1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
Structures and function pointers useful to build and solve the Navier-Stokes equations with face-base...
void cs_cdofb_monolithic_sles_clean(cs_cdofb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdofb_monolithic_sles.c:3977
int cs_cdofb_monolithic_uzawa_cg_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schem...
Definition: cs_cdofb_monolithic_sles.c:4908
int cs_cdofb_monolithic_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.c:4317
int cs_cdofb_monolithic_uzawa_al_incr_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian (ALU) technique in an incremental way to solve t...
Definition: cs_cdofb_monolithic_sles.c:5250
void cs_cdofb_monolithic_sles_finalize(void)
Free if needed structure(s) associated CDO face-based schemes with a monolithic velocity-pressure cou...
Definition: cs_cdofb_monolithic_sles.c:4042
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
Definition: cs_cdofb_monolithic_sles.c:4062
void cs_cdofb_monolithic_sles_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:4023
void cs_cdofb_monolithic_sles_free(cs_cdofb_monolithic_sles_t **p_msles)
Free memory related to cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3995
cs_cdofb_monolithic_sles_t * cs_cdofb_monolithic_sles_create(cs_lnum_t n_faces, cs_lnum_t n_cells)
Create an empty cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3945
int cs_cdofb_monolithic_gkb_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Na...
Definition: cs_cdofb_monolithic_sles.c:4741
int cs_cdofb_monolithic_block_krylov(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:4526
Definition: cs_defs.h:514
Definition: cs_defs.h:515
Definition: cs_defs.h:313
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_system.h:377
Definition: cs_cdofb_monolithic_priv.h:77
Definition: cs_navsto_param.h:611
Definition: cs_param_sles.h:213
