8.0
cs_pressure_correction.h
1 #ifndef __CS_PRESSURE_CORRECTION_H__
2 #define __CS_PRESSURE_CORRECTION_H__
5  * Pressure correction.
31  * Local headers
34 #include "cs_defs.h"
41  * Type definitions
44 typedef struct {
45
50
56
61
67
72
77
83
85
87
88 /*============================================================================
89  * Public function definitions
90  *============================================================================*/
91
92 /*----------------------------------------------------------------------------*/
96 /*----------------------------------------------------------------------------*/
97
98 void
100
101 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
107 void
109
110
111 /*----------------------------------------------------------------------------*/
115 /*----------------------------------------------------------------------------*/
116
117 void
119
120 /*----------------------------------------------------------------------------*/
124 /*----------------------------------------------------------------------------*/
125
126 void
128
129 /*----------------------------------------------------------------------------*/
135 /*----------------------------------------------------------------------------*/
136
137 bool
139
140 /*----------------------------------------------------------------------------*/
147
148 void
150
151 /*----------------------------------------------------------------------------*/
158 /*----------------------------------------------------------------------------*/
159
160 void
162
163 /*----------------------------------------------------------------------------*/
206 /*----------------------------------------------------------------------------*/
207
208 void
209 cs_pressure_correction(int iterns,
213  cs_lnum_t ltmast[],
214  int isostd[],
215  cs_real_t vel[restrict][3],
216  cs_real_t da_uu[restrict][6],
217  cs_real_t coefav[restrict][3],
218  cs_real_t coefbv[restrict][3][3],
219  cs_real_t coefa_dp[restrict],
220  cs_real_t coefb_dp[restrict],
223  cs_real_t frcxt[restrict][3],
224  cs_real_t dfrcxt[restrict][3],
225  cs_real_t i_visc[restrict],
226  cs_real_t b_visc[restrict]);
227
228 /*----------------------------------------------------------------------------*/
229
231
232 #endif /* __CS_PRESSURE_CORRECTION_H__ */
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
@ vel
void cs_pressure_correction_cdo_activate(void)
Activate the pressure increment solving with CDO.
Definition: cs_pressure_correction.c:2952
void cs_pressure_correction_cdo_destroy_all(void)
Free the main structure related to the pressure correction.
Definition: cs_pressure_correction.c:3186
bool cs_pressure_correction_cdo_is_activated(void)
Test if pressure solving with CDO is activated.
Definition: cs_pressure_correction.c:3027
void cs_pressure_correction(int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[nfbpcd], cs_lnum_t ltmast[], int isostd[], cs_real_t vel[restrict][3], cs_real_t da_uu[restrict][6], cs_real_t coefav[restrict][3], cs_real_t coefbv[restrict][3][3], cs_real_t coefa_dp[restrict], cs_real_t coefb_dp[restrict], cs_real_t spcond[restrict], cs_real_t svcond[restrict], cs_real_t frcxt[restrict][3], cs_real_t dfrcxt[restrict][3], cs_real_t i_visc[restrict], cs_real_t b_visc[restrict])
Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly co...
Definition: cs_pressure_correction.c:3261
void cs_pressure_correction_fv_activate(void)
Activate the pressure increment solving with Legacy FV.
Definition: cs_pressure_correction.c:2926
void cs_pressure_correction_cdo_init_setup(void)
Start setting-up the pressure increment equation At this stage, numerical settings should be complete...
Definition: cs_pressure_correction.c:3044
void cs_pressure_correction_cdo_finalize_setup(const cs_domain_t *domain)
Finalize setting-up the pressure increment equation At this stage, numerical settings should be compl...
Definition: cs_pressure_correction.c:3113
void cs_pressure_correction_model_activate(void)
Activate the pressure increment, either FV or CDO.
Definition: cs_pressure_correction.c:3007
integer, save ncmast
number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the ...
Definition: pointe.f90:218
integer, dimension(:), allocatable ltmast
list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_...
Definition: pointe.f90:222
double precision, dimension(:,:), allocatable svcond
value of the condensation source terms for pressure associated to the metal structures modelling....
Definition: pointe.f90:238
integer(c_int), pointer, save nfbpcd
number of faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine c...
Definition: cs_nz_condensation.f90:55
double precision, dimension(:,:), pointer, save spcond
value of the condensation source terms for pressure. For the other variables, eventual imposed specif...
Definition: cs_nz_condensation.f90:83
integer, dimension(:), pointer, save ifbpcd
list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user sub...
Definition: cs_nz_condensation.f90:95
Definition: cs_domain.h:138
Definition: cs_field.h:130
Definition: cs_pressure_correction.h:44
cs_flag_t post_flag
Definition: cs_pressure_correction.h:84
cs_equation_t * pressure_incr
Definition: cs_pressure_correction.h:49
cs_field_t * pressure_incr_gradient
Definition: cs_pressure_correction.h:55
cs_real_t * bdy_pressure_incr
Definition: cs_pressure_correction.h:82
cs_field_t * pressure_gradient
Definition: cs_pressure_correction.h:60
cs_real_t * div_st
Definition: cs_pressure_correction.h:66
cs_real_t * inner_potential_flux
Definition: cs_pressure_correction.h:71
cs_real_t * bdy_potential_flux
Definition: cs_pressure_correction.h:76
