As usual, one can access any field using the field_get_val_s_by_name function. cvar_*(iel) is the value of this variable in cell number iel. ONLY done if there is no restart computation
pulverized_coal example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel, ige, mode, icha
integer ioxy
double precision t1init, h1init, coefe(ngazem)
double precision t2init
double precision f1mc(ncharm), f2mc(ncharm)
double precision dmas, wmco2, wmh2o, wmn2, wmo2
double precision, dimension(:), pointer :: cvar_scalt, cvar_yco2
double precision, dimension(:), pointer :: cvar_hox
Initialization
The following initialization block allows setting some variable values (variables not set here keep their GUI-defined or default values):
if (isuite.gt.0) return
write(nfecra,9001)
t1init = t0
t2init = t0
do ige = 1, ngazem
coefe(ige) = zero
enddo
coefe(io2) = wmole(io2)*oxyo2(1) &
/( wmole(io2) *oxyo2(1) +wmole(in2) *oxyn2(1) &
+wmole(ih2o)*oxyh2o(1)+wmole(ico2)*oxyco2(1))
coefe(ih2o) = wmole(ih2o)*oxyh2o(1) &
coefe(ico2) = wmole(ico2)*oxyco2(1) &
coefe(in2) = 1.d0-coefe(io2)-coefe(ih2o)-coefe(ico2)
do icha = 1, ncharm
f1mc(icha) = zero
f2mc(icha) = zero
enddo
mode = -1
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
do iel = 1, ncel
cvar_scalt(iel) = h1init
enddo
call field_get_val_s(ivarfl(isca(iyco2)), cvar_yco2)
call field_get_val_s(ivarfl(isca(ihox)), cvar_hox)
if (ieqco2 .ge. 1) then
ioxy = 1
wmo2 = wmole(io2)
wmco2 = wmole(ico2)
wmh2o = wmole(ih2o)
wmn2 = wmole(in2)
dmas = ( oxyo2(ioxy)*wmo2 +oxyn2(ioxy)*wmn2 &
+oxyh2o(ioxy)*wmh2o+oxyco2(ioxy)*wmco2)
xco2 = oxyco2(ioxy)*wmco2/dmas
do iel = 1, ncel
cvar_yco2(iel) = oxyco2(ioxy)*wmco2/dmas
enddo
endif
if (ieqnox .eq. 1) then
do iel = 1, ncel
cvar_hox(iel) = h1init
enddo
endif
9001 format( /,&
' cs_user_initialization: settings for pulverized coal', /,&
subroutine cs_coal_htconvers1(mode, eh, xesp, f1mc, f2mc, tp)
Definition: cs_coal_htconvers1.f90:51
