51 #define CS_COMBUSTION_MAX_COALS 5
54 #define CS_COMBUSTION_MAX_CLASSES_PER_COAL 20
57 #define CS_COMBUSTION_COAL_MAX_CLASSES CS_COMBUSTION_MAX_COALS \
58 * CS_COMBUSTION_MAX_CLASSES_PER_COAL
61 #define CS_COMBUSTION_COAL_MAX_TABULATION_POINTS 500
64 #define CS_COMBUSTION_COAL_MAX_SOLIDS CS_COMBUSTION_MAX_COALS * 4
221 const double xsolid[],
Definition: cs_coal.h:64
double cs_coal_thconvers1(const double xesp[], const double f1mc[], const double f2mc[], cs_real_t tp)
Compute gas enthalpy Function with gas temperature and concentrations.
Definition: cs_coal.h:57
Definition: cs_coal.h:61
double cs_coal_thconvers2(int class_id, const double xsolid[], cs_real_t temper)
Compute particles enthalpy Function with temperature and concentrations.
void cs_coal_rad_transfer_st(const cs_field_t *f, cs_real_t *smbrs, cs_real_t *rovsdt)
Take in account the radiative source terms in the particle equation of a given class for pulverized c...
Definition: cs_coal.c:216
Definition: cs_coal.h:51
cs_coal_model_t * cs_coal_model_create(void)
Create coal model object.
Definition: cs_coal.c:136
void cs_coal_model_destroy(cs_coal_model_t **cm)
Destroy coal model object.
Definition: cs_coal.c:195
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
real(c_double), dimension(:), pointer, save xashch
Definition: cpincl.f90:117
real(c_double), dimension(:), pointer, save eh0sol
Definition: cpincl.f90:180
real(c_double), dimension(:), pointer, save wmols
real(c_double), dimension(:), pointer, save diam20
Definition: cpincl.f90:198
real(c_double), dimension(:), pointer, save rho20
real(c_double), dimension(:), pointer, save rho2mn
integer(c_int), dimension(:), pointer, save iash
Definition: cpincl.f90:179
real(c_double), dimension(:), pointer, save dia2mn
integer(c_int), dimension(:), pointer, save iwat
real(c_double), dimension(:), pointer, save xmp0
real(c_double), dimension(:), pointer, save cp2ch
real(c_double), dimension(:), pointer, save xwatch
integer(c_int), dimension(:), pointer, save ick
integer(c_int), dimension(:), pointer, save ichcor
Definition: cpincl.f90:197
real(c_double), dimension(:,:), pointer, save ehsoli
int nsolim
Definition: cs_coal.h:78
int nclacp
Definition: cs_coal.h:76
int n_coals
Definition: cs_coal.h:75
Definition: cs_field.h:131
