1 #ifndef __CS_EVALUATE_H__
2 #define __CS_EVALUATE_H__
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
void cs_evaluate_array_reduction(int dim, cs_lnum_t n_x, const cs_real_t *array, const cs_real_t *w_x, cs_real_t *min, cs_real_t *max, cs_real_t *wsum, cs_real_t *asum, cs_real_t *ssum)
Compute reduced quantities for an array of size equal to dim * n_x The computed quantities are synchr...
Definition: cs_evaluate.c:1394
void cs_evaluate_potential_at_cells_by_value(const cs_xdef_t *def, cs_real_t retval[])
Evaluate a potential field at cell centers from a definition by value.
Definition: cs_evaluate.c:1902
void cs_evaluate_potential_at_cells_by_analytic(const cs_xdef_t *def, const cs_real_t time_eval, cs_real_t retval[])
Evaluate the quantity attached to a potential field at cell centers when the definition relies on an ...
Definition: cs_evaluate.c:1933
void cs_evaluate_potential_at_faces_by_analytic(const cs_xdef_t *def, const cs_real_t time_eval, const cs_lnum_t n_f_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the quantity attached to a potential field at face centers when the definition relies on an ...
Definition: cs_evaluate.c:1799
void cs_evaluate_potential_at_vertices_by_analytic(const cs_xdef_t *def, const cs_real_t time_eval, const cs_lnum_t n_v_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the quantity attached to a potential field at vertices when the definition relies on an anal...
Definition: cs_evaluate.c:1671
void cs_evaluate_density_by_analytic(cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[])
Compute the value related to each DoF in the case of a density field The value defined by the analyti...
Definition: cs_evaluate.c:1565
void cs_evaluate_potential_by_qov(cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t vvals[], cs_real_t wvals[])
Define a value to each DoF in the case of a potential field in order to put a given quantity inside t...
Definition: cs_evaluate.c:2025
void cs_evaluate_potential_at_cells_by_array(const cs_xdef_t *def, cs_real_t retval[])
Evaluate a potential field at cell centers from a definition by array.
Definition: cs_evaluate.c:1885
void cs_evaluate_scatter_array_reduction(int dim, cs_lnum_t n_x, const cs_real_t *array, const cs_adjacency_t *c2x, const cs_real_t *w_x, cs_real_t *min, cs_real_t *max, cs_real_t *wsum, cs_real_t *asum, cs_real_t *ssum)
Compute reduced quantities for an array attached to either vertex, face or edge DoFs The weight to ap...
Definition: cs_evaluate.c:1451
void cs_evaluate_circulation_along_edges_by_value(const cs_xdef_t *def, const cs_lnum_t n_e_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the circulation along a selection of (primal) edges. Circulation is defined thanks to a cons...
Definition: cs_evaluate.c:2091
void cs_evaluate_average_on_faces(const cs_xdef_t *def, cs_real_t time_eval, const cs_lnum_t n_f_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the average value on faces following the given definition.
Definition: cs_evaluate.c:2476
void cs_evaluate_average_on_faces_by_value(const cs_xdef_t *def, const cs_lnum_t n_f_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the average of a function on the faces.
Definition: cs_evaluate.c:2384
void cs_evaluate_average_on_cells(const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[])
Evaluate the average value on cells following the given definition The cells associated to this defin...
Definition: cs_evaluate.c:2664
void cs_evaluate_potential_at_cells_by_dof_func(const cs_xdef_t *def, cs_real_t retval[])
Evaluate the quantity attached to a potential field at cells when the definition relies on a DoF func...
Definition: cs_evaluate.c:1977
void cs_evaluate_circulation_along_edges_by_array(const cs_xdef_t *def, const cs_lnum_t n_e_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the circulation along a selection of (primal) edges. Circulation is defined thanks to an arr...
Definition: cs_evaluate.c:2164
void cs_evaluate_average_on_cells_by_array(const cs_xdef_t *def, cs_real_t retval[])
Evaluate the average of a function on the cells.
Definition: cs_evaluate.c:2545
void cs_evaluate_potential_at_vertices_by_value(const cs_xdef_t *def, const cs_lnum_t n_v_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate a potential field at vertices from a definition by a constant value.
Definition: cs_evaluate.c:1635
void cs_evaluate_average_on_faces_by_analytic(const cs_xdef_t *def, const cs_real_t time_eval, const cs_lnum_t n_f_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the average of a function on the faces. Warning: retval has to be initialize before calling ...
Definition: cs_evaluate.c:2420
void cs_evaluate_potential_at_vertices_by_dof_func(const cs_xdef_t *def, const cs_lnum_t n_v_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the quantity attached to a potential field at vertices when the definition relies on a DoF f...
Definition: cs_evaluate.c:1719
void cs_evaluate_potential_at_faces_by_value(const cs_xdef_t *def, const cs_lnum_t n_f_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate a potential field at face centers from a definition by a constant value.
Definition: cs_evaluate.c:1763
void cs_evaluate_average_on_cells_by_value(const cs_xdef_t *def, cs_real_t retval[])
Definition: cs_evaluate.c:2516
void cs_evaluate_density_by_value(cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t retval[])
Evaluate the quantity defined by a value in the case of a density field for all the degrees of freedo...
Definition: cs_evaluate.c:1502
void cs_evaluate_circulation_along_edges_by_analytic(const cs_xdef_t *def, const cs_real_t time_eval, const cs_lnum_t n_e_selected, const cs_lnum_t *selected_lst, cs_real_t retval[])
Evaluate the circulation along a selection of (primal) edges. Circulation is defined by an analytical...
Definition: cs_evaluate.c:2251
void cs_evaluate_average_on_cells_by_analytic(const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[])
Evaluate the average of a function on the cells Warning: retval has to be initialize before calling t...
Definition: cs_evaluate.c:2597
void cs_evaluate_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_mesh_t *mesh)
Definition: cs_evaluate.c:1365
cs_real_t cs_evaluate_scal_domain_integral_by_array(cs_flag_t array_loc, const cs_real_t *array_val)
Evaluate the integral over the full computational domain of a quantity defined by an array....
Definition: cs_evaluate.c:2705
Definition: cs_cdo_quantities.h:137
Definition: cs_xdef.h:160
