7.3
fvm_tesselation.h
1 #ifndef __FVM_TESSELATION_H__
2 #define __FVM_TESSELATION_H__
5  * Structure describing a mesh section's subdivision into simpler elements
6  *
7  * This is mostly useful to replace polygons or polyhedra by simpler
8  * elements such as triangles, tetrahedra, and prisms upon data export.
9  *============================================================================*/
11 /*
12  This file is part of code_saturne, a general-purpose CFD tool.
13
14  Copyright (C) 1998-2022 EDF S.A.
15
16  This program is free software; you can redistribute it and/or modify it under
17  the terms of the GNU General Public License as published by the Free Software
18  Foundation; either version 2 of the License, or (at your option) any later
19  version.
20
21  This program is distributed in the hope that it will be useful, but WITHOUT
22  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24  details.
25
26  You should have received a copy of the GNU General Public License along with
27  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28  Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 */
30
31 /*----------------------------------------------------------------------------*/
32
33 #include "cs_defs.h"
34
36  * Local headers
38
39 #include "fvm_defs.h"
40 #include "fvm_io_num.h"
45
46 /*=============================================================================
47  * Macro definitions
49
50 #define FVM_TESSELATION_N_SUB_TYPES_MAX 2
51
53  * Type definitions
55
56 /*----------------------------------------------------------------------------
57  * Structure defining a tesselation of a mesh section.
58  *----------------------------------------------------------------------------*/
59
60 /*
61  Pointer to tesselation structure. The structure
62  itself is private, and is defined in fvm_tesselation.c
63 */
64
65 typedef struct _fvm_tesselation_t fvm_tesselation_t;
66
67 /*=============================================================================
68  * Public function prototypes
69  *============================================================================*/
70
71 /*----------------------------------------------------------------------------
72  * Creation of a mesh section's subdivision into simpler elements.
73  *
74  * The structure contains pointers to the mesh section's connectivity,
75  * (passed as arguments), which is not copied. This structure should thus
76  * always be destroyed before the mesh section to which it relates.
77  *
78  * Unused connectivity array arguments should be set to NULL (such as
79  * face_index[] and face_num[] for 2D or regular (strided) elements,
80  * and vertex_index[] for strided elements.
81  *
82  * At this stage, the structure does not yet contain tesselation information.
83  *
84  * parameters:
85  * element_type <-- type of elements considered
86  * n_elements <-- number of elements
87  * face_index <-- polyhedron -> faces index (O to n-1)
88  * dimension [n_elements + 1]
89  * face_num <-- element -> face numbers (1 to n, signed,
90  * > 0 for outwards pointing face normal
91  * < 0 for inwards pointing face normal);
92  * dimension: [face_index[n_elements]], or NULL
93  * vertex_index <-- element face -> vertices index (O to n-1);
94  * dimension: [n_cell_faces + 1], [n_elements + 1],
95  * or NULL depending on face_index and vertex_index
96  * vertex_num <-- element -> vertex connectivity (1 to n)
97  * global_element_num <-- global element numbers (NULL in serial mode)
98  *
99  * returns:
100  * pointer to created mesh section tesselation structure
101  *----------------------------------------------------------------------------*/
102
105  cs_lnum_t n_elements,
106  const cs_lnum_t face_index[],
107  const cs_lnum_t face_num[],
108  const cs_lnum_t vertex_index[],
109  const cs_lnum_t vertex_num[],
110  const fvm_io_num_t *global_element_num);
111
112 /*----------------------------------------------------------------------------
113  * Destruction of a mesh section tesselation structure.
114  *
115  * parameters:
116  * this_tesselation <-> pointer to structure that should be destroyed
117  *
118  * returns:
119  * NULL pointer
120  *----------------------------------------------------------------------------*/
121
123 fvm_tesselation_destroy(fvm_tesselation_t * this_tesselation);
124
125 /*----------------------------------------------------------------------------
126  * Tesselate a mesh section referred to by an fvm_tesselation_t structure.
127  *
128  * parameters:
129  * this_tesselation <-> partially initialized tesselation structure
130  * dim <-- spatial dimension
131  * vertex_coords <-- associated vertex coordinates array
132  * parent_vertex_id <-- optional indirection to vertex coordinates
133  * error_count --> number of elements with a tesselation error
134  * counter (optional)
135  *----------------------------------------------------------------------------*/
136
137 void
138 fvm_tesselation_init(fvm_tesselation_t *this_tesselation,
139  int dim,
140  const cs_coord_t vertex_coords[],
141  const cs_lnum_t parent_vertex_id[],
142  cs_lnum_t *error_count);
143
144 /*----------------------------------------------------------------------------
145  * Reduction of a nodal mesh polygon splitting representation structure;
146  * only the associations (numberings) necessary to redistribution of fields
147  * for output are conserved, the full connectivity being no longer useful
148  * once it has been output.
149  *
150  * parameters:
151  * this_tesselation <-> pointer to structure that should be reduced
152  *----------------------------------------------------------------------------*/
153
154 void
155 fvm_tesselation_reduce(fvm_tesselation_t * this_tesselation);
156
157 /*----------------------------------------------------------------------------
158  * Return number of parent elements of a tesselation.
159  *
160  * parameters:
161  * this_tesselation <-- tesselation structure
162  *
163  * returns:
164  * number of parent elements
165  *----------------------------------------------------------------------------*/
166
167 cs_lnum_t
168 fvm_tesselation_n_elements(const fvm_tesselation_t *this_tesselation);
169
170 /*----------------------------------------------------------------------------
171  * Return global number of added vertices associated with a tesselation.
172  *
173  * parameters:
174  * this_tesselation <-- tesselation structure
175  *
176  * returns:
177  * global number of added vertices associated with the tesselation
178  *----------------------------------------------------------------------------*/
179
180 cs_gnum_t
181 fvm_tesselation_n_g_vertices_add(const fvm_tesselation_t *this_tesselation);
182
183 /*----------------------------------------------------------------------------
184  * Return (local) number of added vertices associated with a tesselation.
185  *
186  * parameters:
187  * this_tesselation <-- tesselation structure
188  *
189  * returns:
190  * global number of added vertices associated with the tesselation
191  *----------------------------------------------------------------------------*/
192
193 cs_lnum_t
194 fvm_tesselation_n_vertices_add(const fvm_tesselation_t *this_tesselation);
195
196 /*----------------------------------------------------------------------------
197  * Return number of resulting sub-types of a tesselation.
198  *
199  * parameters:
200  * this_tesselation <-- tesselation structure
201  *
202  * returns:
203  * number of resulting sub-types of the tesselation
204  *----------------------------------------------------------------------------*/
205
206 int
207 fvm_tesselation_n_sub_types(const fvm_tesselation_t *this_tesselation);
208
209 /*----------------------------------------------------------------------------
210  * Return given sub-types of a tesselation.
211  *
212  * parameters:
213  * this_tesselation <-- tesselation structure
214  * sub_type_id <-- index of sub-type in tesselation (0 to n-1)
215  *
216  * returns:
217  * sub-types of the tesselation with the given index
218  *----------------------------------------------------------------------------*/
219
221 fvm_tesselation_sub_type(const fvm_tesselation_t *this_tesselation,
222  int sub_type_id);
223
224 /*----------------------------------------------------------------------------
225  * Return number of elements of a given sub-type of a tesselation.
226  *
227  * parameters:
228  * this_tesselation <-- tesselation structure
229  * sub_type_id <-- index of sub-type in tesselation (0 to n-1)
230  *
231  * returns:
232  * sub-types of the tesselation with the given index
233  *----------------------------------------------------------------------------*/
234
235 cs_lnum_t
236 fvm_tesselation_n_sub_elements(const fvm_tesselation_t *this_tesselation,
237  fvm_element_t sub_type);
238
239 /*----------------------------------------------------------------------------
240  * Obtain the global and maximum number of elements of a given sub-type
241  * of a tesselation.
242  *
243  * parameters:
244  * this_tesselation <-- tesselation structure
245  * sub_type_id <-- index of sub-type in tesselation (0 to n-1)
246  * n_sub_elements_glob --> global number of sub-elements of the given type
247  * n_sub_elements_max --> maximum number of sub-elements per element
248  * of the given type (for all ranks)
249  *----------------------------------------------------------------------------*/
250
251 void
252 fvm_tesselation_get_global_size(const fvm_tesselation_t *this_tesselation,
253  fvm_element_t sub_type,
254  cs_gnum_t *n_sub_elements_glob,
255  cs_lnum_t *n_sub_elements_max);
256
257 /*----------------------------------------------------------------------------
258  * Return global numbering of added vertices associated with a tesselation.
259  *
260  * parameters:
261  * this_tesselation <-- tesselation structure
262  *
263  * returns:
264  * pointer to global numbering of added vertices for this tesselation,
265  * or NULL if no added vertices are present.
266  *----------------------------------------------------------------------------*/
267
268 const fvm_io_num_t *
270
271 /*----------------------------------------------------------------------------
272  * Compute coordinates of added vertices for a tesselation of polyhedra.
273  *
274  * One additional vertex is added near the center of each polyhedra.
275  * For element types other than polyhedra, there is no need for added
276  * vertices, so this function returns immediately.
277  *
278  * parameters:
279  * this_tesselation <-- tesselation structure
280  * vertex_coords --> coordinates of added vertices
281  *----------------------------------------------------------------------------*/
282
283 void
284 fvm_tesselation_vertex_coords(const fvm_tesselation_t *this_tesselation,
285  cs_coord_t vertex_coords[]);
286
287 /*----------------------------------------------------------------------------
288  * Return index of sub-elements associated with each element of a given
289  * sub-type of a tesselation.
290  *
291  * parameters:
292  * this_tesselation <-- tesselation structure
293  * sub_type_id <-- index of sub-type in tesselation (0 to n-1)
294  *
295  * returns:
296  * index of sub-elements associated with each element (0 to n-1 numbering)
297  *----------------------------------------------------------------------------*/
298
299 const cs_lnum_t *
300 fvm_tesselation_sub_elt_index(const fvm_tesselation_t *this_tesselation,
301  fvm_element_t sub_type);
302
303 #if defined(HAVE_MPI)
304
305 /*----------------------------------------------------------------------------
306  * Decode tesselation to a connectivity buffer.
307  *
308  * parameters:
309  * this_tesselation <-- tesselation structure
310  * connect_type <-- destination element type
311  * extra_vertex_base <-- starting number for added vertices
312  * global_vertex_num <-- global vertex numbering
313  * extra_vertex_base <-- starting number for added vertices
314  * vertex_num --> sub-element (global) vertex connectivity
315  *----------------------------------------------------------------------------*/
316
317 void
318 fvm_tesselation_decode_g(const fvm_tesselation_t *this_tesselation,
319  fvm_element_t connect_type,
320  const fvm_io_num_t *global_vertex_num,
321  cs_gnum_t extra_vertex_base,
322  cs_gnum_t vertex_num[]);
323
324 #endif /* defined(HAVE_MPI) */
325
326 /*----------------------------------------------------------------------------
327  * Decode tesselation to a connectivity buffer.
328  *
329  * To avoid requiring huge buffers and computing unneeded element
330  * connectivities, this function may decode a partial connectivity range,
331  * starting at polygon index start_id and ending either when the indicated
332  * buffer size or the last polygon is attained.
333  * It returns the effective polygon index end.
334  *
335  * parameters:
336  * this_tesselation <-- tesselation structure
337  * connect_type <-- destination element type
338  * start_id <-- start index of polygons subset in parent section
339  * buffer_limit <-- maximum number of sub-elements of destination
340  * element type allowable for vertex_num[] buffer
341  * extra_vertex_base <-- starting number for added vertices
342  * vertex_num --> sub-element (global) vertex connectivity
343  *
344  * returns:
345  * polygon index corresponding to end of decoded range
346  *----------------------------------------------------------------------------*/
347
348 cs_lnum_t
349 fvm_tesselation_decode(const fvm_tesselation_t *this_tesselation,
350  fvm_element_t connect_type,
351  cs_lnum_t start_id,
352  cs_lnum_t buffer_limit,
353  cs_lnum_t extra_vertex_base,
354  cs_lnum_t vertex_num[]);
355
356 /*----------------------------------------------------------------------------
357  * Distribute "per element" data from the base elements to their tesselation.
358  *
359  * The same data array is used for input and output, so as to avoid requiring
360  * excess allocation in typical use cases (extracting data from a parent mesh
361  * to a buffer and distributing it as per its tesselation).
362  * The data array should be at least of size:
363  * [sub_elt_index[end_id] - sub_elt_index[start_id] * size
364  *
365  * parameters:
366  * this_tesselation <-- tesselation structure
367  * connect_type <-- destination element type
368  * start_id <-- start index of elements subset in parent section
369  * end_id <-- end index of elements subset in parent section
370  * size <-- data size for each element (sizeof(type)*stride)
371  * data <-> undistributed data in, distributed data out
372  *----------------------------------------------------------------------------*/
373
374 void
375 fvm_tesselation_distribute(const fvm_tesselation_t *this_tesselation,
376  fvm_element_t connect_type,
377  cs_lnum_t start_id,
378  cs_lnum_t end_id,
379  size_t size,
380  void *data);
381
382 /*----------------------------------------------------------------------------
383  * Compute field values at added vertices for a tesselation of polyhedra.
384  *
385  * One additional vertex is added near the center of each polyhedra.
386  * For element types other than polyhedra, there is no need for added
387  * vertices, so this function returns immediately.
388  *
389  * parameters:
390  * this_tesselation <-- tesselation structure
391  * vertex_coords <-- coordinates of added vertices
392  * src_dim <-- dimension of source data
393  * src_dim_shift <-- source data dimension shift (start index)
394  * dest_dim <-- destination data dimension (1 if non interlaced)
395  * start_id <-- added vertices start index
396  * end_id <-- added vertices past the end index
397  * src_interlace <-- indicates if source data is interlaced
398  * src_datatype <-- source data type (float, double, or int)
399  * dest_datatype <-- destination data type (float, double, or int)
400  * n_parent_lists <-- number of parent lists (if parent_num != NULL)
401  * parent_num_shift <-- parent number to value array index shifts;
402  * size: n_parent_lists
403  * parent_num <-- if n_parent_lists > 0, parent entity numbers
404  * src_data <-- array of source arrays (at least one, with one per
405  * source dimension if non interlaced, times one per
406  * parent list if multiple parent lists, with
407  * x_parent_1, y_parent_1, ..., x_parent_2, ...) order
408  * dest_data --> destination buffer
409  *----------------------------------------------------------------------------*/
410
411 void
412 fvm_tesselation_vertex_values(const fvm_tesselation_t *this_tesselation,
413  int src_dim,
414  int src_dim_shift,
415  int dest_dim,
416  cs_lnum_t start_id,
417  cs_lnum_t end_id,
418  cs_interlace_t src_interlace,
419  cs_datatype_t src_datatype,
420  cs_datatype_t dest_datatype,
421  int n_parent_lists,
422  const cs_lnum_t parent_num_shift[],
423  const cs_lnum_t parent_num[],
424  const void *const src_data[],
425  void *const dest_data);
426
427 /*----------------------------------------------------------------------------
428  * Dump printout of a mesh section tesselation structure.
429  *
430  * parameters:
431  * this_tesselation <-- pointer to structure that should be dumped
432  *----------------------------------------------------------------------------*/
433
434 void
435 fvm_tesselation_dump(const fvm_tesselation_t *this_tesselation);
436
437 /*----------------------------------------------------------------------------*/
438
440
441 #endif /* __FVM_TESSELATION_H__ */
const cs_lnum_t * fvm_tesselation_sub_elt_index(const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type)
Definition: fvm_tesselation.c:2484
cs_datatype_t
Definition: cs_defs.h:275
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_lnum_t fvm_tesselation_decode(const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t buffer_limit, cs_lnum_t extra_vertex_base, cs_lnum_t vertex_num[])
Definition: fvm_tesselation.c:2572
cs_lnum_t fvm_tesselation_n_vertices_add(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2288
cs_interlace_t
Definition: cs_defs.h:484
cs_gnum_t fvm_tesselation_n_g_vertices_add(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2259
Definition: cs_defs.h:512
fvm_tesselation_t * fvm_tesselation_destroy(fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2127
fvm_tesselation_t * fvm_tesselation_create(fvm_element_t element_type, cs_lnum_t n_elements, const cs_lnum_t face_index[], const cs_lnum_t face_num[], const cs_lnum_t vertex_index[], const cs_lnum_t vertex_num[], const fvm_io_num_t *global_element_num)
Definition: fvm_tesselation.c:2003
double cs_coord_t
Definition: cs_defs.h:320
int fvm_tesselation_n_sub_types(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2311
fvm_element_t
Definition: fvm_defs.h:48
void fvm_tesselation_vertex_values(const fvm_tesselation_t *this_tesselation, int src_dim, int src_dim_shift, int dest_dim, cs_lnum_t start_id, cs_lnum_t end_id, cs_interlace_t src_interlace, cs_datatype_t src_datatype, cs_datatype_t dest_datatype, int n_parent_lists, const cs_lnum_t parent_num_shift[], const cs_lnum_t parent_num[], const void *const src_data[], void *const dest_data)
Definition: fvm_tesselation.c:2706
void fvm_tesselation_init(fvm_tesselation_t *this_tesselation, int dim, const cs_coord_t vertex_coords[], const cs_lnum_t parent_vertex_id[], cs_lnum_t *error_count)
Definition: fvm_tesselation.c:2156
void fvm_tesselation_get_global_size(const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type, cs_gnum_t *n_sub_elements_glob, cs_lnum_t *n_sub_elements_max)
Definition: fvm_tesselation.c:2392
void fvm_tesselation_reduce(fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2211
Definition: fvm_tesselation.h:65
const fvm_io_num_t * fvm_tesselation_global_vertex_num(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2430
void fvm_tesselation_dump(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2768
Definition: cs_defs.h:316
struct _fvm_io_num_t fvm_io_num_t
Definition: fvm_io_num.h:72
Definition: cs_defs.h:513
fvm_element_t fvm_tesselation_sub_type(const fvm_tesselation_t *this_tesselation, int sub_type_id)
Definition: fvm_tesselation.c:2333
cs_lnum_t fvm_tesselation_n_elements(const fvm_tesselation_t *this_tesselation)
Definition: fvm_tesselation.c:2238
void fvm_tesselation_vertex_coords(const fvm_tesselation_t *this_tesselation, cs_coord_t vertex_coords[])
Definition: fvm_tesselation.c:2455
cs_lnum_t fvm_tesselation_n_sub_elements(const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type)
Definition: fvm_tesselation.c:2360
void fvm_tesselation_distribute(const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t end_id, size_t size, void *data)
Definition: fvm_tesselation.c:2631
