8.0
Setting porosity values: basic example
Local definitions and initialization
Mesh quantities
It may be useful to access some mesh adjacencies and quantities, in which case local pointers allow for more readable code:
cs_mesh_t *m = domain->mesh;
cs_mesh_quantities_t *mq = domain->mesh_quantities;
const cs_lnum_2_t *i_face_cells
= (const cs_lnum_2_t *)m->i_face_cells;
const cs_real_3_t *restrict i_face_cog
const cs_real_3_t *restrict b_face_cog
const cs_real_3_t *restrict cell_cen
= (const cs_real_3_t *restrict)mq->cell_cen;
const cs_real_3_t *restrict i_face_normal
cs_real_3_t *restrict i_f_face_normal
const cs_real_3_t *restrict b_face_normal
cs_real_3_t *restrict b_f_face_normal
const cs_real_t *i_f_face_surf = mq->i_f_face_surf;
const cs_real_t *i_face_surf = mq->i_face_surf;
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:319
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:325
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
cs_real_t * b_face_cog
Definition: cs_mesh_quantities.h:111
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:122
cs_real_t * i_f_face_surf
Definition: cs_mesh_quantities.h:125
cs_real_t * i_face_cog
Definition: cs_mesh_quantities.h:110
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:102
cs_real_t * cell_cen
Definition: cs_mesh_quantities.h:94
cs_real_t * i_f_face_normal
Definition: cs_mesh_quantities.h:104
cs_real_t * b_f_face_normal
Definition: cs_mesh_quantities.h:106
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:100
Definition: cs_mesh.h:85
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
Associated properties
Accessing cell porosity property values is required so values may be set:
cs_real_t *cpro_porosi = cs_field_by_name("porosity")->val;
Definition: cs_field.c:2340
cs_real_t * val
Definition: cs_field.h:151
Example: define porosity by geometric zones
Individual cell porosity values can be assigned to each cell, so they may be based on groups, geometric criteria, or any other time-independent functions:
for (cs_lnum_t cell_id = 0; cell_id < m->n_cells; cell_id++) {
cs_real_t x = cell_cen[cell_id][0];
if (x < 20.)
cpro_porosi[cell_id] = 1.;
else
cpro_porosi[cell_id] = 0.5;
/* synchronize for use in fluid face factor calculation below */
halo_type);
Definition: cs_defs.h:313
void cs_field_synchronize(cs_field_t *f, cs_halo_type_t halo_type)
Synchronize current parallel and periodic field values.
Definition: cs_field_operator.c:1206
cs_halo_type_t
Definition: cs_halo.h:56
@ CS_HALO_STANDARD
Definition: cs_halo.h:58
cs_lnum_t n_cells
Definition: cs_mesh.h:97
When using the integral porosity model (cs_glob_porous_model == 3), the matching face equivalent surfaces can also be assigned in a corresponding manner, for interior faces:
for (cs_lnum_t face_id = 0; face_id < m->n_i_faces; face_id++) {
cs_real_t x = i_face_cog[face_id][0];
cs_real_t face_porosity = 1.;
if (x > 19.9999)
face_porosity = 0.5;
for (int i = 0; i < 3; i++)
i_f_face_normal[face_id][i] = face_porosity * i_face_normal[face_id][i];
mq->i_f_face_surf[face_id] = cs_math_3_norm(i_f_face_normal[face_id]);
static cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:424
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
and for boundary faces:
for (cs_lnum_t face_id = 0; face_id < m->n_b_faces; face_id++) {
cs_real_t x = b_face_cog[face_id][0];
if (x > 19.9999)
b_f_face_normal[face_id][i] = face_porosity * b_face_normal[face_id][i];
mq->b_f_face_surf[face_id] = cs_math_3_norm(b_f_face_normal[face_id]);
cs_real_t * b_f_face_surf
Definition: cs_mesh_quantities.h:126
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
When not defined in this way, face porosities will match the lowest adjacent cell porosity.
