7.3
cs_mesh_smoother.h
1
#ifndef __CS_MESH_SMOOTHER_H__
2
#define __CS_MESH_SMOOTHER_H__
4
5
* Mesh smoothing.
6
8
9
This file is part of code_saturne, a general-purpose CFD tool.
11
Copyright (C) 1998-2022 EDF S.A.
13
14
15
16
version.
18
19
20
21
details.
23
24
25
26
28
30
* Local headers
32
34
#include "
cs_base.h
#include "
cs_mesh.h
36
#include "
cs_mesh_quantities.h
38
BEGIN_C_DECLS
* Macro definitions
45
46
* Type definitions
48
49
50
51
* Public function prototypes
52
53
54
55
* Set fixed vertices flag based on feature angle criterion.
56
57
* parameters:
58
* mesh <-- pointer to a cs_mesh_t structure
59
* feature_angle <-- feature angle (bounded between 0 and 90 degrees)
60
* vtx_is_fixed --> array to define vertices mobility (1: fixed, 0: free)
61
62
63
void
64
cs_mesh_smoother_fix_by_feature
cs_mesh_t
mesh
65
cs_real_t
feature_angle,
66
int
vtx_is_fixed[]);
67
68
69
* Unwarping smoother.
70
71
* parameters:
72
73
* vtx_is_fixed --> array to define vertices mobility (1 : fixed, 0 : free)
74
75
76
void
77
cs_mesh_smoother_unwarp
cs_mesh_t
mesh
78
const
int
vtx_is_fixed[]);
79
80
81
82
END_C_DECLS
83
84
#endif
/* __CS_MESH_SMOOTHER_H__ */
cs_base.h
BEGIN_C_DECLS
Definition:
cs_defs.h:512
void cs_mesh_smoother_unwarp(cs_mesh_t *mesh, const int vtx_is_fixed[])
Unwarping smoother.
Definition:
cs_mesh_smoother.c:886
cs_real_t
Definition:
cs_defs.h:322
cs_mesh_t
Definition:
cs_mesh.h:85
void cs_mesh_smoother_fix_by_feature(cs_mesh_t *mesh, cs_real_t feature_angle, int vtx_is_fixed[])
Definition:
cs_mesh_smoother.c:797
cs_mesh.h
END_C_DECLS
Definition:
cs_defs.h:513
mesh
Definition:
mesh.f90:26
src
mesh
cs_mesh_smoother.h
Generated on Tue Dec 20 2022 17:59:02 for code_saturne by
