8.0
cs_join_split.h
1 #ifndef __CS_JOIN_SPLIT_H__
2 #define __CS_JOIN_SPLIT_H__
5  * Set of subroutines for cutting faces during face joining.
6  *===========================================================================*/
31  * Local headers
32  *---------------------------------------------------------------------------*/
34 #include "cs_base.h"
35 #include "cs_join_mesh.h"
36 #include "cs_join_set.h"
37 #include "cs_join_util.h"
38
39 /*---------------------------------------------------------------------------*/
44  * Macro and type definitions
45  *===========================================================================*/
46
48  * Public function prototypes
49  *===========================================================================*/
50
51 /*----------------------------------------------------------------------------
52  * Build new faces after the vertex fusion operation. Split initial faces into
53  * subfaces and keep the historic between initial/final faces.
54  *
55  * parameters:
56  * param <-- set of user-defined parameters
57  * face_normal <-- array of normal vector on each face
58  * edges <-- list of edges
59  * work <-> pointer to a cs_join_mesh_t structure
60  * old2new_history <-> relation between new faces and old one:
61  * old global face -> new local face
62  *---------------------------------------------------------------------------*/
63
64 void
66  const cs_real_t face_normal[],
67  const cs_join_edges_t *edges,
68  cs_join_mesh_t **work,
69  cs_join_gset_t **old2new_history);
70
71 /*----------------------------------------------------------------------------
72  * Update after face splitting of the local join mesh structure.
73  * Send back to the original rank the new face description.
74  *
75  * parameters:
76  * param <-- set of user-defined parameters
77  * work_mesh <-- distributed mesh on faces to join
78  * gnum_rank_index <-- index on ranks for the old global face numbering
79  * o2n_hist <-> old global face -> new local face numbering
80  * local_mesh <-> mesh on local selected faces to be joined
81  *---------------------------------------------------------------------------*/
82
83 void
85  const cs_join_mesh_t *work_mesh,
86  const cs_gnum_t gnum_rank_index[],
87  cs_join_gset_t **o2n_hist,
88  cs_join_mesh_t **local_mesh);
89
90 /*---------------------------------------------------------------------------*/
91
93
94 #endif /* __CS_JOIN_SPLIT_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
void cs_join_split_faces(cs_join_param_t param, const cs_real_t face_normal[], const cs_join_edges_t *edges, cs_join_mesh_t **work, cs_join_gset_t **old2new_history)
Definition: cs_join_split.c:1844
void cs_join_split_update_struct(const cs_join_param_t param, const cs_join_mesh_t *work_mesh, const cs_gnum_t gnum_rank_index[], cs_join_gset_t **o2n_hist, cs_join_mesh_t **local_mesh)
Definition: cs_join_split.c:2259
Definition: cs_join_util.h:115
