8.1
cs_coal_boundary_conditions.h
1 #ifndef __CS_COAL_BOUNDARY_CONDITIONS_H__
2 #define __CS_COAL_BOUNDARY_CONDITIONS_H__
5  * Coal combustion model boundary conditions.
35  * Local headers
38 #include "cs_defs.h"
40 #include "cs_combustion_model.h"
45
47  * Macro definitions
49
51  * Local type definitions
53
56 typedef struct _cs_coal_bc_inlet_state_t cs_coal_bc_inlet_state_t;
57
60 typedef struct {
61
62  const cs_zone_t *zone;
64  int ientat;
65  int ientcp;
66  int inmoxy;
76
95  void *qm_air_input;
100  cs_coal_bc_inlet_state_t *state; /* Inlet state (not user-accessible) */
101
103
104 /*=============================================================================
105  * Global variables
106  *============================================================================*/
107
108 /*============================================================================
109  * Public function prototypes
110  *============================================================================*/
111
123 /*----------------------------------------------------------------------------*/
124
127
140 /*----------------------------------------------------------------------------*/
141
142 void
144  (const cs_zone_t *z,
145  cs_real_t q);
146
147 /*----------------------------------------------------------------------------*/
148 /*
149  * \brief Assign an air mass flow rate to an inlet based on provided function.
150  *
151  * The total mass flow rate will also include that of the pulverized coals.
152  *
153  * This is otherwise similar to
154  * \ref cs_boundary_conditions_open_set_mass_flow_rate_by_func.
155  *
156  * \param[in] z pointer to associated zone
157  * \param[in] func associated scalar (mass flow rate) evaluation function
158  * \param[in] input optional function evaluation input, or NULL
159  */
160 /*----------------------------------------------------------------------------*/
161
162 void
164  (const cs_zone_t *z,
165  cs_eval_at_location_t *func,
166  void *input);
167
168 /*----------------------------------------------------------------------------*/
174 /*----------------------------------------------------------------------------*/
175
176 void
177 cs_coal_boundary_conditions(int bc_type[]);
178
179 /*----------------------------------------------------------------------------*/
186 /*----------------------------------------------------------------------------*/
187
188 void
190
191 /*----------------------------------------------------------------------------*/
192
194
195 #endif /* __CS_COAL_BOUNDARY_CONDITIONS_H_ */
#define CS_COMBUSTION_MAX_CLASSES_PER_COAL
Definition: cs_coal.h:54
#define CS_COMBUSTION_MAX_COALS
Definition: cs_coal.h:51
void cs_coal_boundary_conditions(int bc_type[])
Automatic boundary condition for pulverized coal combution.
Definition: cs_coal_boundary_conditions.c:385
void cs_coal_boundary_conditions_inlet_density(void)
Compute density at inlets for pulverized coal combustion.
Definition: cs_coal_boundary_conditions.c:918
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Definition: cs_coal_boundary_conditions.c:362
cs_coal_bc_inlet_t * cs_coal_boundary_conditions_get_inlet(const cs_zone_t *zone)
Return pointer to coal boundary conditions inlet structure.
Definition: cs_coal_boundary_conditions.c:264
Inlet model state data.
Definition: cs_coal_boundary_conditions.h:56
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant air mass flow rate to an inlet.
Definition: cs_coal_boundary_conditions.c:333
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:112
Inlet definition for pulverized coal combustion.
Definition: cs_coal_boundary_conditions.h:60
void * qm_air_input
Definition: cs_coal_boundary_conditions.h:95
cs_eval_at_location_t * qm_air_func
Definition: cs_coal_boundary_conditions.h:93
cs_coal_bc_inlet_state_t * state
Definition: cs_coal_boundary_conditions.h:100
cs_real_t qm_air
Definition: cs_coal_boundary_conditions.h:91
cs_real_t t_air
Definition: cs_coal_boundary_conditions.h:77
int ientcp
Definition: cs_coal_boundary_conditions.h:65
int ientat
Definition: cs_coal_boundary_conditions.h:64
int inmoxy
Definition: cs_coal_boundary_conditions.h:66
const cs_zone_t * zone
Definition: cs_coal_boundary_conditions.h:62
Definition: cs_zone.h:55
