7.3
cs_mesh_builder.h
1 #ifndef __CS_MESH_BUILDER_H__
2 #define __CS_MESH_BUILDER_H__
5  * Auxiliary structure used to read, write, and partition mesh data.
31  * Local headers
34 #include "cs_defs.h"
36 #include "fvm_periodicity.h"
38 #include "cs_base.h"
39 #include "cs_block_dist.h"
40 #include "cs_interface.h"
45
46 /*=============================================================================
47  * Macro definitions
49
51  * Type definitions
53
54 /* Auxiliary and temporary structure used to build or distribute mesh */
55 /* ------------------------------------------------------------------ */
56
57 typedef struct {
58
59  /* Global dimensions */
60
61  cs_gnum_t n_g_faces; /* Number of faces */
62  cs_gnum_t n_g_face_connect_size; /* Size of face connectivity */
63
64  int n_perio; /* Number of periodicities */
65
66  bool have_cell_rank; /* True if cell_rank array is defined */
67
68  /* Temporary mesh data */
69
73  int *cell_gc_id;
74  int *face_gc_id;
76
77  /* Refinement features */
78
79  char *face_r_gen;
80  char *vtx_r_gen;
81
82  /* Periodic features */
83
84  int *periodicity_num; /* Periodicity numbers */
85  cs_lnum_t *n_per_face_couples; /* Nb. face couples per periodicity */
86  cs_gnum_t *n_g_per_face_couples; /* Global nb. couples per periodicity */
87
88  cs_gnum_t **per_face_couples; /* Periodic face couples list. */
89
90  /* Optional partitioning info */
91
92  int *cell_rank; /* Partition id for each cell */
93
94  /* Block ranges for parallel distribution */
95
96  int min_rank_step; /* Minimum block rank step */
97  cs_block_dist_info_t cell_bi; /* Block info for cell data */
98  cs_block_dist_info_t face_bi; /* Block info for face data */
99  cs_block_dist_info_t vertex_bi; /* Block info for vertex data */
100  cs_block_dist_info_t *per_face_bi; /* Block info for parallel face
101  couples */
102
104
105 /*============================================================================
106  * Static global variables
107  *============================================================================*/
108
109 extern cs_mesh_builder_t *cs_glob_mesh_builder; /* Pointer to builder mesh
110  structure */
111
112 /*============================================================================
113  * Public function prototypes
114  *============================================================================*/
115
116 /*----------------------------------------------------------------------------
117  * Create an empty mesh builder structure.
118  *
119  * returns:
120  * A pointer to a mesh builder structure
121  *----------------------------------------------------------------------------*/
122
125
126 /*----------------------------------------------------------------------------*
127  * Destroy a cs_mesh_builder_t structure.
128  *
129  * parameters:
130  * mb <-> pointer to pointer of structure to destroy
131  *----------------------------------------------------------------------------*/
132
133 void
135
136 /*----------------------------------------------------------------------------
137  * Define block distribution sizes for mesh builder.
138  *
139  * parameters:
140  * mb <-> mesh builder
141  * rank_id <-- id of local rank
142  * n_ranks <-- number of associated ranks
143  * min_rank_step <-- minimum rank step between blocks
144  * min_block_size <-- minimum number of entities per block
145  * n_g_cells <-- global number of cells
146  * n_g_faces <-- global number of faces
147  * n_g_vertices <-- global number of vertices
148  *----------------------------------------------------------------------------*/
149
150 void
152  int rank_id,
153  int n_ranks,
154  int min_rank_step,
155  int min_block_size,
156  cs_gnum_t n_g_cells,
157  cs_gnum_t n_g_faces,
158  cs_gnum_t n_g_vertices);
159
160 #if defined(HAVE_MPI)
161
162 /*----------------------------------------------------------------------------
163  * Extract periodic face connectivity information from faces interface
164  * for mesh builder whn running in parallel mode.
165  *
166  * parameters:
167  * n_init_perio <-- number of initial periodicities
168  * mesh <-- pointer to mesh structure
169  * mb <-> pointer to mesh builder structure
170  * periodicity <-- periodicity information
171  * face_gnum <-- global face numbers, or NULL
172  * face_ifs <-- parallel and periodic faces interfaces set
173  *----------------------------------------------------------------------------*/
174
175 void
176 cs_mesh_builder_extract_periodic_faces_g(int n_init_perio,
177  cs_mesh_builder_t *mb,
178  fvm_periodicity_t *periodicity,
179  const cs_gnum_t *face_gnum,
180  const cs_interface_set_t *face_ifs);
181
182 #endif /* defined(HAVE_MPI) */
183
184 /*----------------------------------------------------------------------------*/
185
187
188 #endif /* __CS_MESH_BUILDER_H__ */
bool have_cell_rank
Definition: cs_mesh_builder.h:66
cs_mesh_builder_t * cs_glob_mesh_builder
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_block_dist_info_t * per_face_bi
Definition: cs_mesh_builder.h:100
Definition: cs_mesh_builder.h:57
Definition: cs_defs.h:512
void cs_mesh_builder_destroy(cs_mesh_builder_t **mb)
Definition: cs_mesh_builder.c:200
int min_rank_step
Definition: cs_mesh_builder.h:96
Definition: cs_mesh_builder.h:62
cs_gnum_t ** per_face_couples
Definition: cs_mesh_builder.h:88
cs_gnum_t * face_vertices
Definition: cs_mesh_builder.h:72
cs_gnum_t n_g_faces
Definition: cs_mesh_builder.h:61
Definition: cs_mesh_builder.h:99
Definition: cs_mesh_builder.h:98
Definition: cs_defs.h:322
cs_mesh_builder_t * cs_mesh_builder_create(void)
Definition: cs_mesh_builder.c:141
cs_gnum_t * n_g_per_face_couples
Definition: cs_mesh_builder.h:86
int n_perio
Definition: cs_mesh_builder.h:64
cs_lnum_t * n_per_face_couples
Definition: cs_mesh_builder.h:85
int * cell_rank
Definition: cs_mesh_builder.h:92
char * vtx_r_gen
Definition: cs_mesh_builder.h:80
Definition: cs_interface.h:61
void cs_mesh_builder_define_block_dist(cs_mesh_builder_t *mb, int rank_id, int n_ranks, int min_rank_step, int min_block_size, cs_gnum_t n_g_cells, cs_gnum_t n_g_faces, cs_gnum_t n_g_vertices)
Definition: cs_mesh_builder.c:262
struct _fvm_periodicity_t fvm_periodicity_t
Definition: fvm_periodicity.h:67
Definition: cs_defs.h:316
char * face_r_gen
Definition: cs_mesh_builder.h:79
Definition: cs_mesh_builder.h:97
Definition: cs_defs.h:513
int * periodicity_num
Definition: cs_mesh_builder.h:84
cs_lnum_t * face_vertices_idx
Definition: cs_mesh_builder.h:71
cs_real_t * vertex_coords
Definition: cs_mesh_builder.h:75
int * cell_gc_id
Definition: cs_mesh_builder.h:73
cs_gnum_t * face_cells
Definition: cs_mesh_builder.h:70
int * face_gc_id
Definition: cs_mesh_builder.h:74
