8.0
cs_sys_coupling.h
1 #ifndef __CS_SYS_COUPLING_H__
2 #define __CS_SYS_COUPLING_H__
5  * SYSTEM Scale code coupling (0D/1D equations)
29  * Local headers
32 #include "cs_base.h"
33 #include "cs_zone.h"
34
35 /*----------------------------------------------------------------------------*/
36
38
39 typedef enum
40 {
45
50
51 typedef struct {
52
53  // Intersection (surface/volume)
54  int *n_elts; // Number of intersected sys elts for each CFD elt
55  cs_double_int_t **elt_ids_val; // Surface/Volume intersected (absolute!) + id
56
57  cs_real_t *cfd_weight; // Total weight for cfd elements
58  cs_real_t *sys_weight; // Total weight for sys elements
59
61
62 typedef struct {
63
64  // Coupling type
66
67  // Coupling zones. If in/out are different both are used, otherwise only
68  // first.
70
72
73  // Inverse flow rate (normal) if necessary
74  int bnd_dir;
75
76  // Surface coefficient used for symmetrical cases.
78
79  // Fields to send
82
83  // Fields to send
86
87  // Number of elements in system code
88  int n_sys_elts; // 1 For 0D, > 1 for a 1D element
89  cs_cfd2sys_intersection_t *im; // NULL for 0D, !=NULL for a 1D element
90
91  // System element identification
92  char *element_name;
93  int sys_elt_idx[2];
94
96
97 typedef struct {
98
99  // ---------------------------
100  // MPI Parameters
101 #if defined(HAVE_MPI)
102  MPI_Comm comm;
103 #endif
104
105  int cfd_root;
106  int sys_root;
108  // ---------------------------
109
110  // ---------------------------
111  // Coupling zones
114  // ---------------------------
115
116  // ---------------------------
117  // send/recv arrays
122  // ---------------------------
123
124  // ---------------------------
125  // Number of coupled phases
127  // ---------------------------
128
129  // ---------------------------
130  // system code instance
131  char *sys_name;
132  // ---------------------------
133
134 } cs_sys_cpl_t;
135
136 /*============================================================================
137  * Public function definitions
138  *============================================================================*/
139
140 /*----------------------------------------------------------------------------*/
148 /*----------------------------------------------------------------------------*/
149
150 cs_sys_cpl_t *
151 cs_sys_coupling_by_id(const int cpl_id);
152
153 /*----------------------------------------------------------------------------*/
161 /*----------------------------------------------------------------------------*/
162
163 cs_sys_cpl_t *
164 cs_sys_coupling_by_name_try(const char *sys_name);
165
166 /*----------------------------------------------------------------------------*/
174 /*----------------------------------------------------------------------------*/
175
176 cs_sys_cpl_t *
177 cs_sys_coupling_by_name(const char *sys_name);
178
179 /*----------------------------------------------------------------------------*/
186 /*----------------------------------------------------------------------------*/
187
188 void
190  const int field_id);
191
192 /*----------------------------------------------------------------------------*/
199 /*----------------------------------------------------------------------------*/
200
201 void
203  const int field_id);
204
205 /*----------------------------------------------------------------------------*/
212 /*----------------------------------------------------------------------------*/
213
214 void
216  const cs_real_t coeff);
217
218 /*----------------------------------------------------------------------------*/
225 /*----------------------------------------------------------------------------*/
226
227 void
229
230 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 void
242  const int dir,
243  const int field_id);
244
245 /*----------------------------------------------------------------------------*/
258 /*----------------------------------------------------------------------------*/
259
260 void
262  cs_syscpl_bc_type_t type,
263  const cs_zone_t *z_input,
264  const char *sel_criteria_output,
265  const char *element_name,
266  const int c0,
267  const int c1,
268  const int n_sys_elts);
269
270 /*----------------------------------------------------------------------------*/
279 /*----------------------------------------------------------------------------*/
280
281 int
282 cs_sys_coupling_add(const char *sys_name,
283  const int n_cpl_phases);
284
285 /*----------------------------------------------------------------------------*/
291 /*----------------------------------------------------------------------------*/
292
293 void
295
296 /*----------------------------------------------------------------------------*/
302 /*----------------------------------------------------------------------------*/
303
304 void
306
307 /*----------------------------------------------------------------------------*/
311 /*----------------------------------------------------------------------------*/
312
313 void
315
316 /*----------------------------------------------------------------------------*/
320 /*----------------------------------------------------------------------------*/
321
322 void
324
325 /*----------------------------------------------------------------------------*/
326
328
329 #endif /* __CS_SYS_COUPLING_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_syscpl_bc_type_t
Definition: cs_sys_coupling.h:40
@ CS_SYS_CPL_BC_UKNOWN
Definition: cs_sys_coupling.h:48
@ CS_SYS_CPL_BC_VOLUME
Definition: cs_sys_coupling.h:44
@ CS_SYS_CPL_BC_WALL
Definition: cs_sys_coupling.h:43
@ CS_SYS_CPL_BC_INLET
Definition: cs_sys_coupling.h:41
@ CS_N_SYS_CPL_BC_TYPES
Definition: cs_sys_coupling.h:46
@ CS_SYS_CPL_BC_OUTLET
Definition: cs_sys_coupling.h:42
void cs_sys_cplbc_add_exchanged_field(cs_cfd_sys_cplbc_t *cplbc, const int dir, const int field_id)
Add a field to send/recv during coupling to a given coupled BC.
Definition: cs_sys_coupling.c:729
cs_sys_cpl_t * cs_sys_coupling_by_name_try(const char *sys_name)
Try getting a cfd<-->sys coupling structure by its name.
Definition: cs_sys_coupling.c:596
void cs_sys_coupling_all_init(void)
Initialize cfd<->system coupling once all couplings are defined.
Definition: cs_sys_coupling.c:933
void cs_sys_coupling_add_cplbc(cs_sys_cpl_t *sys_coupling, cs_syscpl_bc_type_t type, const cs_zone_t *z_input, const char *sel_criteria_output, const char *element_name, const int c0, const int c1, const int n_sys_elts)
Add a coupled condition to a cfd<-->sys coupling.
Definition: cs_sys_coupling.c:783
void cs_sys_cplbc_define_surf_coeff(cs_cfd_sys_cplbc_t *cplbc, const cs_real_t coeff)
Define a surface coefficient to a given coupled BC.
Definition: cs_sys_coupling.c:693
void cs_sys_cplbc_inverse_bnd_dir(cs_cfd_sys_cplbc_t *cplbc)
Define a flowrate inversion between CFD and System codes if signs are inversed for a given coupled BC...
Definition: cs_sys_coupling.c:711
cs_sys_cpl_t * cs_sys_coupling_by_id(const int cpl_id)
Get a cfd<-->sys coupling structure by its id.
Definition: cs_sys_coupling.c:569
void cs_sys_cplbc_add_field_to_recv(cs_cfd_sys_cplbc_t *cplbc, const int field_id)
Add a field to recieve during coupling to a given coupled BC.
Definition: cs_sys_coupling.c:670
void cs_sys_coupling_recv_data(cs_sys_cpl_t *cpl)
recieve data from system code
Definition: cs_sys_coupling.c:900
int cs_sys_coupling_add(const char *sys_name, const int n_cpl_phases)
Add a cfd<->sys coupling.
Definition: cs_sys_coupling.c:842
void cs_sys_coupling_all_finalize(void)
Finalize all cfd<->sys couplings.
Definition: cs_sys_coupling.c:978
void cs_sys_cplbc_add_field_to_send(cs_cfd_sys_cplbc_t *cplbc, const int field_id)
Add a field to send during coupling to a given coupled BC.
Definition: cs_sys_coupling.c:647
void cs_sys_coupling_send_data(cs_sys_cpl_t *cpl)
send data to system code
Definition: cs_sys_coupling.c:876
cs_sys_cpl_t * cs_sys_coupling_by_name(const char *sys_name)
Get a cfd<-->sys coupling structure by its name.
Definition: cs_sys_coupling.c:625
double precision, dimension(ncharm), save c1
Definition: cpincl.f90:233
Definition: cs_sys_coupling.h:51
cs_real_t * sys_weight
Definition: cs_sys_coupling.h:58
int * n_elts
Definition: cs_sys_coupling.h:54
cs_real_t * cfd_weight
Definition: cs_sys_coupling.h:57
cs_double_int_t ** elt_ids_val
Definition: cs_sys_coupling.h:55
Definition: cs_sys_coupling.h:62
cs_cfd2sys_intersection_t * im
Definition: cs_sys_coupling.h:89
int * send_field_ids
Definition: cs_sys_coupling.h:81
int input_zone_id
Definition: cs_sys_coupling.h:69
int n_send_fields
Definition: cs_sys_coupling.h:80
int n_recv_fields
Definition: cs_sys_coupling.h:84
cs_real_t surf_coeff
Definition: cs_sys_coupling.h:77
char * selection_criteria_output
Definition: cs_sys_coupling.h:71
char * element_name
Definition: cs_sys_coupling.h:92
int n_sys_elts
Definition: cs_sys_coupling.h:88
Definition: cs_sys_coupling.h:65
int bnd_dir
Definition: cs_sys_coupling.h:74
int * recv_field_ids
Definition: cs_sys_coupling.h:85
Definition: cs_defs.h:358
Definition: cs_sys_coupling.h:97
int sys_root
Definition: cs_sys_coupling.h:106
int cfd_root
Definition: cs_sys_coupling.h:105
int sys_n_ranks
Definition: cs_sys_coupling.h:107
int n_cpl_phases
Definition: cs_sys_coupling.h:126
int n_cpl_bcs
Definition: cs_sys_coupling.h:112
cs_cfd_sys_cplbc_t ** cplbc
Definition: cs_sys_coupling.h:113
int n_recv_vals
Definition: cs_sys_coupling.h:120
char * sys_name
Definition: cs_sys_coupling.h:131
cs_real_t * send_vals
Definition: cs_sys_coupling.h:119
MPI_Comm comm
Definition: cs_sys_coupling.h:102
cs_real_t * recv_vals
Definition: cs_sys_coupling.h:121
int n_send_vals
Definition: cs_sys_coupling.h:118
Definition: cs_zone.h:55
