8.0
cs_enforcement.h
1 #ifndef __CS_ENFORCEMENT_H__
2 #define __CS_ENFORCEMENT_H__
5  * Manage the list of solid cells and associated helper functions
29  * Local headers
32 #include "cs_defs.h"
33 #include "cs_cdo_connect.h"
34 #include "cs_cdo_local.h"
41  * Macro definitions
45  * Structure and type definitions
63 typedef enum {
64
71
72
77 typedef enum {
78
83
84
89 typedef struct {
90
93
96  int stride;
100
101 /*============================================================================
102  * Public function prototypes
103  *============================================================================*/
104
105 /*----------------------------------------------------------------------------*/
118 /*----------------------------------------------------------------------------*/
119
123  int stride,
124  cs_lnum_t n_elts,
125  const cs_lnum_t *elt_ids,
126  const cs_real_t *values);
127
140 /*----------------------------------------------------------------------------*/
141
142 void
146  int stride,
147  cs_lnum_t n_elts,
148  const cs_lnum_t *elt_ids,
149  const cs_real_t *values);
150
151 /*----------------------------------------------------------------------------*/
159 /*----------------------------------------------------------------------------*/
160
163
164 /*----------------------------------------------------------------------------*/
170 /*----------------------------------------------------------------------------*/
171
172 void
174
175 /*----------------------------------------------------------------------------*/
182 /*----------------------------------------------------------------------------*/
183
184 void
185 cs_enforcement_param_log(const char *eqname,
186  const cs_enforcement_param_t *efp);
187
188 /*----------------------------------------------------------------------------*/
198 /*----------------------------------------------------------------------------*/
199
200 cs_real_t *
202  int n_params,
203  cs_enforcement_param_t **efp_array);
204
205 /*----------------------------------------------------------------------------*/
216
217 cs_real_t *
219  int n_params,
220  cs_enforcement_param_t **efp_array);
221
222 /*----------------------------------------------------------------------------*/
232 /*----------------------------------------------------------------------------*/
233
234 cs_real_t *
236  int n_params,
237  cs_enforcement_param_t **efp_array);
238
239 /*----------------------------------------------------------------------------*/
249 /*----------------------------------------------------------------------------*/
250
251 bool
252 cs_enforcement_dofs_cw(const cs_real_t *forced_values,
253  cs_cell_sys_t *csys,
254  cs_real_t *cw_forced_values);
255
256 /*----------------------------------------------------------------------------*/
257
259
260 #endif /* __CS_ENFORCEMENT_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
void cs_enforcement_param_log(const char *eqname, const cs_enforcement_param_t *efp)
Log a cs_enforcement_param_t structure.
Definition: cs_enforcement.c:281
cs_enforcement_selection_t
Type of entities used to define the selection where the enforcement takes place.
Definition: cs_enforcement.h:63
@ CS_ENFORCEMENT_SELECTION_VERTICES
Definition: cs_enforcement.h:68
@ CS_ENFORCEMENT_SELECTION_EDGES
Definition: cs_enforcement.h:67
@ CS_ENFORCEMENT_SELECTION_CELLS
Definition: cs_enforcement.h:65
@ CS_ENFORCEMENT_SELECTION_FACES
Definition: cs_enforcement.h:66
void cs_enforcement_param_free(cs_enforcement_param_t **p_efp)
Free a cs_enforcement_param_t structure.
Definition: cs_enforcement.c:254
cs_real_t * cs_enforcement_define_at_edges(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for edge-based scheme.
Definition: cs_enforcement.c:629
cs_real_t * cs_enforcement_define_at_faces(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for face-based scheme.
Definition: cs_enforcement.c:500
cs_enforcement_param_t * cs_enforcement_param_copy(const cs_enforcement_param_t *ref)
Copy a cs_enforcement_param_t structure.
Definition: cs_enforcement.c:228
void cs_enforcement_param_reset(cs_enforcement_param_t *efp, cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Reset an existing cs_enforcement_param_t structure.
Definition: cs_enforcement.c:172
Describe the way the values to enforce are defined.
Definition: cs_enforcement.h:77
@ CS_ENFORCEMENT_BY_DOF_VALUES
Definition: cs_enforcement.h:80
@ CS_ENFORCEMENT_BY_CONSTANT
Definition: cs_enforcement.h:79
cs_real_t * cs_enforcement_define_at_vertices(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for vertex-based scheme.
Definition: cs_enforcement.c:371
bool cs_enforcement_dofs_cw(const cs_real_t *forced_values, cs_cell_sys_t *csys, cs_real_t *cw_forced_values)
Build the cell-wise value to enforce.
Definition: cs_enforcement.c:758
cs_enforcement_param_t * cs_enforcement_param_create(cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Create and define a cs_enforcement_param_t structure.
Definition: cs_enforcement.c:111
Set of data defining an enforcement.
Definition: cs_enforcement.h:89
int stride
Definition: cs_enforcement.h:96
Definition: cs_enforcement.h:92
cs_real_t * values
Definition: cs_enforcement.h:97
cs_lnum_t n_elts
Definition: cs_enforcement.h:94
cs_enforcement_selection_t selection_type
Definition: cs_enforcement.h:91
cs_lnum_t * elt_ids
Definition: cs_enforcement.h:95
