L2 time residuals of a variable at a given time step are a relative measure of the unsteady term of its transport equation:
bool cved = true;
if (cved) {
Definition: bft_printf.c:140
Definition: cs_defs.h:319
Definition: cs_field.c:2316
int cs_field_n_fields(void)
Definition: cs_field.c:1527
Definition: cs_field.c:2570
const void * cs_field_get_key_struct(const cs_field_t *f, const int key_id, void *s)
Return a structure for a given key associated with a field.
Definition: cs_field.c:3487
cs_time_step_t * cs_get_glob_time_step(void)
Provide read/write access to cs_glob_time_step.
Definition: cs_time_step.c:433
#define CS_FIELD_VARIABLE
Definition: cs_field.h:63
Definition: cs_field.h:130
int type
Definition: cs_field.h:135
Definition: cs_parameters.h:68
double l2residual
Definition: cs_parameters.h:73
time step descriptor
Definition: cs_time_step.h:64
int nt_cur
Definition: cs_time_step.h:74
int nt_max
Definition: cs_time_step.h:75
