8.0
cs_turbulence_kw.h
1 #ifndef __CS_TURBULENCE_KW_H__
2 #define __CS_TURBULENCE_KW_H__
5  * k-w turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
61 /*----------------------------------------------------------------------------*/
62
63 void
65  cs_lnum_t icetsm[],
66  int itypsm[],
67  const cs_real_t dt[],
68  cs_real_t smacel[]);
69
70 /*----------------------------------------------------------------------------*/
87 /*----------------------------------------------------------------------------*/
88
89 void
91
92 /*----------------------------------------------------------------------------*/
93
95
96 #endif /* __CS_TURBULENCE_KW_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
@ dt
void cs_turbulence_kw_mu_t(void)
Calculation of turbulent viscosity for the SST model.
Definition: cs_turbulence_kw.c:1694
void cs_turbulence_kw(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[])
Solve the k-omega equations.
Definition: cs_turbulence_kw.c:137
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:192
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:207
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:201
