8.0
cs_parameters_check.h
1 #ifndef __CS_PARAMETERS_CHECK_H__
2 #define __CS_PARAMETERS_CHECK_H__
5  * Log field and other array statistics at relevant time steps.
35  * Local headers
38 #include "cs_base.h"
45  * type definitions
48 /* Parameter check behavior when an error is detected */
49
50 typedef enum {
51
55
57
61
73
74 #if defined(__GNUC__)
75
76 void
78  const char *section_desc,
79  const char *format,
80  ...)
81  __attribute__((format(printf, 3, 4)));
82
83 #else
84
85 void
87  const char *section_desc,
88  const char *format,
89  ...);
90
91 #endif
92
93 /*----------------------------------------------------------------------------*/
103 /*----------------------------------------------------------------------------*/
104
105 void
107  const char *section_desc,
108  const char *format,
109  ...);
110
111 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
121 void
123  const char *section_desc);
124
125 /*----------------------------------------------------------------------------*/
131 /*----------------------------------------------------------------------------*/
132
133 void
135
136 /*----------------------------------------------------------------------------*/
148 /*----------------------------------------------------------------------------*/
149
150 void
152  const char *section_desc,
153  const char *param_name,
154  int param_value,
155  int range_l,
156  int range_u);
157
158 /*----------------------------------------------------------------------------*/
171 /*----------------------------------------------------------------------------*/
172
173 void
175  const char *section_desc,
176  const char *param_name,
177  int param_value,
178  int range_l,
179  int range_u);
180
181 /*----------------------------------------------------------------------------*/
195 /*----------------------------------------------------------------------------*/
196
197 void
199  const char *section_desc,
200  const char *param_name,
201  int param_value,
202  int enum_size,
203  const int *enum_values,
204  const char *enum_names[]);
205
206 /*----------------------------------------------------------------------------*/
221 /*----------------------------------------------------------------------------*/
222
223 void
225  const char *section_desc,
226  const char *param_name,
227  int param_value,
228  int enum_size,
229  const int *enum_values,
230  const char *enum_names[]);
231
232 /*----------------------------------------------------------------------------*/
243 /*----------------------------------------------------------------------------*/
244
245 void
247  const char *section_desc,
248  const char *param_name,
249  int param_value,
250  int std_value);
251
263 /*----------------------------------------------------------------------------*/
264
265 void
267  const char *section_desc,
268  const char *param_name,
269  int param_value,
270  int fbd_value);
271
272 /*----------------------------------------------------------------------------*/
282 /*----------------------------------------------------------------------------*/
283
284 void
286  const char *section_desc,
287  const char *param_name,
288  int param_value);
289
290 /*----------------------------------------------------------------------------*/
301 /*----------------------------------------------------------------------------*/
302
303 void
305  const char *section_desc,
306  const char *param_name,
307  int param_value,
308  int ib_value);
309
310 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
324 void
326  const char *section_desc,
327  const char *param_name,
328  double param_value,
329  double range_l,
330  double range_u);
331
332 /*----------------------------------------------------------------------------*/
345 /*----------------------------------------------------------------------------*/
346
347 void
349  const char *section_desc,
350  const char *param_name,
351  double param_value,
352  int enum_size,
353  const double *enum_values,
354  const char *enum_names[]);
355
356 /*----------------------------------------------------------------------------*/
367 /*----------------------------------------------------------------------------*/
368
369 void
371  const char *section_desc,
372  const char *param_name,
373  double param_value,
374  double std_value);
375
376 /*----------------------------------------------------------------------------*/
387 /*----------------------------------------------------------------------------*/
388
389 void
391  const char *section_desc,
392  const char *param_name,
393  double param_value,
394  double ib_value);
395
396 /*----------------------------------------------------------------------------*/
400 /*----------------------------------------------------------------------------*/
401
402 void
404
405 /*----------------------------------------------------------------------------
406 !
407  * \brief Check data settings
408  */
409 /*----------------------------------------------------------------------------*/
410
411 void
412 cs_parameters_check(void);
413
414 /*----------------------------------------------------------------------------*/
415
417
418 #endif /* __CS_PARAMETERS_CHECK_H__ */
Definition: cs_defs.h:509
void cs_parameters_is_not_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int fbd_value)
Check that a given integer keyword is not equal to a specified value.
Definition: cs_parameters_check.c:517
void cs_parameters_error_footer(cs_parameter_error_behavior_t err_behavior)
Print footer for a given parameters error message type.
Definition: cs_parameters_check.c:236
void cs_parameters_is_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int std_value)
Check that a given integer keyword is equal to a specified value.
Definition: cs_parameters_check.c:475
void cs_parameters_error_barrier(void)
Abort if the the parameter errors count is nonzero.
Definition: cs_parameters_check.c:786
void cs_parameters_is_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has values in a specified range.
Definition: cs_parameters_check.c:259
Definition: cs_parameters_check.h:50
@ CS_WARNING
Definition: cs_parameters_check.h:52
@ CS_ABORT_DELAYED
Definition: cs_parameters_check.h:53
@ CS_ABORT_IMMEDIATE
Definition: cs_parameters_check.h:54
void cs_parameters_is_positive_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value)
Check that a given integer keyword is strictly positive.
Definition: cs_parameters_check.c:551
void cs_parameters_is_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Definition: cs_parameters_check.c:336
void cs_parameters_error(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *format,...)
Print general parameters error or warning info.
Definition: cs_parameters_check.c:169
void cs_parameters_is_in_list_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, int enum_size, const double *enum_values, const char *enum_names[])
Check that a given double keyword has values in a specified list.
Definition: cs_parameters_check.c:659
void cs_parameters_is_not_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Check that a given integer keyword does not have values in a specified list.
Definition: cs_parameters_check.c:405
void cs_parameters_is_equal_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double std_value)
Check that a given double keyword is equal to a specified value.
Definition: cs_parameters_check.c:716
void cs_parameters_is_greater_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double ib_value)
Check that a given double keyword is greater than a specified value.
Definition: cs_parameters_check.c:758
void cs_parameters_is_not_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has not values in a specified range.
Definition: cs_parameters_check.c:297
void cs_parameters_check(void)
Check computation parameters after user modification.
Definition: cs_parameters_check.c:810
void cs_parameters_is_in_range_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double range_l, double range_u)
Check that a given double keyword has values in a specified range.
Definition: cs_parameters_check.c:621
void cs_parameters_is_greater_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int ib_value)
Check that a given int keyword is greater than a specified value.
Definition: cs_parameters_check.c:585
void cs_parameters_error_header(cs_parameter_error_behavior_t err_behavior, const char *section_desc)
Print header for a given parameters error message type.
Definition: cs_parameters_check.c:199
