8.0
cs_coolprop.hxx
1 #ifndef __CS_COOLPROP_HXX__
2 #define __CS_COOLPROP_HXX__
5  * Equation of state
35  * Local headers
38 #include "cs_physical_properties.h"
40 #include "cs_base.h"
45
46 /*=============================================================================
47  * Local Macro Definitions
49
51  * Structure definition
53
55  * Global variables definition
57
61
78 /*----------------------------------------------------------------------------*/
79
80 void
81 cs_phys_prop_coolprop(char *coolprop_material,
82  const char *coolprop_backend,
84  cs_phys_prop_type_t property,
85  const cs_lnum_t n_vals,
86  const cs_real_t var1[],
87  const cs_real_t var2[],
88  cs_real_t val[]);
89
94 /*----------------------------------------------------------------------------*/
95
96 void
98
99 /*----------------------------------------------------------------------------*/
100
102
103 #endif /* __CS_COOLPROP_HXX__ */
104
void cs_coolprop_finalize(void)
Free state for Coolprop plugin.
Definition: cs_coolprop.cxx:360
void cs_phys_prop_coolprop(char *coolprop_material, const char *coolprop_backend, cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_coolprop.cxx:112
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
Definition: cs_physical_properties.h:40
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
