1 #ifndef __CS_MEDCOUPLING_INTERSECTOR_HXX__ 2 #define __CS_MEDCOUPLING_INTERSECTOR_HXX__ 67 typedef struct _cs_medcoupling_intersector_t cs_medcoupling_intersector_t;
87 const char *medfile_path,
88 const char *interp_method,
89 const char *select_criteria);
105 const char *medfile_path,
106 const char *interp_method,
107 const char *select_criteria);
123 const char *medfile_path,
124 const char *interp_method,
125 const char *select_criteria);
157 cs_medcoupling_intersector_t *
170 cs_medcoupling_intersector_t *
307 const char *dir_name,
308 const char *fmt_name,
309 const char *fmt_opts,
311 bool output_at_start,
cs_real_t * cs_medcoupling_intersect_surfaces(cs_medcoupling_intersector_t *mi)
Compute the intersection surfaces between the source mesh and code mesh.
Definition: cs_medcoupling_intersector.cxx:1067
cs_medcpl_mesh_type_t
Definition: cs_medcoupling_intersector.h:54
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_id(int id)
Get a MEDCoupling intersector using its id.
Definition: cs_medcoupling_intersector.cxx:977
void cs_medcoupling_intersector_destroy_all(void)
Free all allocated intersectors.
Definition: cs_medcoupling_intersector.cxx:956
void cs_medcoupling_intersector_translate(cs_medcoupling_intersector_t *mi, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_medcoupling_intersector.cxx:1151
Definition: cs_medcoupling_intersector.h:57
Definition: cs_defs.h:512
void cs_medcoupling_intersector_add_vol(const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
Add a volume MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:831
Definition: cs_medcoupling_intersector.h:51
void cs_medcoupling_intersector_rotate(cs_medcoupling_intersector_t *mi, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
rotate the mesh
Definition: cs_medcoupling_intersector.cxx:1211
fvm_writer_time_dep_t
Definition: fvm_writer.h:57
void cs_medcoupling_intersector_scale_auto(cs_medcoupling_intersector_t *mi, cs_real_t factor)
Scale a mesh using a factor based on the current mesh center position.
Definition: cs_medcoupling_intersector.cxx:1260
void cs_medcoupling_intersector_dump_mesh(cs_medcoupling_intersector_t *mi, const char *prefix)
Definition: cs_medcoupling_intersector.cxx:1397
int cs_mi_post_get_writer_id(void)
Return writer id used for medcoupling meshes, 0 means unused.
Definition: cs_medcoupling_intersector.cxx:1418
Definition: cs_defs.h:322
void cs_medcoupling_intersector_destroy(cs_medcoupling_intersector_t *mi)
Destroy a given MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:935
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_name(const char *name)
Get a MEDCoupling intersector by name.
Definition: cs_medcoupling_intersector.cxx:998
Definition: cs_medcoupling_intersector.h:48
cs_real_t * cs_medcoupling_intersect_volume_and_surfaces(cs_medcoupling_intersector_t *mi)
Definition: cs_medcoupling_intersector.cxx:1110
void cs_mi_post_add_mesh(cs_medcoupling_intersector_t *mi)
Associate a Medcoupling mesh to the default writer.
Definition: cs_medcoupling_intersector.cxx:1476
void cs_mi_post_init_writer(const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
Create a new writer that will contains the boundary MED mesh added.
Definition: cs_medcoupling_intersector.cxx:1433
Definition: cs_medcoupling_intersector.h:59
void cs_medcoupling_intersector_transform_from_init(cs_medcoupling_intersector_t *mi, cs_real_t matrix[3][4])
Transform a mesh, but takes as input the initial position of the mesh.
Definition: cs_medcoupling_intersector.cxx:1348
Definition: cs_medcoupling_intersector.h:56
Definition: cs_defs.h:513
void cs_medcoupling_intersector_add_vol_surf(const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
Add a surface in volume MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:903
Definition: cs_medcoupling_intersector.h:47
cs_medcpl_intersect_type_t
Definition: cs_medcoupling_intersector.h:45
void cs_medcoupling_intersector_add_surf(const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
Add a surface MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:867
Definition: cs_medcoupling_intersector.h:50
Definition: cs_medcoupling_intersector.h:58
Definition: cs_medcoupling_intersector.h:49
cs_real_t * cs_medcoupling_intersect_volumes(cs_medcoupling_intersector_t *mi)
Compute the intersection volumes between the source mesh and code mesh.
Definition: cs_medcoupling_intersector.cxx:1026
