8.0
cs_cdocb_monolithic_sles.h
1 #ifndef __CS_CDOCB_MONOLITHIC_SLES_H__
2 #define __CS_CDOCB_MONOLITHIC_SLES_H__
5  * Functions dedicated to the linear algebra settings and operations in case
6  * of CDO cell-based schemes with a monolithic velocity-pressure coupling
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_cdocb_priv.h"
46
48  * Macro definitions
50
52  * Type definitions
54
55 /*============================================================================
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
72  cs_lnum_t n_cells);
73
81
82 void
84
91 /*----------------------------------------------------------------------------*/
92
93 void
95
96 /*----------------------------------------------------------------------------*/
103 /*----------------------------------------------------------------------------*/
104
105 void
107  const cs_cdo_quantities_t *quant);
108
109 /*----------------------------------------------------------------------------*/
114 /*----------------------------------------------------------------------------*/
115
116 void
118
119 /*----------------------------------------------------------------------------*/
129
130 void
132  void *context);
133
147 /*----------------------------------------------------------------------------*/
148
149 int
151  const cs_cdo_system_helper_t *sh,
153
154 /*----------------------------------------------------------------------------*/
155
157
158 #endif /* __CS_CDOCB_MONOLITHIC_SLES_H__ */
void cs_cdocb_monolithic_sles_clean(cs_cdocb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdocb_monolithic_sles.c:193
void cs_cdocb_monolithic_sles_finalize(void)
Free if needed structure(s) associated CDO cell-based schemes with a monolithic velocity-pressure cou...
Definition: cs_cdocb_monolithic_sles.c:255
void cs_cdocb_monolithic_sles_init_sharing(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdocb_monolithic_sles.c:238
cs_cdocb_monolithic_sles_t * cs_cdocb_monolithic_sles_create(cs_lnum_t n_faces, cs_lnum_t n_cells)
Create an empty cs_cdocb_monolithic_sles_t structure.
Definition: cs_cdocb_monolithic_sles.c:161
void cs_cdocb_monolithic_set_sles(cs_equation_param_t *eqp, void *context)
Start setting-up the equations when a monolithic algorithm is used to couple the system....
Definition: cs_cdocb_monolithic_sles.c:272
void cs_cdocb_monolithic_sles_free(cs_cdocb_monolithic_sles_t **p_msles)
Free memory related to cs_cdocb_monolithic_sles_t structure.
Definition: cs_cdocb_monolithic_sles.c:211
int cs_cdocb_monolithic_solve(const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_cdocb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO cell-b...
Definition: cs_cdocb_monolithic_sles.c:326
Definition: cs_defs.h:509
Definition: cs_defs.h:313
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_system.h:377
Definition: cs_cdocb_priv.h:50
