8.0
Probes and profiles
About Probes and profiles
Sets of probes may also be defined through the cs_user_postprocess_probes function, to allow for extraction and output of values at specific mesh locations, often with a higher time frequency than for volume or surface meshes.
Probe sets, and profiles (which can be viewed as a series of probes lying on a user-defined curve) are handled as a point mesh, which can be associated with plot and time_plot 2D-plot writers, as well as any of the general (3D-output) writer types (the priviledged writer types being plot for a profile, and time_plot for other probes).
Probe sets may be defined using the cs_probe_set_create_from_array function. In some cases, it might be useful to define those in multiple stages, using first cs_probe_set_create then a series of calls to cs_probe_set_add_probe.
The following example shows how probes may be added using that function.
cs_probe_set_t *pset = cs_probe_set_create("Monitoring");
cs_probe_set_add_probe(pset, 0.25, 0.025, 0.025, "M1");
cs_probe_set_add_probe(pset, 0.50, 0.025, 0.025, "M2");
cs_probe_set_add_probe(pset, 0.75, 0.025, 0.025, "M3");
cs_probe_set_t * cs_probe_set_create(const char *name)
Create a new set of probes.
Definition: cs_probe.c:947
void cs_probe_set_add_probe(cs_probe_set_t *pset, cs_real_t x, cs_real_t y, cs_real_t z, const char *label)
Add a new probe to an existing set of probes.
Definition: cs_probe.c:971
struct _cs_probe_set_t cs_probe_set_t
Definition: cs_probe.h:53
The same set could also be defined using predifined arrays:
const cs_real_t coords[][3] = {{0.25, 0.025, 0.025},
{0.50, 0.025, 0.025},
{0.75, 0.025, 0.025}};
const char *labels[] = {"M1", "M2", "M3"};
3,
coords,
labels);
Definition: cs_defs.h:319
cs_probe_set_t * cs_probe_set_create_from_array(const char *name, int n_probes, const cs_real_3_t *coords, const char **labels)
Define a new set of probes from an array of coordinates.
Definition: cs_probe.c:1019
In both cases, labels are optional (NULL may be used instead).
Probe set creation functions return a pointer to a cs_probe_set_t structure which can be used to specify additional options using the cs_probe_set_option function.
A writer (id = CS_POST_WRITER_PROBES) using the format "time_plot" is associated by default to a set of monitoring probes. This is not the case for profiles.
Profiles are special probe sets, for which a curvilinear coordinate is usually provided (or deduced, when cs_probe_set_create_from_segment or cs_probe_set_create_from_local construction function is used). Curvilinear coordinates may also be assigned to probe sets generated using cs_probe_set_create or cs_probe_set_create_from_array by using the cs_probe_set_assign_curvilinear_abscissa function.
Instead of being assigned by default to a time plot, profiles are generally used with writers using the "plot" format (with a "dat" or "csv" sub-option). Instead of using one file per variable with one column per point and one line per output time, this produces one file pour output time, with une column per variable and one line per point. But they may also be used with time plots (as a regular probe set), or as with any post-processing output mesh, with 3D formats such as EnSight or MED.
The following example shows how to simply define a profile on a given segment, and associate it to writer 2:
cs_coord_3_t start = {0., 0.025, 0.025};
cs_coord_3_t end = {1., 0.025, 0.025};
int writer_ids[] = {2};
11, // n_probes
start, // start coordinates
end); // end coordinates
cs_probe_set_associate_writers(pset, 1, writer_ids);
cs_coord_t cs_coord_3_t[3]
Definition: cs_defs.h:328
cs_probe_set_t * cs_probe_set_create_from_segment(const char *name, int n_probes, const cs_real_t start_coords[3], const cs_real_t end_coords[3])
Define a new set of probes from the segment spanned by two points.
Definition: cs_probe.c:1068
void cs_probe_set_associate_writers(cs_probe_set_t *pset, int n_writers, const int *writer_ids)
Associate a list of writers to a probe set.
Definition: cs_probe.c:1254
Probe sets (including profiles) may also be located along the domain boundary, if this is specified. In the following example, we set the "boundary" option to "true" to specify that the probes should be located on the boundary instead of the default volume mesh. We could also set a "criteria" option to define a selection filter for the portion of the mesh in which probes should be located (by default, the whole mesh).
Here We also choose to "snap" the points to the nearest vertices. Snapping probes to cell centers or vertices is useful mainly when the values to plot are located on those points.
cs_coord_3_t start = {0., 0., 0.};
cs_coord_3_t end = {1., 0., 0.};
11, // n_probes
cs_probe_set_option(pset, "boundary", "true");
void cs_probe_set_option(cs_probe_set_t *pset, const char *keyname, const char *keyval)
Set optional parameters related to the management of a set of probes.
Definition: cs_probe.c:1434
void cs_probe_set_snap_mode(cs_probe_set_t *pset, cs_probe_snap_t snap_mode)
Set snap mode related to the management of a set of probes.
Definition: cs_probe.c:1398
@ CS_PROBE_SNAP_VERTEX
Definition: cs_probe.h:59
Defining output on a probe set
To select a specific set of fields to output with a given probe set or profile, the cs_probe_set_associate_field function may be used. It allows specifying whether the output relates to all associated writers or specific ones, and for multidimensional fields, allows selecting specific components (comp_id = -1 for all components, or the (0 to n-1)-th component if filtering is desired.
This is used in general for probe sets whose "automatic" variables output is turned off (using cs_probe_set_auto_var), though it can be used to extend that glob setting.
Finally, the user may choose to output the curvilinear coordinates associated with a profile and/or the point coordinates, using the cs_probe_set_auto_curvilinear_coords and cs_probe_set_auto_cartesian_coords respectively, since these are not output by default.
This last example illustrates a combination of those possibilities:
11, // n_probes
Advanced profile definitions
As with regular meshes, profiles may be defined using user functions.
Definition of a series of profiles
In this example, we define a series of profiles. To avoid redundant code, an array defining both the name of each profile and the matching x coordinate (as a text string) is defined. The code then loops along these array values to define the series:
const char *line_defs[]
= {"-5.87", "buicesat-6",
"2.59", "buicesat03",
"5.98", "buicesat06",
"12.75", "buicesat13",
"13.56", "buicesat14",
"16.14", "buicesat16",
"16.93", "buicesat17",
"19.53", "buicesat19",
"20.32", "buicesat20",
"22.91", "buicesat23",
"23.71", "buicesat24",
"26.3", "buicesat26",
"27.09", "buicesat27",
"29.69", "buicesat29",
"30.48", "buicesat30",
"33.07", "buicesat33",
"33.87", "buicesat34",
"39.85", "buicesat40",
"46.62", "buicesat47",
"53.39", "buicesat53",
"60.17", "buicesat60",
"66.94", "buicesat67",
"73.71", "buicesat74"};
for (int i = 0; i < 23; i++) {
/* Define profiles */
const cs_real_t x = atof(line_defs[i*2]);
const cs_real_t start_coords[3] = {x, 0.1, 0.05};
const cs_real_t end_coords[3] = {x, -5, 0.05};
-1, /* Automatic sampling */
start_coords,
end_coords);
/* Associate writers */
const int writer_ids[] = {CS_POST_WRITER_PROFILES};
#define CS_POST_WRITER_PROFILES
Definition: cs_post.h:74
Boundary profiles
Probes and profiles may also be associated to the mesh boundary.
In the following example, a profile is defined based on a mesh boundary selection criterion, using the predefined cs_b_face_criterion_probes_define (which assumes curvilinear coordinates based on the "x" direction):
= cs_probe_set_create_from_local("foil_profile", /* probes set name */
/* probe def. function */
(void *)"FOIL_WALL"); /* input */
/* Indicate that the probes are located on the boundary */
/* Associate profile writer to this probes set */
void cs_b_face_criterion_probes_define(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s)
Define a profile based on centers of faces defined by a given criterion.
Definition: cs_post_util.c:274
cs_probe_set_t * cs_probe_set_create_from_local(const char *name, cs_probe_set_define_local_t *p_define_func, void *p_define_input)
Define a new set of probes from rank-local definition function.
Definition: cs_probe.c:1157
and in the below example using an array of 2 selection criteria:
static const char *wall_defs[]
= {"UP", "buicstr",
"DOWN", "buicinc"};
for (int i = 0; i < 2; i++) {
= cs_probe_set_create_from_local(wall_defs[i*2+1],
_b_face_criterion_probes_define,
(void *)wall_defs[i*2]); /* input */
In this example, we provide a local selection function (which may be defined in the private function definitions section near the beginning of the file) and whose code is shown below:
static void
cs_lnum_t *n_elts,
cs_real_t **s)
const char *criterion = (const char *)input;
const cs_mesh_t *m = cs_glob_mesh;
cs_lnum_t n_faces;
cs_lnum_t *face_ids;
BFT_MALLOC(face_ids, m->n_b_faces, cs_lnum_t);
cs_selector_get_b_face_list(criterion, &n_faces, face_ids);
cs_real_3_t *_coords;
cs_real_t *_s;
BFT_MALLOC(_coords, n_faces, cs_real_3_t);
BFT_MALLOC(_s, n_faces, cs_real_t);
for (cs_lnum_t i = 0; i < n_faces; i++) {
for (cs_lnum_t j = 0; j < 3; j++)
_coords[i][j] = mq->b_face_cog[face_ids[i]*3 + j];
_s[i] = _coords[i][0];
BFT_FREE(face_ids);
/* Set return values */
*n_elts = n_faces;
*coords = _coords;
*s = _s;
Definition: bft_mem.h:62
#define BFT_FREE(_ptr)
Free allocated memory.
Definition: bft_mem.h:101
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
Definition: cs_defs.h:313
cs_mesh_t * cs_glob_mesh
void cs_selector_get_b_face_list(const char *criteria, cs_lnum_t *n_b_faces, cs_lnum_t b_face_list[])
Fill a list of boundary faces verifying a given selection criteria.
Definition: cs_selector.c:213
cs_real_t * b_face_cog
Definition: cs_mesh_quantities.h:111
Definition: cs_mesh.h:85
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
