */
102  CS_IBM_NO_SLIP_WALL_CONDITION , /* No-Slip wall b.c. */
103  CS_IBM_WALL_LAW_WALL_CONDITION /* Wall law wall b.c. */
104
106
107 /*---------------------------------------------------------------------------
108  * Objects mechanical or thermophysical properties
109  *---------------------------------------------------------------------------*/
110
111 typedef enum
112 {
113
126
128
130
131 typedef enum
132 {
140
142
144
145 /*---------------------------------------------------------------------------
146  * Structure associated to objects management
147  *---------------------------------------------------------------------------*/
148
149 typedef int
150 (cs_cutcell_func_t)(const cs_lnum_t c_id,
151  const cs_real_3_t xyz,
152  const cs_real_t t,
153  const int num_object);
154
155 /*---------------------------------------------------------------------------
156  * Structure associated to objects management
157  *---------------------------------------------------------------------------*/
158
159 /*----------------------------------------------------------------------------
160  * Porosity immersed boundaries model options descriptor
161  *----------------------------------------------------------------------------*/
162
163 typedef struct {
166
167 /* Pointer to options structure */
169
170 typedef struct
171 {
172
173  /* --------------------------------------- */
174  /* Name of the object */
175  /* --------------------------------------- */
176  char *name;
177
178  /* --------------------------------------- */
179  /* Computation method */
180  /* --------------------------------------- */
182
183  /* --------------------------------------- */
184  /* Method specific pointers */
187  cs_medcoupling_intersector_t *mi;
188  /* --------------------------------------- */
189
190  /* --------------------------------------- */
191  /* Object thermophysical properties */
193  /* --------------------------------------- */
194
195  /* --------------------------------------- */
196  /* Initial parameters */
198  /* --------------------------------------- */
199
201
202 /*---------------------------------------------------------------------------
203  * Structure associated to immersed boundaries management
204  *---------------------------------------------------------------------------*/
205
206 typedef struct
207 {
208  /* ---------------------------------------------- */
209  /* Objects defined using stl or medcoupling. */
212  /* ---------------------------------------------- */
213
214  /* Detection of prob dim type for immersed boundaries */
216  /* Algorithm choice for porosity computation */
218  /* Choice for velocity B.C. at walls */
220  /* Number of sub-cut for cells using the Cut-Cells algo */
222  /* Number of sub-cut for faces using the Cut-Cells algo */
224  /* Porosity dynamic modification */
226  /* Limitation area for porosity calculation */
228  /* Limitation area for porosity calculation */
230  /* Solid internal porosity */
232  /* Fluid volume at the first time step */
234  /* Keep same volume for porous object at each iteration */
236  /* Cell porosity based on nodes porosity (smoothing) */
238
239 } cs_ibm_t;
240
241
242 /*============================================================================
243  * Global variables
244  *============================================================================*/
245
246 /* Pointer to the cs_ibm structure for various arrays */
247
248 extern cs_ibm_t *cs_ibm;
249
250 /*============================================================================
251  * Public function prototypes
252  *============================================================================*/
253
254 /*----------------------------------------------------------------------------*/
262 /*----------------------------------------------------------------------------*/
263
265 cs_ibm_object_by_id(int obj_id);
266
267 /*----------------------------------------------------------------------------*/
275 /*----------------------------------------------------------------------------*/
276
278 cs_ibm_object_by_name_try(const char *name);
279
280 /*----------------------------------------------------------------------------*/
288 /*----------------------------------------------------------------------------*/
289
291 cs_ibm_object_by_name(const char *name);
292
293 /*----------------------------------------------------------------------------
294  * Create an empty cs_ibm structure for various arrays
295  *
296  * returns:
297  * pointer to created cs_ibm structure
298  *----------------------------------------------------------------------------*/
299
300 cs_ibm_t *
301 cs_ibm_create(void);
302
303 /*----------------------------------------------------------------------------
304  * Destroy a cs_ibm structure
305  *
306  * cs_ibm <-- pointer to a cs_ibm_t structure
307  *
308  * returns:
309  * NULL
310  *----------------------------------------------------------------------------*/
311
312 void
313 cs_ibm_finalize(void);
314
315 /*----------------------------------------------------------------------------
316  * Define immersed boundaries in time and space (solid(s) interior part).
317  *----------------------------------------------------------------------------*/
318
320  const cs_mesh_quantities_t *mesh_quantities);
321
322 /*----------------------------------------------------------------------------
323  * Define space immersed boundaries on a set of zones defined by the user in the
324  * GUI
325  *----------------------------------------------------------------------------*/
326
327 void cs_volumic_zone_porosity(const cs_mesh_quantities_t *mesh_quantities);
328
329 /*----------------------------------------------------------------------------*
330  * User function. Locally Modify porosity (erosion, fouling effects, ...)
331  *----------------------------------------------------------------------------*/
332
333 void cs_user_ibm_modify(const cs_mesh_t *mesh,
334  const cs_mesh_quantities_t *mesh_quantities);
335
336 /*----------------------------------------------------------------------------*/
344 /*----------------------------------------------------------------------------*/
345
347 cs_ibm_object_by_id(int obj_id);
348
349 /*----------------------------------------------------------------------------*/
357 /*----------------------------------------------------------------------------*/
358
360 cs_ibm_object_by_name_try(const char *name);
361
362 /*----------------------------------------------------------------------------*/
372 /*----------------------------------------------------------------------------*/
373
374 int
376  const cs_real_3_t xyz,
377  const cs_real_t t,
378  const int num_object);
379
380 /*----------------------------------------------------------------------------*/
390 /*----------------------------------------------------------------------------*/
391
392 void
393 cs_ibm_add_object_from_file(const char *name,
394  cs_ibm_algo_type_t method,
395  const char *file_name,
396  bool solve_fsi);
397
398 /*----------------------------------------------------------------------------*/
409 /*----------------------------------------------------------------------------*/
410
411 void
412 cs_ibm_add_object_from_func(const char *name,
413  cs_cutcell_func_t *cutcell_func,
414  bool solve_fsi,
415  int n_nodes);
416
417 /*----------------------------------------------------------------------------*/
425 /*----------------------------------------------------------------------------*/
426
427 void
428 cs_ibm_stl_define_ext_points(const char *name,
429  const int n_pts,
430  cs_real_t *pts_coords);
431
432 /*----------------------------------------------------------------------------*/
441 /*----------------------------------------------------------------------------*/
442
443 void
444 cs_ibm_object_rotate(const char *name,
445  cs_real_t angle,
446  cs_real_t axis[3],
447  cs_real_t center[3]);
448
449 /*----------------------------------------------------------------------------*/
457 /*----------------------------------------------------------------------------*/
458
459 void
462  cs_real_t val);
463
464 /*----------------------------------------------------------------------------*/
471 /*----------------------------------------------------------------------------*/
472
473 void
474 cs_ibm_object_translate(const char *name,
475  cs_real_t vector[3]);
476
477 /*----------------------------------------------------------------------------*/
484 /*----------------------------------------------------------------------------*/
485
486 void
487 cs_ibm_object_scale(const char *name,
488  cs_real_t factor);
489
490 /*----------------------------------------------------------------------------*/
494 /*----------------------------------------------------------------------------*/
495
496 void
498
499 /*----------------------------------------------------------------------------*/
503 /*----------------------------------------------------------------------------*/
504
505 void
506 cs_ibm_init_writer(void);
507
508 /*----------------------------------------------------------------------------*/
516 /*----------------------------------------------------------------------------*/
517
518 void
521
522 /*----------------------------------------------------------------------------*/
532 /*----------------------------------------------------------------------------*/
533
534 void
536  const cs_mesh_t *m,
537  const cs_real_t *cell_vol,
538  cs_real_t *obj_frac_tot,
539  int *indic);
540
541 /*----------------------------------------------------------------------------*/
545 /*----------------------------------------------------------------------------*/
546
547 void
549
550 /*----------------------------------------------------------------------------*/
555 /*----------------------------------------------------------------------------*/
556
557 void
559
560 /*----------------------------------------------------------------------------*/
567 /*----------------------------------------------------------------------------*/
568
569 void
571
572 /*----------------------------------------------------------------------------*/
581 /*----------------------------------------------------------------------------*/
582
583 void
585  const cs_real_3_t xyz,
586  const cs_real_t t,
587  const int num_object);
588
589 /*----------------------------------------------------------------------------*/
596 /*----------------------------------------------------------------------------*/
597
598 void
599 cs_ibm_volumic_zone(const cs_mesh_quantities_t *mesh_quantities);
600
601 /*----------------------------------------------------------------------------*/
602
604
605 #endif /* __CS_IBM_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
cs_real_t cs_real_34_t[3][4]
Definition: cs_defs.h:349
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ t
void cs_user_ibm_parameters(void)
User function to set global parameters for the immersed boundaries module.
Definition: cs_user_ibm.c:84
void cs_ibm_add_object_from_func(const char *name, cs_cutcell_func_t *cutcell_func, bool solve_fsi, int n_nodes)
Define an object from a function used in the cutcell algorithm.
Definition: cs_ibm.c:4243
void cs_immersed_boundaries(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Definition: cs_ibm.c:3801
void cs_ibm_user_parameters(void)
Apply user parameters.
Definition: cs_ibm.c:4466
void cs_ibm_volumic_zone(const cs_mesh_quantities_t *mesh_quantities)
Define space immersed boundaries on a set of zones defined by the user in the GUI.
Definition: cs_ibm.c:4667
int cs_ibm_object_compute_cut_porosity(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
Check if a point is solid or fluid based on the cut-cell method.
Definition: cs_ibm.c:4155
void cs_user_ibm_define_objects(void)
User function in which the user defines the objects to model.
Definition: cs_user_ibm.c:70
void cs_ibm_object_compute_intersect_vol(cs_ibm_object_t *obj, const cs_mesh_t *m, const cs_real_t *cell_vol, cs_real_t *obj_frac_tot, int *indic)
Compute the volume fraction of an object over all cells.
Definition: cs_ibm.c:4589
void cs_ibm_init_writer(void)
Init writers for STL or MED objects.
Definition: cs_ibm.c:4485
cs_ibm_object_init_param_t
Definition: cs_ibm.h:132
@ CS_IBM_OBJ_INIT_FLUID_FORCE
Definition: cs_ibm.h:139
@ CS_IBM_OBJ_INIT_ANGLE
Definition: cs_ibm.h:135
@ CS_IBM_OBJ_INIT_ANGULAR_VEL
Definition: cs_ibm.h:138
@ CS_N_IBM_OBJ_INIT_TYPES
Definition: cs_ibm.h:141
@ CS_IBM_OBJ_INIT_COG
Definition: cs_ibm.h:134
@ CS_IBM_OBJ_INIT_VELOCITY
Definition: cs_ibm.h:136
@ CS_IBM_OBJ_INIT_ACCELERATION
Definition: cs_ibm.h:137
@ CS_IBM_OBJ_INIT_COG_EQ
Definition: cs_ibm.h:133
cs_ibm_object_property_type_t
Definition: cs_ibm.h:112
@ CS_IBM_OBJ_PROP_STIFFNESS
Definition: cs_ibm.h:119
@ CS_IBM_OBJ_PROP_DAMPING
Definition: cs_ibm.h:120
@ CS_IBM_OBJ_PROP_YOUNG_MODULE
Definition: cs_ibm.h:121
@ CS_IBM_OBJ_PROP_RAYLEIGH_DAMP_A
Definition: cs_ibm.h:124
@ CS_N_IBM_OBJ_PROP_TYPES
Definition: cs_ibm.h:127
@ NC_IBM_OBJ_PROP_INERTIA_MATRIX
Definition: cs_ibm.h:116
@ CS_IBM_OBJ_PROP_CROSS_SECTION
Definition: cs_ibm.h:123
@ CS_IBM_OBJ_PROP_CP
Definition: cs_ibm.h:117
@ CS_IBM_OBJ_PROP_DENSITY
Definition: cs_ibm.h:114
@ CS_IBM_OBJ_PROP_RAYLEIGH_DAMP_B
Definition: cs_ibm.h:125
@ CS_IBM_OBJ_PROP_INERTIA_MOM
Definition: cs_ibm.h:122
@ CS_IBM_OBJ_PROP_LAMBDA
Definition: cs_ibm.h:118
@ NC_IBM_OBJ_PROP_MASS
Definition: cs_ibm.h:115
cs_ibm_object_t * cs_ibm_object_by_id(int obj_id)
Get an object based on its id.
Definition: cs_ibm.c:3652
cs_ibm_object_t * cs_ibm_object_by_name_try(const char *name)
Try to get an object based on its name. Returns NULL if not found.
Definition: cs_ibm.c:3672
cs_ibm_model_type_t
Definition: cs_ibm.h:61
@ CS_IBM_FIXED_SOLID
Definition: cs_ibm.h:63
@ CS_IBM_OFF
Definition: cs_ibm.h:62
void cs_ibm_object_transform_from_init(cs_ibm_object_t *obj, cs_real_34_t matrix)
Transform an object from its initial state using a transformation matrix.
Definition: cs_ibm.c:4553
void cs_user_ibm_modify(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
User function. Locally modify a given porosity to take into account erosion effect (for instance)
Definition: cs_user_ibm_modify.c:79
void cs_ibm_object_scale(const char *name, cs_real_t factor)
Scale an object based on a factor.
Definition: cs_ibm.c:4430
void cs_ibm_object_set_property_const(cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, cs_real_t val)
Define a new constant property definition for an object.
Definition: cs_ibm.c:4374
cs_ibm_t * cs_ibm_create(void)
Definition: cs_ibm.c:3727
void cs_user_ibm_solid_por(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
User function which allows the definition of a 'porous' object.
Definition: cs_user_ibm.c:120
cs_porosity_ibm_opt_t * cs_glob_porosity_ibm_opt
Definition: cs_ibm.c:98
cs_ibm_object_t * cs_ibm_object_by_name(const char *name)
Get an object based on its name. Error if not found.
Definition: cs_ibm.c:3699
int() cs_cutcell_func_t(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object)
Definition: cs_ibm.h:150
void cs_user_ibm_object_transformations(const cs_real_t time)
User function where to apply predefined transformations to med/stl based objects.
Definition: cs_user_ibm.c:101
cs_ibm_algo_type_t
Definition: cs_ibm.h:85
@ CS_IBM_ALGO_CUT_CELLS
Definition: cs_ibm.h:87
@ CS_N_VAR_PORO_ALGO_TYPES
Definition: cs_ibm.h:91
@ CS_IBM_ALGO_MEDCOUPLING
Definition: cs_ibm.h:88
@ CS_IBM_ALGO_NONE
Definition: cs_ibm.h:86
@ CS_IBM_ALGO_STL
Definition: cs_ibm.h:89
void cs_ibm_object_translate(const char *name, cs_real_t vector[3])
Translate an object based on the STL or MED algorithms.
Definition: cs_ibm.c:4391
void cs_ibm_object_rotate(const char *name, cs_real_t angle, cs_real_t axis[3], cs_real_t center[3])
Rotate an object based on the STL or MED algorithms.
Definition: cs_ibm.c:4326
void cs_ibm_add_object_from_file(const char *name, cs_ibm_algo_type_t method, const char *file_name, bool solve_fsi)
Define an object from a file using STL or MED formats.
Definition: cs_ibm.c:4190
void cs_ibm_stl_define_ext_points(const char *name, const int n_pts, cs_real_t *pts_coords)
Define exterior points for an STL object.
Definition: cs_ibm.c:4297
void cs_ibm_finalize(void)
Definition: cs_ibm.c:3765
cs_ibm_prob_dim_type_t
Definition: cs_ibm.h:72
@ CS_IBM_2D_Y
Definition: cs_ibm.h:75
@ CS_IBM_2D_Z
Definition: cs_ibm.h:76
@ CS_IBM_2D_X
Definition: cs_ibm.h:74
@ CS_IBM_3D
Definition: cs_ibm.h:73
cs_ibm_t * cs_ibm
Definition: cs_ibm.c:101
cs_ibm_wall_cond_type_t
Definition: cs_ibm.h:100
@ CS_IBM_WALL_LAW_WALL_CONDITION
Definition: cs_ibm.h:103
@ CS_IBM_SLIP_WALL_CONDITION
Definition: cs_ibm.h:101
@ CS_IBM_NO_SLIP_WALL_CONDITION
Definition: cs_ibm.h:102
Definition: mesh.f90:26
Definition: cs_ibm.h:171
cs_medcoupling_intersector_t * mi
Definition: cs_ibm.h:187
char * name
Definition: cs_ibm.h:176
Definition: cs_ibm.h:181
cs_stl_mesh_t * stl
Definition: cs_ibm.h:186
cs_cutcell_func_t * cutcell_func
Definition: cs_ibm.h:185
Definition: cs_ibm.h:207
bool porosity_from_nodes
Definition: cs_ibm.h:237
bool porosity_user_source_term_modification
Definition: cs_ibm.h:225
bool ensure_isovol
Definition: cs_ibm.h:235
int n_objects
Definition: cs_ibm.h:210
cs_ibm_prob_dim_type_t prob_dim
Definition: cs_ibm.h:215
cs_real_t isovol
Definition: cs_ibm.h:233
int nb_cut_faces
Definition: cs_ibm.h:223
cs_ibm_algo_type_t algo_choice
Definition: cs_ibm.h:217
cs_real_3_t xyzmax_moving_porosity
Definition: cs_ibm.h:229
cs_real_t * solid_porosity
Definition: cs_ibm.h:231
cs_real_3_t xyzmin_moving_porosity
Definition: cs_ibm.h:227
cs_ibm_object_t ** objects
Definition: cs_ibm.h:211
int nb_cut_cells
Definition: cs_ibm.h:221
cs_ibm_wall_cond_type_t wall_condition
Definition: cs_ibm.h:219
Definition: cs_mesh.h:85
Definition: cs_ibm.h:163
int porosity_mode
Definition: cs_ibm.h:164
Definition: cs_stl.h:54
Definition: cs_xdef.h:160
