8.0
cs_sles_pc_cuda.h
1 #ifndef __CS_SLES_PC_CUDA_H__
2 #define __CS_SLES_PC_CUDA_H__
5  * Sparse Linear Equation Solver Preconditioners using CUDA
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_matrix.h"
36 #include "cs_sles.h"
37 #include "cs_sles_pc.h"
38
44  * Macro definitions
46
48  * Type definitions
50
52  * Global variables
54
56  * User function prototypes
58
59 /*=============================================================================
60  * Public function prototypes
62
63 /*----------------------------------------------------------------------------
64  * Function for application of a null-preconditioner.
65  *
66  * In cases where it is desired that the preconditioner modify a vector
67  * "in place", x_in should be set to NULL, and x_out contain the vector to
68  * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
69  *
70  * parameters:
71  * context <-> pointer to preconditioner context
72  * x_in <-- input vector
73  * x_out <-> input/output vector
74  *
75  * returns:
76  * preconditioner application status
77  *----------------------------------------------------------------------------*/
78
81  const cs_real_t *x_in,
82  cs_real_t *x_out);
83
84 /*----------------------------------------------------------------------------
85  * Function for application of a Jacobi preconditioner.
86  *
87  * In cases where it is desired that the preconditioner modify a vector
88  * "in place", x_in should be set to NULL, and x_out contain the vector to
89  * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
90  *
91  * parameters:
92  * context <-> pointer to preconditioner context
93  * x_in <-- input vector
94  * x_out <-> input/output vector
95  *
96  * returns:
97  * preconditioner application status
98  *----------------------------------------------------------------------------*/
99
102  const cs_real_t *x_in,
103  cs_real_t *x_out);
104
105 /*----------------------------------------------------------------------------
106  * Function for application of a polynomial preconditioner.
107  *
108  * In cases where it is desired that the preconditioner modify a vector
109  * "in place", x_in should be set to NULL, and x_out contain the vector to
110  * be modified (\f$x_{out} \leftarrow M^{-1}x_{out})\f$).
111  *
112  * parameters:
113  * context <-> pointer to preconditioner context
114  * x_in <-- input vector
115  * x_out <-> input/output vector
116  *
117  * returns:
118  * preconditioner application status
119  *----------------------------------------------------------------------------*/
120
123  const cs_real_t *x_in,
124  cs_real_t *x_out);
125
126 /*----------------------------------------------------------------------------*/
127
129
130 #endif /* __CS_SLES_PC_CUDA_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_sles_pc_state_t
Definition: cs_sles_pc.h:55
cs_sles_pc_state_t cs_sles_pc_cuda_apply_jacobi(void *context, const cs_real_t *x_in, cs_real_t *x_out)
cs_sles_pc_state_t cs_sles_pc_cuda_apply_none(void *context, const cs_real_t *x_in, cs_real_t *x_out)
cs_sles_pc_state_t cs_sles_pc_cuda_apply_poly(void *context, const cs_real_t *x_in, cs_real_t *x_out)
