1 #ifndef __CS_MATRIX_PRIV_H__ 2 #define __CS_MATRIX_PRIV_H__ 76 (cs_matrix_destroy_struct_t) (
void **ms);
126 typedef struct _cs_matrix_struct_native_t {
138 } cs_matrix_struct_native_t;
143 typedef struct _cs_matrix_struct_csr_t {
151 bool direct_assembly;
162 } cs_matrix_struct_csr_t;
188 typedef struct _cs_matrix_struct_dist_t {
195 cs_matrix_struct_csr_t e;
196 cs_matrix_struct_csr_t
h;
201 } cs_matrix_struct_dist_t;
206 typedef struct _cs_matrix_coeff_csr_t {
223 } cs_matrix_coeff_csr_t;
230 typedef struct _cs_matrix_coeff_dist_t {
260 } cs_matrix_coeff_dist_t;
265 struct _cs_matrix_structure_t {
291 struct _cs_matrix_t {
295 const char *type_name;
296 const char *type_fname;
314 const void *structure;
345 cs_matrix_set_coeffs_t *set_coefficients;
346 cs_matrix_release_coeffs_t *release_coefficients;
347 cs_matrix_copy_diagonal_t *copy_diagonal;
348 cs_matrix_get_diagonal_t *get_diagonal;
350 cs_matrix_destroy_struct_t *destroy_structure;
351 cs_matrix_destroy_coeffs_t *destroy_coefficients;
352 cs_matrix_destroy_adaptor_t *destroy_adaptor;
354 cs_matrix_assembler_values_create_t *assembler_values_create;
362 #if defined(HAVE_ACCEL) 379 struct _cs_matrix_variant_t {
#define restrict
Definition: cs_defs.h:142
Definition: cs_defs.h:512
Definition: cs_matrix.h:85
Definition: cs_defs.h:322
Definition: cs_matrix.h:110
Definition: cs_matrix.h:100
Definition: cs_field_pointer.h:91
cs_matrix_type_t
Definition: cs_matrix.h:54
cs_alloc_mode_t
Definition: cs_base_accel.h:142
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:328
Definition: cs_defs.h:316
Definition: cs_defs.h:513
Definition: cs_numbering.h:87
cs_matrix_fill_type_t
Definition: cs_matrix.h:72
