7.3
cs_sles_it.h
1 #ifndef __CS_SLES_IT_H__
2 #define __CS_SLES_IT_H__
5  * Sparse Linear Equation Solvers
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_matrix.h"
36 #include "cs_sles.h"
37 #include "cs_sles_pc.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*----------------------------------------------------------------------------
52  * Solver types
53  *----------------------------------------------------------------------------*/
54
55 typedef enum {
56
83
84 /* Iterative linear solver context (opaque) */
85
86 typedef struct _cs_sles_it_t cs_sles_it_t;
87
88 /* Forward type declarations */
89
90 typedef struct _cs_sles_it_convergence_t cs_sles_it_convergence_t;
91
92 /*============================================================================
93  * Global variables
94  *============================================================================*/
95
96 /* Names for iterative solver types */
97
98 extern const char *cs_sles_it_type_name[];
99
100 /*=============================================================================
101  * User function prototypes
102  *============================================================================*/
103
104 /*----------------------------------------------------------------------------
105  * Solution of A.vx = Rhs using a user-defined iterative solver
106  *
107  * On entry, vx is considered initialized.
108  *
109  * parameters:
110  * c <-- pointer to solver context info
111  * a <-- matrix
112  * diag_block_size <-- diagonal block size (unused here)
113  * convergence <-- convergence information structure
114  * rhs <-- right hand side
115  * vx <-> system solution
116  * aux_size <-- number of elements in aux_vectors (in bytes)
117  * aux_vectors --- optional working area (allocation otherwise)
118  *
119  * returns:
120  * convergence state
121  *----------------------------------------------------------------------------*/
122
125  const cs_matrix_t *a,
126  cs_lnum_t diag_block_size,
127  cs_sles_it_convergence_t *convergence,
128  const cs_real_t *rhs,
129  cs_real_t *restrict vx,
130  size_t aux_size,
131  void *aux_vectors);
132
133 /*=============================================================================
134  * Public function prototypes
135  *============================================================================*/
136
137 /*----------------------------------------------------------------------------
138  * Define and associate an iterative sparse linear system solver
139  * for a given field or equation name.
140  *
141  * If this system did not previously exist, it is added to the list of
142  * "known" systems. Otherwise, its definition is replaced by the one
143  * defined here.
144  *
145  * This is a utility function: if finer control is needed, see
146  * cs_sles_define() and cs_sles_it_create().
147  *
148  * Note that this function returns a pointer directly to the iterative solver
149  * management structure. This may be used to set further options,
150  * for example using cs_sles_set_plot_options(). If needed, cs_sles_find()
151  * may be used to obtain a pointer to the matching cs_sles_t container.
152  *
153  * parameters:
154  * f_id <-- associated field id, or < 0
155  * name <-- associated name if f_id < 0, or NULL
156  * solver_type <-- type of solver (PCG, Jacobi, ...)
157  * poly_degree <-- preconditioning polynomial degree
158  * (0: diagonal; -1: non-preconditioned)
159  * n_max_iter <-- maximum number of iterations
160  *
161  * returns:
162  * pointer to newly created iterative solver info object.
163  *----------------------------------------------------------------------------*/
164
165 cs_sles_it_t *
166 cs_sles_it_define(int f_id,
167  const char *name,
168  cs_sles_it_type_t solver_type,
169  int poly_degree,
170  int n_max_iter);
171
172 /*----------------------------------------------------------------------------
173  * Create iterative sparse linear system solver info and context.
174  *
175  * parameters:
176  * solver_type <-- type of solver (PCG, Jacobi, ...)
177  * poly_degree <-- preconditioning polynomial degree
178  * (0: diagonal; -1: non-preconditioned)
179  * n_max_iter <-- maximum number of iterations
180  * update_stats <-- automatic solver statistics indicator
181  *
182  * returns:
183  * pointer to newly created solver info object.
184  *----------------------------------------------------------------------------*/
185
186 cs_sles_it_t *
188  int poly_degree,
189  int n_max_iter,
190  bool update_stats);
191
192 /*----------------------------------------------------------------------------
193  * Destroy iterative sparse linear system solver info and context.
194  *
195  * parameters:
196  * context <-> pointer to iterative sparse linear solver info
197  * (actual type: cs_sles_it_t **)
198  *----------------------------------------------------------------------------*/
199
200 void
201 cs_sles_it_destroy(void **context);
202
203 /*----------------------------------------------------------------------------
204  * Create iterative sparse linear system solver info and context
205  * based on existing info and context.
206  *
207  * parameters:
208  * context <-- pointer to reference info and context
209  * (actual type: cs_sles_it_t *)
210  *
211  * returns:
212  * pointer to newly created solver info object
213  * (actual type: cs_sles_it_t *)
214  *----------------------------------------------------------------------------*/
215
216 void *
217 cs_sles_it_copy(const void *context);
218
219 /*----------------------------------------------------------------------------
220  * Setup iterative sparse linear equation solver.
221  *
222  * parameters:
223  * context <-> pointer to iterative sparse linear solver info
224  * (actual type: cs_sles_it_t *)
225  * name <-- pointer to system name
226  * a <-- associated matrix
227  * verbosity <-- verbosity level
228  *----------------------------------------------------------------------------*/
229
230 void
231 cs_sles_it_setup(void *context,
232  const char *name,
233  const cs_matrix_t *a,
234  int verbosity);
235
236 /*----------------------------------------------------------------------------
237  * Call iterative sparse linear equation solver.
238  *
239  * parameters:
240  * context <-> pointer to iterative sparse linear solver info
241  * (actual type: cs_sles_it_t *)
242  * name <-- pointer to system name
243  * a <-- matrix
244  * verbosity <-- verbosity level
245  * precision <-- solver precision
246  * r_norm <-- residue normalization
247  * n_iter --> number of iterations
248  * residue --> residue
249  * rhs <-- right hand side
250  * vx <-> system solution
251  * aux_size <-- number of elements in aux_vectors (in bytes)
252  * aux_vectors --- optional working area (internal allocation if NULL)
253  *
254  * returns:
255  * convergence state
256  *----------------------------------------------------------------------------*/
257
259 cs_sles_it_solve(void *context,
260  const char *name,
261  const cs_matrix_t *a,
262  int verbosity,
263  double precision,
264  double r_norm,
265  int *n_iter,
266  double *residue,
267  const cs_real_t *rhs,
268  cs_real_t *vx,
269  size_t aux_size,
270  void *aux_vectors);
271
272 /*----------------------------------------------------------------------------
273  * Free iterative sparse linear equation solver setup context.
274  *
275  * This function frees resolution-related data, such as
276  * buffers and preconditioning but does not free the whole context,
277  * as info used for logging (especially performance data) is maintained.
278
279  * parameters:
280  * context <-> pointer to iterative sparse linear solver info
281  * (actual type: cs_sles_it_t *)
282  *----------------------------------------------------------------------------*/
283
284 void
285 cs_sles_it_free(void *context);
286
287 /*----------------------------------------------------------------------------
288  * Log sparse linear equation solver info.
289  *
290  * parameters:
291  * context <-> pointer to iterative sparse linear solver info
292  * (actual type: cs_sles_it_t *)
293  * log_type <-- log type
294  *----------------------------------------------------------------------------*/
295
296 void
297 cs_sles_it_log(const void *context,
298  cs_log_t log_type);
299
300 /*----------------------------------------------------------------------------
301  * Return iterative solver type.
302  *
303  * parameters:
304  * context <-- pointer to iterative solver info and context
305  *
306  * returns:
307  * selected solver type
308  *----------------------------------------------------------------------------*/
309
311 cs_sles_it_get_type(const cs_sles_it_t *context);
312
313 /*----------------------------------------------------------------------------
314  * Return the initial residue for the previous solve operation with a solver.
315  *
316  * This is useful for convergence tests when this solver is used as
317  * a preconditioning smoother.
318  *
319  * This operation is only valid between calls to cs_sles_it_setup()
320  * (or cs_sles_it_solve()) and cs_sles_it_free().
321  * It returns -1 otherwise.
322  *
323  * parameters:
324  * context <-- pointer to iterative solver info and context
325  *
326  * returns:
327  * initial residue from last call to \ref cs_sles_solve with this solver
328  *----------------------------------------------------------------------------*/
329
330 double
332
333 /*----------------------------------------------------------------------------
334  * Return a preconditioner context for an iterative sparse linear
335  * equation solver.
336  *
337  * This allows modifying parameters of a non default (Jacobi or polynomial)
338  * preconditioner.
339  *
340  * parameters:
341  * context <-- pointer to iterative solver info and context
342  *
343  * returns:
344  * pointer to preconditoner context
345  *----------------------------------------------------------------------------*/
346
347 cs_sles_pc_t *
349
350 /*----------------------------------------------------------------------------
351  * Assign a preconditioner to an iterative sparse linear equation
352  * solver, transfering its ownership to to solver context.
353  *
354  * This allows assigning a non default (Jacobi or polynomial) preconditioner.
355  *
356  * The input pointer is set to NULL to make it clear the caller does not
357  * own the preconditioner anymore, though the context can be accessed using
358  * cs_sles_it_get_cp().
359  *
360  * parameters:
361  * context <-> pointer to iterative solver info and context
362  * pc <-> pointer to preconditoner context
363  *----------------------------------------------------------------------------*/
364
365 void
367  cs_sles_pc_t **pc);
368
369 /*----------------------------------------------------------------------------
370  * Copy options from one iterative sparse linear system solver info
371  * and context to another.
372  *
373  * Optional plotting contexts are shared between the source and destination
374  * contexts.
375  *
376  * Preconditioner settings are to be handled separately.
377  *
378  * parameters:
379  * src <-- pointer to source info and context
380  * dest <-> pointer to destination info and context
381  *----------------------------------------------------------------------------*/
382
383 void
385  cs_sles_it_t *dest);
386
387 /*----------------------------------------------------------------------------
388  * Associate a similar info and context object with which some setup
389  * data may be shared.
390  *
391  * This is especially useful for sharing preconditioning data between
392  * similar solver contexts (for example ascending and descending multigrid
393  * smoothers based on the same matrix).
394  *
395  * For preconditioning data to be effectively shared, cs_sles_it_setup()
396  * (or cs_sles_it_solve()) must be called on "shareable" before being
397  * called on "context" (without cs_sles_it_free() being called in between,
398  * of course).
399  *
400  * It is the caller's responsibility to ensure the context is not used
401  * for a cs_sles_it_setup() or cs_sles_it_solve() operation after the
402  * shareable object has been destroyed (normally by cs_sles_it_destroy()).
403  *
404  * parameters:
405  * context <-> pointer to iterative sparse linear system solver info
406  * shareable <-- pointer to iterative solver info and context
407  * whose context may be shared
408  *----------------------------------------------------------------------------*/
409
410 void
412  const cs_sles_it_t *shareable);
413
414 #if defined(HAVE_MPI)
415
416 /*----------------------------------------------------------------------------*/
428 /*----------------------------------------------------------------------------*/
429
430 void
431 cs_sles_it_set_mpi_reduce_comm(cs_sles_it_t *context,
432  MPI_Comm comm,
433  MPI_Comm caller_comm);
434
435 #endif /* defined(HAVE_MPI) */
436
437 /*----------------------------------------------------------------------------
438  * Assign ordering to iterative solver.
439  *
440  * The solver context takes ownership of the order array (i.e. it will
441  * handle its later deallocation).
442  *
443  * This is useful only for Block Gauss-Seidel.
444  *
445  * parameters:
446  * context <-> pointer to iterative solver info and context
447  * order <-> pointer to ordering array
448  *----------------------------------------------------------------------------*/
449
450 void
452  cs_lnum_t **order);
453
454 /*----------------------------------------------------------------------------*/
461 /*----------------------------------------------------------------------------*/
462
463 double
465
466 /*----------------------------------------------------------------------------*/
473 /*----------------------------------------------------------------------------*/
474
475 void
476 cs_sles_it_set_breakdown_threshold(double threshold);
477
478 /*----------------------------------------------------------------------------*/
492 /*----------------------------------------------------------------------------*/
493
494 void
496  cs_sles_convergence_state_t threshold);
497
498 /*----------------------------------------------------------------------------*/
506 /*----------------------------------------------------------------------------*/
507
508 void
510  int interval);
511
512 /*----------------------------------------------------------------------------*/
519 /*----------------------------------------------------------------------------*/
520
521 void
523  int n_max_iter);
524
525 /*----------------------------------------------------------------------------
526  * Query mean number of rows under which Conjugate Gradient algorithm
527  * uses the single-reduction variant.
528  *
529  * The single-reduction variant requires only one parallel sum per
530  * iteration (instead of 2), at the cost of additional vector operations,
531  * so it tends to be more expensive when the number of matrix rows per
532  * MPI rank is high, then becomes cheaper when the MPI latency cost becomes
533  * more significant.
534  *
535  * This option is ignored for non-parallel runs, so 0 is returned.
536  *
537  * return:
538  * mean number of rows per active rank under which the
539  * single-reduction variant will be used
540  *----------------------------------------------------------------------------*/
541
542 cs_lnum_t
544
545 /*----------------------------------------------------------------------------
546  * Set mean number of rows under which Conjugate Gradient algorithm
547  * should use the single-reduction variant.
548  *
549  * The single-reduction variant requires only one parallel sum per
550  * iteration (instead of 2), at the cost of additional vector operations,
551  * so it tends to be more expensive when the number of matrix rows per
552  * MPI rank is high, then becomes cheaper when the MPI latency cost becomes
553  * more significant.
554  *
555  * This option is ignored for non-parallel runs.
556  *
557  * parameters:
558  * threshold <-- mean number of rows per active rank under which the
559  * single-reduction variant will be used
560  *----------------------------------------------------------------------------*/
561
562 void
564
565 /*----------------------------------------------------------------------------
566  * Log the current global settings relative to parallelism.
567  *----------------------------------------------------------------------------*/
568
569 void
571
572 /*----------------------------------------------------------------------------
573  * Error handler for iterative sparse linear equation solver.
574  *
575  * In case of divergence or breakdown, this error handler outputs
576  * postprocessing data to assist debugging, then aborts the run.
577  * It does nothing in case the maximum iteration count is reached.
578  *
579  * parameters:
580  * sles <-> pointer to solver object
581  * state <-- convergence state
582  * a <-- matrix
583  * rhs <-- right hand side
584  * vx <-> system solution
585  *
586  * returns:
587  * false (do not attempt new solve)
588  *----------------------------------------------------------------------------*/
589
590 bool
593  const cs_matrix_t *a,
594  const cs_real_t *rhs,
595  cs_real_t *vx);
596
597 /*----------------------------------------------------------------------------
598  * Set plotting options for an iterative sparse linear equation solver.
599  *
600  * parameters:
601  * context <-> pointer to iterative solver info and context
602  * base_name <-- base plot name to activate, NULL otherwise
603  * use_iteration <-- if true, use iteration as time stamp
604  * otherwise, use wall clock time
605  *----------------------------------------------------------------------------*/
606
607 void
609  const char *base_name,
610  bool use_iteration);
611
612 /*----------------------------------------------------------------------------
613  * Convergence test.
614  *
615  * parameters:
616  * c <-- pointer to solver context info
617  * n_iter <-- Number of iterations done
618  * residue <-- Non normalized residue
619  * convergence <-> Convergence information structure
620  *
621  * returns:
622  * convergence status.
623  *----------------------------------------------------------------------------*/
624
627  unsigned n_iter,
628  double residue,
629  cs_sles_it_convergence_t *convergence);
630
631 /*----------------------------------------------------------------------------*/
632
634
635 #endif /* __CS_SLES_IT_H__ */
void cs_sles_it_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Definition: cs_sles_it.c:4184
void cs_sles_it_transfer_parameters(const cs_sles_it_t *src, cs_sles_it_t *dest)
Copy options from one iterative sparse linear system solver info and context to another.
Definition: cs_sles_it.c:4746
#define restrict
Definition: cs_defs.h:142
Definition: cs_sles_it.h:79
Definition: cs_sles_it.h:65
cs_sles_it_type_t
Definition: cs_sles_it.h:55
Definition: cs_sles_it.h:70
bool cs_sles_it_error_post_and_abort(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Definition: cs_sles_it.c:5073
Definition: cs_sles_it.h:76
void cs_sles_it_set_restart_interval(cs_sles_it_t *context, int interval)
Define the number of iterations to be done before restarting the solver. Useful only for GCR or GMRES...
Definition: cs_sles_it.c:4953
double cs_sles_it_get_last_initial_residue(const cs_sles_it_t *context)
Definition: cs_sles_it.c:4661
Definition: cs_defs.h:512
Definition: cs_sles_it.h:71
Definition: cs_sles_it.h:64
void cs_sles_it_set_fallback_threshold(cs_sles_it_t *context, cs_sles_convergence_state_t threshold)
Define convergence level under which the fallback to another solver may be used if applicable...
Definition: cs_sles_it.c:4936
void cs_sles_it_transfer_pc(cs_sles_it_t *context, cs_sles_pc_t **pc)
Assign a preconditioner to an iterative sparse linear equation solver, transfering its ownership to t...
Definition: cs_sles_it.c:4714
Definition: cs_sles_pc.h:66
cs_lnum_t cs_sles_it_get_pcg_single_reduction(void)
Query mean number of rows under which Conjugate Gradient algorithm uses the single-reduction variant...
Definition: cs_sles_it.c:5000
Definition: cs_sles_it.h:86
Definition: cs_sles_it.h:58
Definition: cs_defs.h:322
Definition: cs_matrix.h:110
void cs_sles_it_destroy(void **context)
Definition: cs_sles_it.c:3990
void cs_sles_it_free(void *context)
Definition: cs_sles_it.c:4600
void cs_sles_it_log(const void *context, cs_log_t log_type)
Definition: cs_sles_it.c:4070
Definition: cs_sles_it.h:68
Convergence status indicator.
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
Definition: cs_sles_it.h:90
Definition: cs_sles_it.h:73
Definition: cs_sles_it.h:61
void cs_sles_it_set_breakdown_threshold(double threshold)
Define the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2...
Definition: cs_sles_it.c:4914
double precision, save a
Definition: cs_fuel_incl.f90:148
cs_sles_convergence_state_t cs_user_sles_it_solver(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *restrict vx, size_t aux_size, void *aux_vectors)
Definition: cs_sles_it.c:3778
cs_sles_pc_t * cs_sles_it_get_pc(cs_sles_it_t *context)
Return a preconditioner context for an iterative sparse linear equation solver.
Definition: cs_sles_it.c:4685
void cs_sles_it_set_n_max_iter(cs_sles_it_t *context, int n_max_iter)
Define the max. number of iterations before stopping the algorithm.
Definition: cs_sles_it.c:4972
const char * cs_sles_it_type_name[]
Definition: cs_sles_it.h:62
cs_sles_it_type_t cs_sles_it_get_type(const cs_sles_it_t *context)
Definition: cs_sles_it.c:4636
Definition: cs_sles_it.h:66
cs_log_t
Definition: cs_log.h:48
void cs_sles_it_log_parallel_options(void)
Definition: cs_sles_it.c:5042
void cs_sles_it_set_plot_options(cs_sles_it_t *context, const char *base_name, bool use_iteration)
Definition: cs_sles_it.c:5119
Definition: cs_sles_it.h:57
void cs_sles_it_set_pcg_single_reduction(cs_lnum_t threshold)
Set mean number of rows under which Conjugate Gradient algorithm should use the single-reduction vari...
Definition: cs_sles_it.c:5028
cs_sles_convergence_state_t cs_sles_it_convergence_test(cs_sles_it_t *c, unsigned n_iter, double residue, cs_sles_it_convergence_t *convergence)
Definition: cs_sles_it.c:5163
Definition: cs_defs.h:316
void cs_sles_it_set_shareable(cs_sles_it_t *context, const cs_sles_it_t *shareable)
Associate a similar info and context object with which some setup data may be shared.
Definition: cs_sles_it.c:4792
Definition: cs_defs.h:513
void cs_sles_it_assign_order(cs_sles_it_t *context, cs_lnum_t **order)
Definition: cs_sles_it.c:4867
cs_sles_it_t * cs_sles_it_create(cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter, bool update_stats)
Definition: cs_sles_it.c:3890
cs_sles_convergence_state_t cs_sles_it_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Definition: cs_sles_it.c:4377
cs_sles_it_t * cs_sles_it_define(int f_id, const char *name, cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter)
Define and associate an iterative sparse linear system solver for a given field or equation name...
Definition: cs_sles_it.c:3835
Definition: cs_sles_it.h:60
double cs_sles_it_get_breakdown_threshold(void)
Retrieve the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2...
Definition: cs_sles_it.c:4899
Definition: cs_sles_it.h:69
void * cs_sles_it_copy(const void *context)
Create iterative sparse linear system solver info and context based on existing info and context...
Definition: cs_sles_it.c:4028
Definition: cs_sles_it.h:77
