8.0
Gas 3 PTCHEM examples
Local variables to be added
integer iel, ifac, izone, ii
integer ilelt, nlelt
double precision uref2, d2s3
double precision xkent, xeent
double precision dp, rho, S0, Kadm, radm, madm, Qadm, Padm, Ploc
double precision, dimension(:), pointer :: crom
integer, allocatable, dimension(:) :: lstelt
Example 1
Definition of a fuel flow inlet for each face of colour 11
call getfbr('11', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
! Type of pre-defined boundary condidition (see above)
itypfb(ifac) = ientre
! Zone number (arbitrary number between 1 and n)
izone = 1
! Allocation of the actual face to the zone
izfppp(ifac) = izone
! Indicating the inlet as a fuel flow inlet
ientfu(izone) = 1
! Inlet Temperature in K
tinfue = 436.d0
! The incoming fuel flow refers to:
! a) a massflow rate -> iqimp() = 1
iqimp(izone) = 1
qimp(izone) = 2.62609d-4 / 72.d0
! b) an inlet velocity -> iqimp() = 0
rcodcl(ifac,iu,1) = 0.d0
rcodcl(ifac,iv,1) = 0.d0
rcodcl(ifac,iw,1) = 21.47d0
! ATTENTION: If iqimp() = 1 the direction vector of the massfow has
! to begiven here.
! Boundary conditions of turbulence
icalke(izone) = 1
! - If ICALKE = 0 the boundary conditions of turbulence at
! the inlet are calculated as follows:
if(icalke(izone).eq.0) then
uref2 = rcodcl(ifac,iu,1)**2 &
+rcodcl(ifac,iv,1)**2 &
+rcodcl(ifac,iw,1)**2
uref2 = max(uref2,1.d-12)
xkent = epzero
xeent = epzero
if (itytur.eq.2) then
rcodcl(ifac,ik,1) = xkent
rcodcl(ifac,iep,1) = xeent
elseif(itytur.eq.3) then
rcodcl(ifac,ir11,1) = d2s3*xkent
rcodcl(ifac,ir22,1) = d2s3*xkent
rcodcl(ifac,ir33,1) = d2s3*xkent
rcodcl(ifac,ir12,1) = 0.d0
rcodcl(ifac,ir13,1) = 0.d0
rcodcl(ifac,ir23,1) = 0.d0
elseif (iturb.eq.50) then
rcodcl(ifac,iphi,1) = d2s3
rcodcl(ifac,ifb,1) = 0.d0
elseif (iturb.eq.60) then
rcodcl(ifac,iomg,1) = xeent/cmu/xkent
elseif (iturb.eq.70) then
rcodcl(ifac,inusa,1) = cmu*xkent**2/xeent
endif
endif
! - If ICALKE = 1 the boundary conditions of turbulence at
! the inlet refer to both, a hydraulic diameter and a
! reference velocity.
dh(izone) = 0.032d0
! - If ICALKE = 2 the boundary conditions of turbulence at
! the inlet refer to a turbulence intensity.
xintur(izone) = 0.d0
enddo
subroutine getfbr(fstr, facnb, faces)
Build the list of boundary faces matching a criteria string.
Definition: cs_selector_f2c.f90:111
Example 2
Definition of an air flow inlet for each face of colour 21
call getfbr('21', nlelt, lstelt)
do ilelt = 1, nlelt
izone = 2
! Indicating the inlet as a air flow inlet
ientox(izone) = 1
tinoxy = 353.d0
! The inflowing fuel flow refers to:
iqimp(izone) = 1
qimp(izone) = 4.282d-3 / 72.d0
rcodcl(ifac,iw,1) = 0.097d0
! to be given here.
icalke(izone) = 1
xkent = epzero
xeent = epzero
endif
endif
dh(izone) = 0.218d0
enddo
Example 3
Definition of a wall for each face of colour 51 up to 59
call getfbr('51 to 59', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = iparoi
izone = 3
enddo
Example 4
Definition of an exit for each face of colour 91
call getfbr('91', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = isolib
izone = 4
enddo
Example 5
Definition of symmetric boundary conditions for each face of colour 41 and 4.
call getfbr('41 or 4', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = isymet
izone = 5
enddo
