7.3
cs_restart_map.h
1 #ifndef __CS_RESTART_MAP_H__
2 #define __CS_RESTART_MAP_H__
5  * Checkpoint / restart extension to mapped meshes
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_restart.h"
46  * Macro definitions
48
49
51  * Local type definitions
53
54
56  * Global variables
58
59
60 /*============================================================================
61  * Public function prototypes
62  *============================================================================*/
63
64 /*----------------------------------------------------------------------------*/
70 /*----------------------------------------------------------------------------*/
71
72 void
73 cs_restart_map_set_mesh_input(const char *mesh_path);
74
75 /*----------------------------------------------------------------------------*/
84 /*----------------------------------------------------------------------------*/
85
86 void
87 cs_restart_map_set_options(float tolerance_base,
88  float tolerance_fraction);
89
113
114 void
115 cs_restart_map_set_locations(bool map_cell_centers,
116  bool map_vertices);
117
118 /*----------------------------------------------------------------------------*/
123
124 void
126
133 /*----------------------------------------------------------------------------*/
134
135 void
136 cs_restart_map_free(void);
137
138 /*----------------------------------------------------------------------------*/
139
141
142 #endif /* __CS_RESTART_MAP_H__ */
void cs_restart_map_free(void)
Free restart file mapping to different mesh.
Definition: cs_restart_map.c:584
void cs_restart_map_build(void)
Build mapping of restart files to different mesh if defined.
Definition: cs_restart_map.c:430
void cs_restart_map_set_mesh_input(const char *mesh_path)
Indicate restart files should be mapped to a given mesh input.
Definition: cs_restart_map.c:359
Definition: cs_defs.h:512
void cs_restart_map_set_locations(bool map_cell_centers, bool map_vertices)
Indicate whether location for restart file mapping is needed at cells or vertices.
Definition: cs_restart_map.c:412
void cs_restart_map_set_options(float tolerance_base, float tolerance_fraction)
Set options relative to restart file mapping to a given mesh input.
Definition: cs_restart_map.c:380
Definition: cs_defs.h:513
