8.1
Basic examples
It is useful to map a field array to a local pointer for a clear and concise access, such as done here for the velocity:
const cs_real_3_t *cvara_vel = (const cs_real_3_t *)(CS_F_(vel)->val_pre);
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
@ vel
#define CS_F_(e)
Otherwise, the zone entries (see cs_volume_zone_t) should contain the necessary information with no additional preparation.
Body
Defining a volume zone
A volume zone may be defined using the GUI, or in the cs_user_zones user function (in cs_user_zones.c), such as the following zone determined by a geometric criterion:
cs_volume_zone_define("head_loss_1",
"box[4.0, 6.0, -1e6, 2.0, 8.0, 1e6]",
int cs_volume_zone_define(const char *name, const char *criteria, int type_flag)
Define a new volume zone using a selection criteria string.
Definition: cs_volume_zone.c:574
#define CS_VOLUME_ZONE_HEAD_LOSS
Definition: cs_volume_zone.h:67
Note that if the CS_VOLUME_ZONE_HEAD_LOSS flag is not set (or the matching type set through the GUI), calls to cs_user_head_losses will ignore this zone.
Head loss examples
Note that in the following examples, we check the zone name, so we know which zone we are dealing with using in case of multiple zones.
head loss tensor coefficients for each cell are organized as follows: cku11, cku22, cku33, cku12, cku13, cku23.
Note that diagonal coefficients must be positive; the calculation may crash if this is not the case.
Example 1: head losses alined with an axis of the computation frame
Using the previously defined zone, we define head losses in direction x
if (strcmp(zone->name, "head_loss_1") == 0) {
for (cs_lnum_t i = 0; i < zone->n_elts; i++) {
cs_lnum_t c_id = zone->elt_ids[i];
cs_real_t v = cs_math_3_norm(cvara_vel[c_id]);
cku[i][0] = 10.0 * v;
cku[i][1] = 0.0;
cku[i][2] = 0.0;
Definition: cs_defs.h:319
Definition: cs_defs.h:313
static cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:440
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
Example 2: head losses along a direction at 45 degrees
Necessary, we shall use here a 3x3 tensor to impose head losses at an angle $ alpha = 45^{o} $ with respect to x and y direction of the computation frame. Namely, resistance is set along components x by cku1 and y by cku2
Orthogonal reference frame sketch
In the present example, it is chosen to set a head loss representing friction along X and to model a vane in Y direction by setting ck1 = 0 .
/* define rotation matrix outside of loop on cells */
cs_real_t cosa = cos(alpha);
cs_real_t sina = sin(alpha);
cs_real_t ck0 = 10.0;
cs_real_t ck1 = 0.0;
cs_real_t a11 = cs_math_sq(cosa)*ck0 + cs_math_sq(sina)*ck1;
cs_real_t a22 = cs_math_sq(sina)*ck0 + cs_math_sq(cosa)*ck1;
cs_real_t a12 = cosa * sina * (ck0 - ck1);
/* compute local coefficients */
cku[i][0] = a11 * v;
cku[i][1] = a22 * v;
cku[i][2] = 0.;
cku[i][3] = a12 * v;
cku[i][4] = 0.;
cku[i][5] = 0.;
static cs_real_t cs_math_sq(cs_real_t x)
Definition: cs_math.h:222
const cs_real_t cs_math_pi
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:96
