8.0
cs_param_cdo.h
1 #ifndef __CS_PARAM_CDO_H__
2 #define __CS_PARAM_CDO_H__
5  * High-level metadata related to CDO/HHO schemes
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
44 /* Specifications for OpenMP loops */
45
46 #define CS_CDO_OMP_CHUNK_SIZE 128
47 #define CS_CDO_OMP_SCHEDULE schedule(static, CS_CDO_OMP_CHUNK_SIZE)
48 #define CS_CDO_OMP_SYNC_SECTIONS 0 /* > 0 --> critical sections
49  otherwise atomic sections */
50
51 /* Avoid issues with assert in some OpenMp contructs using gcc 9 */
52
53 #if defined(HAVE_OPENMP) && defined(__GNUC__)
54  #if __GNUC__ == 9
55  #define CS_CDO_OMP_ASSERT(e)
56  #else
57  #define CS_CDO_OMP_ASSERT(e) assert(e)
58  #endif
59 #else
60  #define CS_CDO_OMP_ASSERT(e) assert(e)
61 #endif
62
63 /* Size of the buffer used to collect global ids for rows and columns
64  when assembling the values in the global matrix from the local cellwise
65  matrices */
66
67 #define CS_CDO_ASSEMBLE_BUF_SIZE 200
68
69 /* The following limitation only results from an optimization in the size of
70  the bit mask (can be changed if needed by changing the definition of
71  the type cs_mask_t)
72  Here is the max. number of reaction terms allowed in an equation */
73
74 #define CS_CDO_N_MAX_REACTIONS 8
75
76 #define CS_ALL_FACES 0 /* All faces: interior + border */
77 #define CS_BND_FACES 1 /* Boundary faces */
78 #define CS_INT_FACES 2 /* Interior faces */
79
80 /* HHO specific part:
81  *
82  * Number of DoFs on faces and cells according to the polynomial space
83  */
84
85 #define CS_N_DOFS_FACE_0TH 1
86 #define CS_N_DOFS_FACE_1ST 3
87 #define CS_N_DOFS_FACE_2ND 6
88
89 #define CS_N_DOFS_CELL_0TH 1
90 #define CS_N_DOFS_CELL_1ST 4
91 #define CS_N_DOFS_CELL_2ND 10
92
93 /*============================================================================
94  * Type definitions
95  *============================================================================*/
96
97 typedef enum {
98
99  CS_PARAM_CDO_MODE_OFF = -1, /* CDO schemes are not used */
100  CS_PARAM_CDO_MODE_WITH_FV = 1, /* CDO and legacy FV schemes are used */
101  CS_PARAM_CDO_MODE_ONLY = 2 /* Only CDO schemes are used */
102
104
105 /* OpenMP STRATEGY FOR THE ASSEMBLY STEP */
106 /* ===================================== */
107
108 typedef enum {
109
113
115
116 /*============================================================================
117  * Global variables
118  *============================================================================*/
119
121
122 /*============================================================================
123  * Public function prototypes
124  *============================================================================*/
125
126 /*----------------------------------------------------------------------------*/
131 /*----------------------------------------------------------------------------*/
132
133 void
135
136 /*----------------------------------------------------------------------------*/
142 /*----------------------------------------------------------------------------*/
143
146
147 /*----------------------------------------------------------------------------*/
151 /*----------------------------------------------------------------------------*/
152
153 void
154 cs_param_cdo_log(void);
155
156 /*----------------------------------------------------------------------------*/
157
159
160 #endif /* __CS_PARAM_CDO_H__ */
Definition: cs_defs.h:509
void cs_param_cdo_log(void)
Print a welcome message indicating what is the current CDO status.
Definition: cs_param_cdo.c:130
cs_param_assemble_omp_strategy_t
Definition: cs_param_cdo.h:107
@ CS_PARAM_ASSEMBLE_OMP_ATOMIC
Definition: cs_param_cdo.h:109
@ CS_PARAM_ASSEMBLE_OMP_CRITICAL
Definition: cs_param_cdo.h:110
@ CS_PARAM_ASSEMBLE_OMP_N_STRATEGIES
Definition: cs_param_cdo.h:111
cs_param_cdo_mode_t
Definition: cs_param_cdo.h:96
@ CS_PARAM_CDO_MODE_ONLY
Definition: cs_param_cdo.h:100
@ CS_PARAM_CDO_MODE_OFF
Definition: cs_param_cdo.h:98
@ CS_PARAM_CDO_MODE_WITH_FV
Definition: cs_param_cdo.h:99
cs_param_cdo_mode_t cs_glob_param_cdo_mode
cs_param_cdo_mode_t cs_param_cdo_mode_get(void)
Get the mode of activation for the CDO/HHO schemes.
Definition: cs_param_cdo.c:118
void cs_param_cdo_mode_set(cs_param_cdo_mode_t mode)
Set the global variable storing the mode of activation to apply to CDO/HHO schemes....
Definition: cs_param_cdo.c:103
