8.0
Advanced management of output times
By default, a post-processing frequency is defined for each writer, as defined using the GUI or through the cs_user_postprocess_writers function. For each writer, the user may define if an output is automatically generated at the end of the calculation, even if the last time step is not a multiple of the required time step number of physical time.
For finer control, the cs_user_postprocess_activate function file may be used to specify when post-processing outputs will be generated, overriding the default behavior.
In the following example, all output is deactivated until time step 1000 is reached, at which time the normal behavior resumes:
if (nt_max_abs < 1000) {
int writer_id = 0; /* 0: all writers */
cs_post_activate_writer(writer_id, false);
void cs_post_activate_writer(int writer_id, bool activate)
Force the "active" or "inactive" flag for a specific writer or for all writers for the current time s...
Definition: cs_post.c:5620
