8.0
cs_les_balance.h
1 #ifndef __CS_LES_BALANCE_H__
2 #define __CS_LES_BALANCE_H__
5  * Filters for dynamic models.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_defs.h"
36
38
42  * Macro definitions
45 /* LES balance type masks */
46
48 #define CS_LES_BALANCE_RIJ (1 << 0)
49
51 #define CS_LES_BALANCE_RIJ_BASE (1 << 1)
52
54 #define CS_LES_BALANCE_RIJ_FULL (1 << 2)
55
57 #define CS_LES_BALANCE_TUI (1 << 3)
58
60 #define CS_LES_BALANCE_TUI_BASE (1 << 4)
61
63 #define CS_LES_BALANCE_TUI_FULL (1 << 5)
64
65 /*============================================================================
66  * Type definition
67  *============================================================================*/
68
69 /* Rij LES balance structure */
70 /*---------------------------*/
71
72 typedef struct {
73
74  /* Working arrays */
87
89
90 /* Tui LES balance structure */
91 /*---------------------------*/
92
93 typedef struct {
94
95  /* Field id */
96  int f_id;
97
98  /* Working arrays */
120
122
123 /* LES balance structure */
124 /*-----------------------*/
125
126 typedef struct {
127
129
131
133
134  int type;
135
137
139
140 /* Pointer to main LES balance structure */
142
143 /*=============================================================================
144  * Public function prototypes
145  *============================================================================*/
146
147 /*----------------------------------------------------------------------------
148  * Create fields used in LES balance computation
149  *----------------------------------------------------------------------------*/
150
151 void
153
154 /*----------------------------------------------------------------------------
155  * Provide access to cs_glob_les_balance.
156  *
157  * returns:
158  * pointer to LES balance global structure
159  *----------------------------------------------------------------------------*/
160
163
164 /*----------------------------------------------------------------------------
165  * Create a LES balance descriptor.
166  *----------------------------------------------------------------------------*/
167
168 void
170
171 /*----------------------------------------------------------------------------
172  * Update gradients needed in LES balance
173  *----------------------------------------------------------------------------*/
174
175 void
177
178 /*----------------------------------------------------------------------------
179  * Compute Rij LES balance.
180  *----------------------------------------------------------------------------*/
181
182 void
184
185 /*----------------------------------------------------------------------------
186  * Compute Tui LES balance.
187  *----------------------------------------------------------------------------*/
188
189 void
191
192 /*----------------------------------------------------------------------------
193  * Write the LES balance structure in the auxiliary restart file.
194  *----------------------------------------------------------------------------*/
195
196 void
198
199 /*----------------------------------------------------------------------------
200  * Destroy the LES balance structure.
201  *----------------------------------------------------------------------------*/
202
203 void
205
206 /*----------------------------------------------------------------------------
207  * Active the LES balance module.
208  *
209  * parameters:
210  * type_flag --> mask of LES balance type
211  * frequency_n --> balance computing frequency in time-steps
212  *----------------------------------------------------------------------------*/
213
214 void
215 cs_les_balance_activate(int type_flag,
216  int frequency_n);
217
218 /*----------------------------------------------------------------------------
219  * Compute the LES balance
220  *----------------------------------------------------------------------------*/
221
222 void
224
225 /*----------------------------------------------------------------------------*/
226
228
229 #endif /* __CS_LES_BALANCE_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_real_t cs_real_69_t[6][9]
Definition: cs_defs.h:351
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:334
void cs_les_balance_create_fields(void)
Definition: cs_les_balance.c:2668
void cs_les_balance_compute_rij(void)
Definition: cs_les_balance.c:2846
cs_les_balance_t * cs_get_glob_les_balance(void)
Definition: cs_les_balance.c:2738
cs_les_balance_t * cs_glob_les_balance
Definition: cs_les_balance.c:229
void cs_les_balance_create(void)
Definition: cs_les_balance.c:2750
void cs_les_balance_activate(int type_flag, int frequency_n)
Definition: cs_les_balance.c:3849
void cs_les_balance_write_restart(void)
Write the LES balance structure in the LES balance restart file.
Definition: cs_les_balance.c:3797
void cs_les_balance_update_gradients(void)
Update gradients needed in LES balance.
Definition: cs_les_balance.c:2834
void cs_les_balance_compute(void)
Compute the LES balance for Tui or Rij.
Definition: cs_les_balance.c:3866
void cs_les_balance_finalize(void)
Definition: cs_les_balance.c:3829
void cs_les_balance_compute_tui(void)
Definition: cs_les_balance.c:3276
Reynolds tensor (Rij) LES balance descriptor.
Definition: cs_les_balance.h:72
cs_real_6_t * convij
Definition: cs_les_balance.h:83
cs_real_6_t * prodij
Definition: cs_les_balance.h:77
cs_real_6_t * difftij
Definition: cs_les_balance.h:80
cs_real_t * smagp2
Definition: cs_les_balance.h:76
cs_real_69_t * budsgsfullij
Definition: cs_les_balance.h:86
cs_real_6_t * difflamij
Definition: cs_les_balance.h:84
cs_real_6_t * unstij
Definition: cs_les_balance.h:82
cs_real_6_t * budsgsij
Definition: cs_les_balance.h:85
cs_real_6_t * phiij
Definition: cs_les_balance.h:78
cs_real_6_t * difftpij
Definition: cs_les_balance.h:81
cs_real_t * pp2
Definition: cs_les_balance.h:75
cs_real_6_t * epsij
Definition: cs_les_balance.h:79
LES balance general options descriptor.
Definition: cs_les_balance.h:126
int frequency_n
Definition: cs_les_balance.h:136
cs_les_balance_tui_t ** btui
Definition: cs_les_balance.h:130
int type
Definition: cs_les_balance.h:134
cs_les_balance_rij_t * brij
Definition: cs_les_balance.h:128
int i_les_balance
Definition: cs_les_balance.h:132
Turbulent thermal flux vector (Tui) LES balance descriptor.
Definition: cs_les_balance.h:93
cs_real_3_t * epsti
Definition: cs_les_balance.h:112
cs_real_t * unstvar
Definition: cs_les_balance.h:99
cs_real_3_t * difftti
Definition: cs_les_balance.h:113
cs_real_t * epsvar
Definition: cs_les_balance.h:102
int f_id
Definition: cs_les_balance.h:96
cs_real_3_t * convti
Definition: cs_les_balance.h:115
cs_real_t * difflamvar
Definition: cs_les_balance.h:105
cs_real_t * prodvar
Definition: cs_les_balance.h:101
cs_real_t * convvar
Definition: cs_les_balance.h:104
cs_real_3_t * difflamti
Definition: cs_les_balance.h:116
cs_real_3_t * unstti
Definition: cs_les_balance.h:108
cs_real_3_t * tpuip
Definition: cs_les_balance.h:107
cs_real_3_t * diffttpi
Definition: cs_les_balance.h:114
cs_real_3_t ** budsgstuifull
Definition: cs_les_balance.h:119
cs_real_t * tptp
Definition: cs_les_balance.h:100
cs_real_3_t * prodtTi
Definition: cs_les_balance.h:110
cs_real_t * difftvar
Definition: cs_les_balance.h:103
cs_real_3_t * prodtUi
Definition: cs_les_balance.h:109
cs_real_3_t * budsgstui
Definition: cs_les_balance.h:117
cs_real_6_t * budsgsvarfull
Definition: cs_les_balance.h:118
cs_real_3_t * phiti
Definition: cs_les_balance.h:111
cs_real_t * budsgsvar
Definition: cs_les_balance.h:106
