8.0
Cooling tower parameters definition
Activate the cooling tower module
As with other predefined physical models, the cooling tower module may be activated by setting the matching value in cs_glob_physical_model_flag, in the cs_user_model function (cs_user_parameters.c):
int cs_glob_physical_model_flag[CS_N_PHYSICAL_MODEL_TYPES]
Definition: cs_physical_model.c:108
@ CS_COOLING_TOWERS
Definition: cs_physical_model.h:74
Define exchange zones
Cooling tower exchange zones and their parameters may be defined in the general cs_user_parameters function (cs_user_parameters.c).
The following code block shows an example of definition of a cooling tower exchange zone.
/* Evaporation model:
CS_CTWR_NONE None,
CS_CTWR_POPPE Poppe,
CS_CTWR_MERKEL Merkel*/
cs_real_t surface = 0.48 * 6540.; /* 48% of the total disc */
cs_real_t qw = surface * 2.64; /* Water flow rate (kg/s) */
"2 or 3", /* selction criterion */
CS_CTWR_COUNTER_CURRENT counter current,
CS_CTWR_CROSS_CURRENT cross,
CS_CTWR_RAIN rain zone */
-1., /* Imposed delta temperature if positive */
0.1, /* Associated relaxation time */
36., /* Liquid injected water temperature */
qw,
0.2, /* Evaportaion law constant A */
0.5, /* Evaportaion law constant n */
surface,
-1.); /* Leaking factor, not taken into account if negative */
cs_ctwr_option_t * cs_get_glob_ctwr_option(void)
Definition: cs_ctwr.c:327
void cs_ctwr_define(const char zone_criteria[], cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac)
Define a cooling tower exchange zone.
Definition: cs_ctwr.c:351
@ CS_CTWR_COUNTER_CURRENT
Definition: cs_ctwr.h:77
@ CS_CTWR_POPPE
Definition: cs_ctwr.h:68
Definition: cs_defs.h:319
double precision, dimension(:,:,:), allocatable qw
Definition: atimbr.f90:109
Definition: cs_ctwr.h:92
int evap_model
Definition: cs_ctwr.h:93
