8.0
cs_cdofb_monolithic_sles.h
1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
5  * Functions dedicated to the linear algebra settings and operations in case
6  * of CDO face-based schemes with a monolithic velocity-pressure coupling
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2023 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
46
48  * Macro definitions
50
52  * Type definitions
54
55 /*============================================================================
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
72  cs_lnum_t n_cells);
73
81
82 void
84
91 /*----------------------------------------------------------------------------*/
92
93 void
95
96 /*----------------------------------------------------------------------------*/
104 /*----------------------------------------------------------------------------*/
105
106 void
108  const cs_cdo_connect_t *connect,
109  const cs_cdo_quantities_t *quant);
110
111 /*----------------------------------------------------------------------------*/
116 /*----------------------------------------------------------------------------*/
117
118 void
120
121 /*----------------------------------------------------------------------------*/
132 /*----------------------------------------------------------------------------*/
133
134 void
136  void *context);
137
138 /*----------------------------------------------------------------------------*/
153 /*----------------------------------------------------------------------------*/
154
155 int
157  const cs_equation_param_t *eqp,
158  const cs_cdo_system_helper_t *sh,
159  cs_param_sles_t *slesp,
161
162 /*----------------------------------------------------------------------------*/
178 /*----------------------------------------------------------------------------*/
179
180 int
182  const cs_equation_param_t *eqp,
183  const cs_cdo_system_helper_t *sh,
184  cs_param_sles_t *slesp,
186
187 /*----------------------------------------------------------------------------*/
201 /*----------------------------------------------------------------------------*/
202
203 int
205  const cs_equation_param_t *eqp,
206  const cs_cdo_system_helper_t *sh,
207  cs_param_sles_t *slesp,
209
210 /*----------------------------------------------------------------------------*/
227 /*----------------------------------------------------------------------------*/
228
229 int
231  const cs_equation_param_t *eqp,
232  const cs_cdo_system_helper_t *sh,
233  cs_param_sles_t *slesp,
235
236 /*----------------------------------------------------------------------------*/
251 /*----------------------------------------------------------------------------*/
252
253 int
255  const cs_equation_param_t *eqp,
256  const cs_cdo_system_helper_t *sh,
257  cs_param_sles_t *slesp,
259
260 /*----------------------------------------------------------------------------*/
261
263
264 #endif /* __CS_CDOFB_MONOLITHIC_SLES_H__ */
Structures and function pointers useful to build and solve the Navier-Stokes equations with face-base...
void cs_cdofb_monolithic_sles_clean(cs_cdofb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdofb_monolithic_sles.c:4023
int cs_cdofb_monolithic_uzawa_cg_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schem...
Definition: cs_cdofb_monolithic_sles.c:4954
int cs_cdofb_monolithic_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.c:4363
int cs_cdofb_monolithic_uzawa_al_incr_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian (ALU) technique in an incremental way to solve t...
Definition: cs_cdofb_monolithic_sles.c:5297
void cs_cdofb_monolithic_sles_finalize(void)
Free if needed structure(s) associated CDO face-based schemes with a monolithic velocity-pressure cou...
Definition: cs_cdofb_monolithic_sles.c:4088
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
Definition: cs_cdofb_monolithic_sles.c:4108
void cs_cdofb_monolithic_sles_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:4069
void cs_cdofb_monolithic_sles_free(cs_cdofb_monolithic_sles_t **p_msles)
Free memory related to cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:4041
cs_cdofb_monolithic_sles_t * cs_cdofb_monolithic_sles_create(cs_lnum_t n_faces, cs_lnum_t n_cells)
Create an empty cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:3991
int cs_cdofb_monolithic_gkb_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Na...
Definition: cs_cdofb_monolithic_sles.c:4783
int cs_cdofb_monolithic_block_krylov(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:4572
Definition: cs_defs.h:509
Definition: cs_defs.h:313
Definition: mesh.f90:26
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_system.h:377
Definition: cs_cdofb_monolithic_priv.h:77
Definition: cs_mesh.h:85
Definition: cs_navsto_param.h:611
Definition: cs_param_sles.h:91
