Introduction
User subroutine for the atmospheric model.
Atmospheric module
imode corresponds to the number of calls of the usatdv function. Depending on the value of imode , different operations are performed in the following example.
imode = 0
if (imode.eq.0) then
write(nfecra,*) 'defining the dimensions of the 1D vertical arrays'
else
write(nfecra,*) 'defining the coordinates and levels of the 1D vertical arrays'
endif
nvert = 1
kvert = 50
kmx = kvert
zvmax = 1975.d0
if (iatra1.gt.0) then
ztop = 11000.d0
zzmax = (int(zvmax)/1000)*1000.d0
do while(zzmax.le.(ztop-1000.d0))
zzmax = zzmax + 1000.d0
kmx = kmx + 1
enddo
endif
imode = 1
zvert(1) = 0.d0
zvert(2) = 5.d0
zvert(3) = 20.5d0
zvert(4) = 42.0d0
zvert(5) = 65.0d0
zvert(6) = 89.5d0
zvert(7) = 115.0d0
zvert(8) = 142.0d0
zvert(9) = 170.5d0
zvert(10) = 199.5d0
zvert(11) = 230.0d0
zvert(12) = 262.0d0
zvert(13) = 294.5d0
zvert(14) = 328.5d0
zvert(15) = 363.5d0
zvert(16) = 399.0d0
zvert(17) = 435.5d0
zvert(18) = 473.5d0
zvert(19) = 512.0d0
zvert(20) = 551.0d0
zvert(21) = 591.5d0
zvert(22) = 632.5d0
zvert(23) = 674.0d0
zvert(24) = 716.0d0
zvert(25) = 759.0d0
zvert(26) = 802.5d0
zvert(27) = 846.5d0
zvert(28) = 891.5d0
zvert(29) = 936.5d0
zvert(30) = 982.0d0
zvert(31) = 1028.0d0
zvert(32) = 1074.5d0
zvert(33) = 1122.0d0
zvert(34) = 1169.5d0
zvert(35) = 1217.0d0
zvert(36) = 1265.5d0
zvert(37) = 1314.5d0
zvert(38) = 1363.5d0
zvert(39) = 1413.0d0
zvert(40) = 1462.5d0
zvert(41) = 1512.5d0
zvert(42) = 1563.0d0
zvert(43) = 1613.5d0
zvert(44) = 1664.5d0
zvert(45) = 1715.5d0
zvert(46) = 1767.0d0
zvert(47) = 1818.5d0
zvert(48) = 1870.0d0
zvert(49) = 1922.5d0
zvert(50) = 1975.0d0
ztop = 11000.d0
ii = kvert
zzmax = (int(zvert(ii))/1000)*1000.d0
zzmax = zzmax+1000.d0
ii = ii + 1
zvert(ii) = zzmax
enddo
endif
do iiv = 1, nvert
xyvert(iiv,1) = 50.d0
xyvert(iiv,2) = 50.d0
xyvert(iiv,3) = 1.d0
soilvert(iiv)%albedo = 0.25d0
soilvert(iiv)%emissi = 0.965d0
soilvert(iiv)%ttsoil = 14.77d0
soilvert(iiv)%totwat = 0.0043d0
soilvert(iiv)%pressure = 1023.d0
soilvert(iiv)%density = 1.23d0
soilvert(iiv)%foir = 0.d0
soilvert(iiv)%fos = 0.d0
enddo
endif
Data Entry for the atmospheric soil model
To activate the model, the user has to set the and to specify the zone id on which the soil model is applied in cs_user_parameters.c, routine cs_user_model:
Then the user may change default coefficient values for soil categories in cs_user_parameters.f90, routine usipsu
if (iatsoil.eq.1) then
tab_sol(4)%csol = 1.7e-5
tab_sol(4)%rugthe = 0.0012
tab_sol(4)%rugdyn = 0.0012
endif
Initialization of atmospheric
The user has to specify the percentage of each categories for all faces of the soil zone in cs_user_initialization.c:
f->
val[soil_id + f->
dim * elt_id] = 0.;
f->
val[4 + f->
dim * elt_id] = 100.;
